Getting started with Linux, LinuxCNC and CNC
- sharpshooterser
10 years 3 months ago #78076
by sharpshooterser
Replied by sharpshooterser on topic Getting started with Linux, LinuxCNC and CNC
Thank you for this, I have implemented most of them, they will be quite handy!
- sharpshooterser
10 years 3 months ago - 10 years 3 months ago #78151
by sharpshooterser
Back to the photo interrupter problem. A friend of mine made me a simple test interrupter (and I forgot to take the schematic or the picture of it) that is connected to the China BOB to 5V+, GND and lets say pin 13. But he made it with only one sensor (instead of two). I hooked it up, tried to configure it in stepconf, and blocked it with peace of paper to see will I have any readout, but no luck.
Will it work with just Index chosen, or do I need to have at least two to make it work?
Attached file is for the original Emco setup, the X40 connection is one for the factory interrupter.
Last edit: 10 years 3 months ago by sharpshooterser.
- sharpshooterser
10 years 3 months ago #78163
by sharpshooterser
This is what was used
- sharpshooterser
10 years 3 months ago #78164
by sharpshooterser
maybe a simple schematic that will work with china BOB and ITR8102 would be better to ask?
- Thank you received: 7491
10 years 3 months ago - 10 years 3 months ago #78166
Replied by tommylight on topic Getting started with Linux, LinuxCNC and CNC
That photo sensor has to be completely in dark or it will not work AFAIK. It looks wired properly, but it needs a 5V power connected to it, and that break out board requires you to add "-not" to your input lines in HAL, if i am remembering correctly.
I have attached i config i made for a friend named plasma, so just unzip it and right click on the ini file and choose open with > linuxcnc, if you do not have that in the context menu, chose "open with" and "other application", under "use custom command" write "linuxcnc" and press enter.
It will start that config so you can actually see if you got your signals going from sensor to BOB and computer.
Regards,
Tom
Regards,
Tom
Last edit: 10 years 3 months ago by tommylight.
The following user(s) said Thank You: sharpshooterser
- sharpshooterser
10 years 3 months ago #78167
by sharpshooterser
Hi Tom, thank you for the info, just there is no attachment at your post
Time to create page: 0.158 seconds
