instalation tb6560
23 Feb 2013 19:10 #30472
by charrier
instalation tb6560 was created by charrier
i install all linuxcnc on new computer its ok on ubuntu 8.04
al the 3 axis move well on stepconf x y z
when i laught linuccnc nothing move the latency test is 16500ns
i put for the parrallel all value that i find on the forun but whitout result
what happen ???
thanks
what happen ???
thanks
23 Feb 2013 19:47 - 23 Feb 2013 19:50 #30474
by cncbasher
Replied by cncbasher on topic instalation tb6560
see wiki.linuxcnc.org/uploads/TB6560.tar.gz
the connection worth noting is the amplifier enable needs to be set as a digital pin
post your hal and ini files as attachments ,
Last edit: 23 Feb 2013 19:50 by cncbasher.
23 Feb 2013 22:01 - 23 Feb 2013 22:02 #30476
by charrier
i join 2 files ini and hal with that config the 3 axxis turn well when i test them on stepconf
but not on linuxcnc 2.5.1 on ubunti 8.04
Replied by charrier on topic instalation tb6560
Last edit: 23 Feb 2013 22:02 by charrier.
23 Feb 2013 23:08 - 23 Feb 2013 23:48 #30478
by cncbasher
forgive me for more information ...
you seem to have centre of each axis as 0 is this a delta or 3d printer ?
if it is a mill, it's usual to have 0 at left side of travel and at top of z
also you seem to have a different version of a TB6560 that i am aware of do you have a pdf of the manual
and can you see any version number .
also change
stepspace to 0 in your hal file
dirhold to 63100
you also have adir and and astep is this a spindle stepper ?
also see the wiki for the TB6560 V5
wiki.linuxcnc.org/uploads/tb6560_v5.gz
I'm sure you have the pinouts incorrect for your board , more importantly the amplifier enable pin
but due to the number of differences these particular boards have and indeed different pinouts to even the manual , they can become difficult to figure out
also change
dirhold to 63100
Last edit: 23 Feb 2013 23:48 by cncbasher.
24 Feb 2013 00:55 #30485
by charrier
the card is a tb6560 4 axis the address for pdf files is:
docs.google.com/viewer?a=v&q=cache:K7YT-...4h5ItT3GNhOLvJN_4mSQ
or on google tb6560 4axes blue card whit fan
i have nothing more , on the card not nomber or n° serie
perhaps i see that kernel is mini 35 000 hrz on pdf doc
i modify to 0 and 63100 its the same thing nothing on mill but ok on stepcomf
i modify the travel
and i join new ini and hal
i modify the travel
24 Feb 2013 01:29 #30486
by charrier
24 Feb 2013 01:31 - 24 Feb 2013 02:12 #30487
by cncbasher
you have the 4 axis version
i make the following pins
x axis
step pin 16
dir pin 1
enable pin 4
y axis
step pin 14
dir pin 7
enable pin 17
z axis
step pin 3
dir pin 6
enable 5
a axis
step pin 9
dir pin 8
enable 5
estop pin 13 ( if used )
limits ( if used )
x axis pin 10
y axis pin 11
z axis pin 12
spindle relay pin 2 ( output )
x axis
step pin 16
dir pin 1
enable pin 4
y axis
step pin 14
dir pin 7
enable pin 17
z axis
step pin 3
dir pin 6
enable 5
a axis
step pin 9
dir pin 8
enable 5
limits ( if used )
x axis pin 10
y axis pin 11
z axis pin 12
Last edit: 24 Feb 2013 02:12 by cncbasher.
24 Feb 2013 02:03 #30491
by charrier
i have not problen whith the pin all is ok the motor run well when i test it in stepconf for x an y an z
i see in you reponse you inverse step an dir and you note 2 times pin 7 it not matter i rectify it
24 Feb 2013 16:09 - 24 Feb 2013 16:32 #30516
by charrier
I contrôle all pin of thé parallèle port. All Is ok
With stepcomf all axis x y z well . I change thé speed And the vélocity to adapt With my motors And my mill.
When i test in stepconf i ear à little click in bordercard for every axis.
When i laught linuxcnc i click on estop ,clic on the "x". And after ">". At this moment i ear thé same click than Before With stepconf ,in thé screen i see all gcode move but not on my mill.
Last edit: 24 Feb 2013 16:32 by charrier.
24 Feb 2013 18:53 #30519
by cncbasher
please try the attached hal file
Time to create page: 0.189 seconds
