THC config that works.
9 years 7 months ago #90562 by tommylight
Replied by tommylight on topic THC config that works.
You have to add a pause when you have short cuts.
Just add G04 P1 after every M5 in the gcode.
9 years 7 months ago #90563 by bubels
Replied by bubels on topic THC config that works.
I will try this solution but im talking about 1000mm cut. Then change position about 200mm a then start cut again.
9 years 7 months ago #90612 by tommylight
Sorry, i expressed myself wrong, not short cuts but short distance from end of a cut to start of the next cut.
Do try adding a 1 or 2 sec pause after M5, i know for sure it works, i added it to all the machines in the postproccessor for inkscape.
9 years 6 months ago #91466 by beauxnez
Replied by beauxnez on topic THC config that works.
Hello
I modified my michine I got a lot of inspiration from the toma machine
here's mine
www.dropbox.com/s/hhdbuz0drkhinf4/2017-0...%2015.19.11.mp4?dl=0
With the config through step conf ca works perfectly as you can see on the video
I have successfully turned off all the LEDs on the screen, configure the X, Y, Z pins but no engines running with the thc-toma file:angry:
9 years 6 months ago #91468 by tommylight
In the video the machine is moving, but it will not go further without the ARCOK signal, it waits for the torch to fire. You can wire a switch between gnd and the ARCOK input and activate it by hand after it finds the material.
9 years 6 months ago #91469 by beauxnez
merci
With the config thc toma impossible to move the motor even in manual
The axes X, Y and Z move well on the screen but not the motor
This is not normal?
