mesa 7i76 configuring a spindle encoder
10 years 7 months ago #71782 by Clive S
Replied by Clive S on topic mesa 7i76 configuring a spindle encoder
OK Andy :) WE (you) are getting there axis now loads with no errors .
The file was generated by PnCConf for my lathe But I know there are bugs in PnCConf some have been sorted but have missed 2.7.4
Now I need to connect up the index A and B from the encoder. I will report back when I have done it
10 years 7 months ago #71784 by Clive S
Thanks Andy can I trouble you with the setting up now.
I have connected the A, B and index to the 7i76 What do I have to set in the hal and ini file to make it work
10 years 7 months ago - 10 years 7 months ago #71786 by andypugh
Replied by andypugh on topic mesa 7i76 configuring a spindle encoder
What doesn't work as things are now?
Open a halmeter and look at motion.spindle-revs
If that increases by 1 for one rev of the spindle you are probably all set.
Last edit: 10 years 7 months ago by andypugh.
10 years 7 months ago - 10 years 7 months ago #71789 by Clive S
Ok no joy with motion.spindle-revs but the voltage on the index at the 7i76 pin TB3 13 changes from 5V to 0V when the chuck is rotated
edit I am using this as single ended input
Last edit: 10 years 7 months ago by Clive S.
10 years 7 months ago #71791 by andypugh
What do the other two inputs do?
What is the ...enc0.position pin doing?
10 years 7 months ago #71794 by Clive S
quote What is the ...enc0.position pin doing?
Can't seem to find that. Do you think I have it conned ok is there any thing to add in the ini file?
Time to create page: 0.222 seconds
