Getting started with Linux, LinuxCNC and CNC
- sharpshooterser
10 years 3 months ago #77684
by sharpshooterser
Replied by sharpshooterser on topic Getting started with Linux, LinuxCNC and CNC
Unfortenatley, I cant see them anywhere. But here are the shematics.
10 years 3 months ago #77690
Replied by andypugh on topic Getting started with Linux, LinuxCNC and CNC
Can you see any current-limiting resistors on the little PCB in the sensor-box?
Are the LEDs wired in series or parallel?
If the measured voltage at the sensor-box end of the 5V wire is less than 5V then that would tend to suggest that there is current limiting in the supply. If it is a full 5V then is sounds like the current limiting is in the sensor-box or in the devices themselves.
The following user(s) said Thank You: sharpshooterser
- sharpshooterser
10 years 3 months ago #77691
by sharpshooterser
I ll measure it, and post the results here so we can see whats going on
- sharpshooterser
10 years 3 months ago - 10 years 3 months ago #77707
by sharpshooterser
Stupido me, I brought it home, and I forgot that I dont have power source here to take any kind of measurements.
Better photos are included, but its not likely that they will be too much help?
Last edit: 10 years 3 months ago by sharpshooterser.
10 years 3 months ago #77708
You should be able to figure out if the LEDs are wired series or parallel.
If you had a bench PSU you could see what voltage the LEDs take to reach 20mA. That would hint whether the Optos were 5V devices or not.
- sharpshooterser
10 years 3 months ago #77711
by sharpshooterser
I ll have to hook it up to the machine to take measurements.
From few days ago, if I recall correctly, a friend tried to do the measuring, and he was getting 5V, and 1.2V. But that doesnt help much...
Time to create page: 0.156 seconds
