Getting started with Linux, LinuxCNC and CNC
10 years 4 months ago - 10 years 4 months ago #76502 by Todd Zuercher
Replied by Todd Zuercher on topic Getting started with Linux, LinuxCNC and CNC
Sounds like it can't find the sub program named "od.ngc".
Should be as simple as saving the file in the right place, or correcting the path name in your ini file.
Last edit: 10 years 4 months ago by Todd Zuercher.
10 years 4 months ago - 10 years 4 months ago #76503 by sharpshooterser
Replied by sharpshooterser on topic Getting started with Linux, LinuxCNC and CNC
Umm, in a folder on desktop where I save all my ngc files. I m still new at using this B)
I havent tried to save it in a place where it prompts me to do it
Last edit: 10 years 4 months ago by sharpshooterser.
10 years 4 months ago #76505 by andypugh
Replied by andypugh on topic Getting started with Linux, LinuxCNC and CNC
sharpshooterser wrote: Umm, in a folder on desktop where I save all my ngc files. I m still new at using this
That's fine, but you need to tell LinuxCNC to look there:
linuxcnc.org/docs/2.7/html/config/ini-co...ml#_rs274ngc_section
You might as well add that folder to M-path and Subroutine path.
By default linuxCNC only knows to look in ~/linuxcnc/nc-files
10 years 4 months ago #76508 by Rick G
Take a look in your .ini file there should be a line similar to...
PROGRAM_PREFIX = /home/rick/linuxcnc/nc_files
Copy the .ngc files you want to use such as od.ngc to that directory so linuxcnc can find them.
Or as Andy said you can also add the proper information to the .ini file for the directory that you want yo use instead.
Rick G
10 years 3 months ago #77556 by sharpshooterser
I ve been busy for a while, working on lathe quite much.
I did get the configuration files set up in metric units (thanks to Sam again), and I m a happy chap :)
For now, I wont be using other GUIs than the axis one. Simply, for all of the parts I am making at present, I ve been given access to a local firm that uses Solid, and I can generate code when I need it. Not sure about working PP, but after I generate code using Fanuc PP, I just hand edit a few bits and it runs OK.
I had a problem when I was using eCam for evaluation, with loosing dimension on parts if made successively (for example, first part was 12 mm in diameter, than 11.6 mm, then 11.2 mm) if I didnt do a touch off between the parts being made. I couldnt figure out what was the problem in PP and machine settings for eCam. Anyway, trial is over, and having that luck to be able to use Solid, I am working on that - learning and using.
But, again I have a problem with dimension loss, sort of speak. But now, dimensions on all parts are the same, just smaller than in the drawing. They should be lets say 12 mm OD, and they are 11.6 mm OD. Luckily, every parts is the same. I was using just one tool for doing the turning work.
I do configure the tool(s) used when generating code as they are, with shape, nose radius etc, but I still havent set up the tool table in LinuxCNC. I figured that it has to do something with tool radius offset?
I ve read several available tutorials on how to set up the tool table, but I m afraid that I m still confused on how to do it. I do a manual change (have only 4 tools at the moment due to lack of tool holders, but I will get more).
I am using one right hand tool, one external threading tool, left hand tool and internal threading tool. Inserts are 35 degree ones. What also bugs me is how to touch off the left hand tool for Z, and how to properly set the threading tool?
Also, in a short time I will do a hardware upgrade of my Emco Compact 5 PC, although this configuration is working nicely - but I do want more speed and precision after all (5 degree steppers are odd, and honestly I dont like the sound that they are making lol). I ll also tweak the carriage gibs (replace the plastic ones with brass), make a new spindle that has a threaded end so I can replace current radial bearings with ones that can take axial loads - and threads on the end are necessary so I can create preload on them, and at the end, alter the motor speed control - from belt changing, to PWM or VFD. I hope that you will be so kind to help me go through this (I am familiar with basic setup stuff, but for instance hooking up and setting up the spindle encoder - I would like to continue using existing one).
10 years 3 months ago #77557 by BigJohnT
Replied by BigJohnT on topic Getting started with Linux, LinuxCNC and CNC
If you have not read this you need to...
linuxcnc.org/docs/2.7/html/lathe/lathe-user.html#_tool_path
Depending on the profile your cutting you will need to use tool diameter offset.
On my lathe I do 95% of my ops with ngcgui and just program each step in then concatenate them to a singe file. I do face, od, taper od, thread od, drill, bore id, tap and I'm sure there are more.
JT
The following user(s) said Thank You: sharpshooterser
Time to create page: 0.464 seconds
