THC config that works.
9 years 6 months ago #91470 by tommylight
Replied by tommylight on topic THC config that works.
Did you set the correct "enable" pin in the "e-stop.hal"?
9 years 6 months ago - 9 years 6 months ago #91619 by beauxnez
Replied by beauxnez on topic THC config that works.
I have to configure the estop on pin 10 as on the original file and linuxcnc does not start?
If I put a # in the file estop ca it starts but the engine does not run
Last edit: 9 years 6 months ago by beauxnez.
9 years 6 months ago #91676 by tommylight
You have to disable the third line not the fourth, third line should be enabled only if you have an external e-stop switch.
If you disable the fourth line, you will have to add another line in the hal file with "xenable" in it and pin 17 of parallel port so it activates the enable on the drives.
9 years 6 months ago #91745 by beauxnez
On pin p17 I have the relay plasma, I can put another pin? I connect what on?
9 years 6 months ago #91778 by tommylight
9 years 6 months ago #91877 by beauxnez
Hello
I have to change the card bob but always same problem
I have to modify the files estop.hal, thc_parport.hal and thc.hal but nothing changes
What is the pin p17 used for?
With the translation google I see not what it corresponds
