instalation tb6560
25 Feb 2013 18:48 - 25 Feb 2013 19:05 #30551
by charrier
Replied by charrier on topic instalation tb6560
hi
i put your file in my config and i laught linuxcnc i an error appear on the screen
i join on attachement
three questions:
-do you think it is a problem with the variable in ns , the latency ,the steplen ,stepspace ,dirhold, and dirsetup
-when i put your new hal file on my config an when i open stepconf a message say me that the hal as been modify ut of stepconf
and he erase the hal file it's normal ???
-if on linuxcnc with none tools define, linuxcnc can work
three questions:
Last edit: 25 Feb 2013 19:05 by charrier.
25 Feb 2013 19:30 - 25 Feb 2013 19:32 #30553
by BigJohnT
Replied by BigJohnT on topic instalation tb6560
Seems you have a typo in your hal file
When you use stepconf wizard and you want to continue to edit your configuration with stepconf then place changes in the custom or postgui hal files. Once you get past the basic config there is no reason to use stepconf wizard usually.
ma-machine.hal:1: Unknown command 'nope'
Last edit: 25 Feb 2013 19:32 by BigJohnT.
25 Feb 2013 20:35 - 25 Feb 2013 20:36 #30554
by charrier
What Is à typo
Rv
Rv
Last edit: 25 Feb 2013 20:36 by charrier.
25 Feb 2013 20:45 - 25 Feb 2013 20:46 #30556
by BigJohnT
A typo is a word that is not spelled correctly. In your case you have the word "nope" somewhere in your hal file and "nope" is not a valid command.
This is from your error.txt file
so in the file ma-machine.hal on line 1 you have the word "nope".
Last edit: 25 Feb 2013 20:46 by BigJohnT.
25 Feb 2013 21:50 #30563
What happens in that case is that a change in direction is seen as a step pulse, and the motor moves one step. It sees the direction command changing rapidly (as that is connected to the step pulses) but that has no effect.
Replied by andypugh on topic instalation tb6560
This may indicate that the step and direction pins are reversed.When i test in stepconf i ear à little click in bordercard for every axis.'
25 Feb 2013 22:45 #30566
by charrier
i delete the typo on the first line of the hal files and i retry again linuxccnc
and unfortunatly again error message latency test 18500
25 Feb 2013 22:48 - 25 Feb 2013 22:49 #30567
"ma-machine.hal:1: Unknown command ''"
So, there is still something on that line. Possibly just a space, though it is more likely to be a problem with DOS-style line-endings. Which editor did you use?
Last edit: 25 Feb 2013 22:49 by andypugh.
25 Feb 2013 23:06 #30569
by charrier
the hal file has been send by cncbascher and i open it with bloc note or wordpad,
and i don't see anything wrong for me
i send again for verification hal files and my .txt codage utf-8
and errror
sorry for my problem
rv
and errror
rv
25 Feb 2013 23:14 #30571
Try editing the original file using gedit on the Linux machine.
I think he may have accidentally typed into the file rather than a chat window or similar.the hal file has been send by cncbascher
This may be the problem. Windows programs tend to interfere with line endings.and i open it with bloc note or wordpad,
26 Feb 2013 00:15 #30575
by cncbasher
Replied by cncbasher on topic instalation tb6560
amended file
Time to create page: 0.093 seconds
