THC config that works.
9 years 5 months ago #92685 by tommylight
Replied by tommylight on topic THC config that works.
Beauxnez
I will have a look again tonight , sorry for the late reply.
9 years 5 months ago #92687 by beauxnez
Replied by beauxnez on topic THC config that works.
Pas de problème
Merci de votre aide
9 years 5 months ago #92721 by tommylight
Here is the config with some more details on how to set up, but it is for Linuxcnc 2.8pre,, so it will not work on 2.7.
Unfortunately i do not speak French, i was in Paris for only 3 weeks. :(
Let's try again to make this work, thank you for your patience.
Tom.
The following user(s) said Thank You: beauxnez, ksgeek
9 years 5 months ago - 9 years 5 months ago #92730 by beauxnez
Hello, thank you.
I have to search last night I think it must work. I finished my thc with an arduino this week, I simulated the voltage with a potentiometer and I have my lights up, down and arcok that lights on the screen.
I still have to do a test of my voltage divider and see if all this works well
Last edit: 9 years 5 months ago by beauxnez.
9 years 5 months ago #92808 by beauxnez
With my plasma, I have to initiate in contact with the tole and then to rise of about 2mm.
With this config I have to modify something in the gcode or in this config?
9 years 5 months ago #92886 by tommylight
No modifications.
See picture, pierce height is there so you can set it as you need.
Time to create page: 0.145 seconds
