Work with probe
- chernogorsky
2 years 3 months ago #306234
by chernogorsky
Replied by chernogorsky on topic Work with probe
Same,
Do I need add it somethere to be loaded (like include qtdragon_handler)
> Add this to CONFIG_FOLDER/qtvcp/screen/qtdragon/
> name it qtdragon_handler.py
- chernogorsky
2 years 3 months ago #306235
by chernogorsky
Ok, it works if I add it to CONFIG_FOLDER/qtvcp/screen/qtdragon_hd/ as qtdragon_hd_handler.py
Thank you
Thank you
- chernogorsky
2 years 3 months ago #306250
by chernogorsky
Ok, it have some Z issue
so the flow is
1. do probe_tool_with_toolsetter
1.1 touch TS
1.2 go back Z_CLEARANCE (Z = *0 + Z_CLEARANCE)
2. perform XMinus
2.1 Go to X+ # move X - edge_length- xy_clearance
2.2 Go down with z_clearance_down (Z = Z - Z_CLEARANCE == *0)
2.3 Perform probe('xplus')
on 2.3 I have an issue, since its try to locate the edge of the TS with Z = top_of_TS == *0
so the flow is
1.1 touch TS
2. perform XMinus
- chrischan
1 year 11 months ago #315708
by chrischan
Replied by chrischan on topic Work with probe
Hi everybody
Sorry, but I didn't read all the 73 pages of this topic. I start using Probe-Screen but have a little bit a problem with missing M6 command.
At the moment I have several tools with SK30 holder. Every tool has it own length in the tool table and I make manual toolchange. Now I want to add a 3d probe sensor.
I don't have a tool length sensor mounted on the bed. I only use it to measure the tools.
So I would like to keep it that way.
What would be the best way to solve this problem?
- Thank you received: 4153
1 year 11 months ago #315712
Replied by rodw on topic Work with probe
Use QTdragon, premeasure your tools including your probe and its all included.. I use a height gauge offline.
- chrischan
1 year 11 months ago #315715
by chrischan
Time to create page: 0.214 seconds
