instalation tb6560
26 Feb 2013 01:54 #30576
by charrier
Replied by charrier on topic instalation tb6560
good job
linuxcnc move
the problem was i import the hal file on forum by cut and paste by windows on a key
and the key cut and paste by ubuntu on config
the hal of cncbascher file is good
for my information i control the cncbascher's hal file and the stepconf's file
the two files are very different ,
the problem is with is stepcomf on my computer or it is normal
because if i want to change the parameter of speed or velocity is more difficult without stepcomf
thanks very much at all for your disponibility
rv
linuxcnc move
rv
26 Feb 2013 02:29 - 26 Feb 2013 04:09 #30577
by BigJohnT
Don't use windows wordpad to edit any file used by a Linux system. If you must edit on a windows machine use notepad++ (note the ++) it is a free windows editor that will not add windows line endings.
Replied by BigJohnT on topic instalation tb6560
the hal file has been send by cncbascher and i open it with bloc note or wordpad,
and i don't see anything wrong for me
Last edit: 26 Feb 2013 04:09 by BigJohnT.
26 Feb 2013 02:45 #30578
by cncbasher
Replied by cncbasher on topic instalation tb6560
it may be a good idea to become familiar with Hal , perhaps make a new configuration from stepconf , with the correct speeds you require
use the working copy as a template
i find stepconf is useful to start with , and then i hand edit the hal and ini afterwards to fine tune
The following user(s) said Thank You: charrier
