Maximum Velocity Setting Locations?
24 May 2013 06:57 #34618
by BigJohnT
Replied by BigJohnT on topic Maximum Velocity Setting Locations?
It does sound like your getting closer...
JT
JT
31 May 2013 20:26 #35012
by Paul
Replied by Paul on topic Maximum Velocity Setting Locations?
Hello everyone. Just an update as I wanted to thank everyone (Especially JohnT, and Roberto, and also PCW, Andypugh, ArcEye, emcPT, Coolmo32 and I am sure others - I didn't mean to leave anyone out.)
I have the thc up/down setup mostly based on Roberto's VLCDTHC setup. I have the Proma THC wired in and have used in test mode. It's looking great so far. Full testing soon - Maybe this weekend.
Again - Thank you VERY much for all the time to help me work through this. I would not have gotten this far without your help.
On another note - I do have the Mesa THCAD for sale.
It has only been wired in less than a week for testing.
Paul K.
![:-) :-)](/media/kunena/emoticons/smile.png)
Paul K.
- Thank you received: 6176
01 Jun 2013 04:59 #35068
Replied by tommylight on topic Maximum Velocity Setting Locations?
I've spent the better part of this week wandering and wondering why o why there is not a ready made config for those simple "torch on=>arc ok=>up/down" thc controls seeing as for around $200 they do work to a certain extent and when the expectations are in check. I gave it a go at modifying the existing configs with variable results that were close but no cigar ! I made Roberto's VLCDTHC to work with everything and ..............it messes up Z axis badly, like : M3 Z goes down......or up....at normal speed and then at insane speed, and from time to time it can be stopped only with machine power off. Homing Z axes is a whole new experience into the unknown where the dark side meets the ......even darker side !!!
![:) :)](/media/kunena/emoticons/smile.png)
And here is the cherry on top: switch THC off and on and .........drum roll......... Z goes into new heights or lowers or straight into deep space, literally Z goes into 7 or 8 MILLION millimetres.
This is absolutely not complaining to Roberto or anyone for that matter, i am really grateful to all who help others in any way possible, this is just a fun way of looking at a hard day of work with the end result : the THC still not functional under linuxcnc, it works in Mach as usual with lots of unexplained problems ( i blame it on windows therefore exorcism is the only rational solution ), and being a hard core linux user it was VERY hard for me to go back to windoze and it's demons. I refuse to choose win...whatever even if it comes with a 2 meter tall blonde in the package.
Anyway, i will try your way,John, in a day or two and see if i manage to iron out the wrinkles and post back here and on cnczone and cncecke and........ahhhhh shut up!!!!
Regards,
Tom
Regards,
Tom
01 Jun 2013 19:15 #35088
by BigJohnT
Tom,
It is best to start a new thread and not hijack someone else thread.
JT
JT
02 Jun 2013 05:02 #35121
Oooops, just checked the thread title ......my bad!
JT thanks for the enlightenment,
Tom
Tom,
JT
Tom
02 Jun 2013 15:01 #35140
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Maximum Velocity Setting Locations?
Hi John
I am using your thcud component and it works well. It just so happen that I also battled with the things that Paul had problems with. Understanding the correction velocity was my biggest issue. I did get it sorted out finally and it is working great.
I made some changes to the component in the how the values are entered. I changed the correction velocity to a percentage of the requested velocity and it is entered as a percentage. I am still testing but I will run it past you when I am done. It is just easier to understand and might help other folk in the future.
Regards
Marius
www.bluearccnc.com
02 Jun 2013 18:28 #35144
by BigJohnT
Let me know when your done.
JT
Hi John
JT
03 Jun 2013 23:53 #35203
by bjames28
Hi Paul,
Where are you located? If your THCAD card is still for sale I would take it.
I wrote you a private message, but it seems that not arrived to you.
(this happened not the first time, does this work for someone else?)
Best regards:
James
Replied by bjames28 on topic Maximum Velocity Setting Locations?
On another note - I do have the Mesa THCAD for sale.It has only been wired in less than a week for testing.
Paul K.
Hi Paul,
Best regards:
James
04 Jun 2013 02:27 #35225
by Paul
I sent you an email through your LinuxCNC profile.
04 Jun 2013 10:16 - 04 Jun 2013 23:21 #35246
by bjames28
Didn't get your e-mail.
I'll inform the site admin to fix this issue.
Last edit: 04 Jun 2013 23:21 by bjames28.
Time to create page: 0.167 seconds
