Hi Tom,
I have posted a question regarding remembering the last position and to continue from where it left, then. Now I'm ready with a plasma table and below I mention where I'm finding it difficult to manage:
1. The complete configuration works on inches scale, I have edited LINEAR_UNITS = inch in "ini" file is this sufficient or I need to edit something more. The settings are done accordingly in other velocity, acceleration, and other section.
2. This is how I understood how to get an arc:
a. Let the Z-axis go downward until it detects the metal, as soon as it detects metal the torch is turned on.
b. Then torch moves to a certain height (I'm assuming this is the gap value, that can be adjusted in right hand side of the panel) above the surface of metal to trigger arc-ok signal.
c. Then the cut continues and the process iterates according to the program.
In my observation when I press F9 if Arc-ok signal light is green it starts taking the torch upwards, instead moving downward for metal detect. It is obvious the THC will not assign true signal for Arc-Ok until it triggers the Arc, what could be possibly going wrong. What i feel is my settings, do point out where I'm wrong:
My Z-axis is only capable of moving 0.75 Inches of total travel, so in travel height I'm setting it to 0.6 Inches. Travel height is the height I'm assuming at which plasma torch travels. I'm not getting what does switch travel value signifies, and what should I set it to.
Next is the Delay value, also I don't know what it is for but only once I have seen it to be triggered but I didn't get it why.
The gap value which need to be set is in the gap section, as 0.250 inch is sufficient should i directly set it to that value? Or is there any different math.
Threshold settings also I didn't get it.
I'm using a locally available THC, which function almost same like the Proma THC.
Thank You,
Kunal.
