Maximum Velocity Setting Locations?
18 May 2013 08:04 #34319
by Paul
Replied by Paul on topic Maximum Velocity Setting Locations?
Well, actually tripping the arc-ok signal didn't make a difference.
18 May 2013 18:34 #34328
by BigJohnT
Replied by BigJohnT on topic Maximum Velocity Setting Locations?
A couple of important points about the thcud comp.
The following must be true to enable correction
Velocity > 0
Torch On
Arc OK On
Enabled On
Current velocity >= minimum velocity
Minimum Velocity = requested velocity -(requested velocity *(1/velocity tolerance))
I have a sample configuration almost done but have to leave for the rest of the day. I'll try and post it tomorrow morning when I've had time to test it.
JT
Velocity > 0
Torch On
Arc OK On
Enabled On
JT
18 May 2013 19:05 #34329
by Paul
Thanks John,
I appreciate all this. I believe I have all those requirements covered.
Now, I did start from a plasma setup without a thc which, itself, was based on a router setup. From there, I worked with the information in the thcud.comp file as far as hal file modifications and physical pin assignments. Maybe the info in that thcud file assumed a setup other than what I started with. I was wondering this morning, does the thcud take the up or down signals and internally move the z axis for correction or did I miss a bit of information that I should put in the hal file that connects the thcud changes to the z axis?
Good luck at the benefit.
Paul
Paul
19 May 2013 08:34 #34369
by Paul
Something else I worked on, but am not completely there, is running the z axis through thcud and maybe this is my [biggest] problem:
net zpos-cmd axis.2.motor-pos-cmd => thcud.z-pos-in
net thcud-zpos-cmd thcud.z-pos-out => stepgen.2.position-cmd
net zpos-fb thcud.z-fb-out => axis.2.motor-pos-fb
I found a couple of variations of the above, but the data flow seemed to explain the difference (I tried both ways). With the above config, I can see z-pos-in following any z axis movement, but the axis doesn't actually move and nothing changes from 0 while watching the thcud.z-pos-out and thcud-z-fb-out pins.
Paul
Paul
19 May 2013 19:07 - 19 May 2013 19:08 #34388
by BigJohnT
I created a THCUD simulator so you can see how the thcud component works.
linuxcnc.org/index.php/english/forum/49-...hc-up-down-simulator
JT
JT
Last edit: 19 May 2013 19:08 by BigJohnT.
The following user(s) said Thank You: Paul
19 May 2013 22:34 #34392
by Paul
Thank you very much, John. It appears that this thcud.comp is a bit different from the one I downloaded from your website. I have that file installed and am looking at your simulator files.
Paul
Paul
20 May 2013 01:28 - 20 May 2013 01:29 #34399
by BigJohnT
Yes, I added a few pins to show on the Pyvcp panel a couple of things. I'll change the one on my web site to the same one and use the same one to add to LinuxCNC. I hope it makes more sense now how the thcud component works.
JT
JT
Last edit: 20 May 2013 01:29 by BigJohnT.
21 May 2013 10:00 #34482
by Paul
John, your simulation files really help me to understand how this is suppose to work. One thing I am still working on and wondering about is the thcud.z-pos-out. Where does thcud.z-pos-out get it's data from? When I look through the thcud.comp file, it looks like z-pos-out = z-pos-in + any offset, if any. My z-pos-out stays at 0 and the z axis doesn't move even though I can see thcud.z-pos-in is following a z axis command to move coming from axis.2.motor-pos-cmd. I checked my velocity and even set velocity value just to check. No go. I did also notice your thcud.time and .tmax have values greater than 0 with tmax at about 15000 and time varying in the hundreds. Mine are both 0.
Does z-pos-out (and z-fb-out) not get it's data from z-pos.in from thcud?
23 May 2013 23:38 - 23 May 2013 23:40 #34595
by BigJohnT
If pressing the up and down buttons on the simulator don't change the z position out then correction is not enabled or your at your soft limit.
z position out and z feedback out are from z position in.
Does the sim have the correction enabled led? It will be green when the up and down buttons are enabled. I did a few last second additions to the sim IIRC just before I left for NC. I need to upload what I have now to be sure your looking at the latest one.
JT
JT
Last edit: 23 May 2013 23:40 by BigJohnT.
24 May 2013 05:08 #34614
by Paul
Your simulator seems to work fine. z out updates as I expected it to. I am using your info to get my parallel port setup to work. Since my Z axis doesn't move at all (THC on or off), I am looking for a reason why. That's when I noticed that z position out was not changing when a command for z to move was issued. z in changes. Now I'm not sure about Z's lineal position when I tried it and maybe it was beyond a programmed limit. I need to check that out.
Paul
Paul
Time to create page: 0.081 seconds
