rigid tapping g33.1 isnt working spindle isnt sync
- fabworx
02 Sep 2013 09:33 #38392
by fabworx
Replied by fabworx on topic rigid tapping g33.1 isnt working spindle isnt sync
here is the gcode
S500 m3
G33.1 z-0.065 k 0.08
S500 m3
- fabworx
02 Sep 2013 09:36 #38393
by fabworx
what "halcmd show pin"?
- Thank you received: 5320
02 Sep 2013 09:47 #38394
Replied by PCW on topic rigid tapping g33.1 isnt working spindle isnt sync
Typing "halcmd show pin" in a terminal window will dump
all hal pins and their states (and you can of course re-direct this output list to a file)
Looking back I notice that the your index is not synchronized with the actual spindle (This is a very unusual setup so its not surprising that motion may not like what it sees) It may be the fact that motion spindle revs is not commensurate with the index operation causes a problem
- fabworx
02 Sep 2013 09:59 #38395
by fabworx
hmmm ok what would you suggest to tie the index to the spindle cause the resent post of my hall I've deleted the gearchange. I'm leaving the gearbox in high gear which is 1:1 with the motor so as far as everyone is concerned the encoder might as well be mounted right to the spindle.
- fabworx
02 Sep 2013 10:00 #38396
by fabworx
im heading out to make it hang lol and get the halcmd show pins
- fabworx
02 Sep 2013 11:13 - 02 Sep 2013 11:14 #38400
by fabworx
ok so im thinking Im using the wrong pins to do my spindle at speed comparison. should I use the motion.spindle-in and motion.spindle-out as a comparison? if so ill need to scale my hm2_5i20.00.encoder.04.velocity pin prior to hooking it up to motion.spindle-in
Last edit: 02 Sep 2013 11:14 by fabworx.
- fabworx
02 Sep 2013 11:41 #38402
by fabworx
by the way I cant get halcmd show pins to work in the terminal window.
- fabworx
02 Sep 2013 11:46 #38404
by fabworx
oh and just for reference I thought this was odd. maybe I'm wrong I thought hm2_5i20.0.encoder.04.velocity was supposed to float out revolutions per second and its not. its putting out a number that is exactly 1000 times to small it says 0.506 to 0.507 with a s500 m3 running
- fabworx
02 Sep 2013 12:38 #38405
by fabworx
I've tried everything I can think of changed how the spindle at speed was compared. changed to a simple spindle drive with no gear change I think it has to do with the other axis. what and how can I check with the other axis?
- Thank you received: 4652
02 Sep 2013 16:32 #38414
I don't suppose you are in incremental mode and the requested movement is less than a full turn?
What is the starting Z position when you issue this command?
12.5 TPI?
Replied by andypugh on topic rigid tapping g33.1 isnt working spindle isnt sync
S500 m3
12.5 TPI?
Time to create page: 0.171 seconds
