- Thank you received: 10
THC config that works.
9 years 8 months ago #87305
by beauxnez
Replied by beauxnez on topic THC config that works.
Hello
I copy the file to / home / linuxcnc / config?
- Online
9 years 8 months ago #87308
Replied by tommylight on topic THC config that works.
Yes you can, but not strictly, they can be anywhere and still work.
There is a read me with those files, and at the begining of this thread. Read that carefuly and do the changes.
There is also info on seting up the Proma elektronika 150 THC in this thread.
9 years 8 months ago - 9 years 8 months ago #87334
by beauxnez
I am sorry but with google ca becomes I do not understand anything, you have not a video?
I put the thc-toma file in home / me / linuxcnc / config
-I have to modify the ESTOP file by removing the # and put 15 instead of 10
Net ExtEStop parport.0.pin-15-in => estop-latch.0.fault-in
If I change the thc.hal file
I but my FloatSwitch on pin 13
Last edit: 9 years 8 months ago by beauxnez.
- Online
9 years 8 months ago #87343
Have you also checked the step and dir pins?
Right click on the ini file and choose open with, enter linuxcnc under use custom command.
It should open and run.
9 years 8 months ago - 9 years 8 months ago #87348
by beauxnez
9 years 8 months ago #87349
Replied by andypugh on topic THC config that works.
Are you loading an estop-latch component?
You would need to scroll about one page lower down the error listing to see the actual problem.
Time to create page: 0.130 seconds
