Rigid Tapping with a speed controlled spindle
- BigJohnT
- Thank you received: 1176
18 Jul 2015 19:34 #60728
by BigJohnT
Replied by BigJohnT on topic Rigid Tapping with a speed controlled spindle
That could be the issue, to eliminate the G code just run your code in a sim with a simulated spindle.
JT
JT
- Thank you received: 4992
18 Jul 2015 21:49 #60733
No, the G-code interpreter has no idea about what is going on in HAL.
Replied by andypugh on topic Rigid Tapping with a speed controlled spindle
I'll provide a theory of mine - I use a custom orient code that uses a separate PID loop. It is connected to motion.spindle-index-enable, so the PID loops change over when M19 is called. Will that be an issue?
- cradek
- Thank you received: 9
19 Jul 2015 02:31 #60742
by cradek
Replied by cradek on topic Rigid Tapping with a speed controlled spindle
The error is actually line N85, which is a G33.1 (since G33.1 is a sticky motion mode, just like G0 G1 G2 G3) without a K word. So is line N90, if you'd get that far.
On line N85 you need to add a G0 or G1, depending on what you wanted this line to do. I'm guessing you intended it to be a G0.
The following user(s) said Thank You: tnl.lambert
- tnl.lambert
20 Jul 2015 21:41 #60781
by tnl.lambert
Replied by tnl.lambert on topic Rigid Tapping with a speed controlled spindle
Very good catch. Maybe that'll teach me to write my own code instead of using generated stuff.
Thanks, and I'll test it out.
Time to create page: 0.059 seconds
