how to get Mesa THC values
6 years 7 months ago #160443 by alex.statie
Replied by alex.statie on topic how to get Mesa THC values
Hello everyone!
Having a bit of trouble with configuring the THCAD + 7i77.
Did the exact connections as in this thread (fout +- to enca+-) and 5v+- to the encoder's 5v+- on the 7i77.
I was expected to connect a power source to the THCAD input and see some output for the encoders's velocity.
Linked a variable input source to the THCAD 10, fed 2-3V to the THCAD and nothing happens. Velocity is 0, although the Encoder channel A appears as true.
Is there any other config that is missing? I've added the following lines in the machine_connections.hal:
setp hm2_5i25.0.encoder.03.counter-mode 1
setp hm2_5i25.0.encoder.01.scale -1
I know the scale is missing, however i don't understand why an output is not shown.
Could it have to do that the 7i77 gets the power from the 5i25 and has no external power supply? Although that does not seem to be a problem...
Should the encoder jumper be set for single ended or differential?
Am i missing anything? Do i need to add any other config? Can you please point me to a tutorial?
Already checked the forum and boards' documentation, did not really find an answer.
Thank you!!
6 years 7 months ago - 6 years 7 months ago #160448 by tommylight
Replied by tommylight on topic how to get Mesa THC values
alex.statie wrote: setp hm2_5i25.0.encoder.03.counter-mode 1
encoder 01 or 03 ???????
Jumpers should be set to diferential.
Edited, my bad !
Last edit: 6 years 7 months ago by tommylight. Reason: reason above.
6 years 7 months ago #160451 by PCW
Replied by PCW on topic how to get Mesa THC values
Jumpers should be set to single ended.
I would tend to disagree here, When possible (and it is with the THCAD+7I77) you should always use differential signalling
so if you have fout+- wired to enca+- the 7I77 encoder channel connected to the THCAD should be jumpered for differential mode
Does the yellow LED on the 5V side of the THCAD blink faster with higher input voltages? (it should)
6 years 7 months ago #160455 by alex.statie
Thanks for the heads up!
It was indeed encoder 3, my mistake. However, that still does not solve it.
Also, tried differential and single ended. No luck...
PCW, the led blinks faster with higher voltage.
Any other ideas?
6 years 7 months ago - 6 years 7 months ago #160458 by PCW
Are you watching the encoder 3 velocity pin with halmeter or similar?
Is encoder 3 count mode set to 1?
Are you sure you are connected to encoder 3 (encoders are 0..5)
do the other encoders work as normal quadrature encoders?
If you read encoder3 input-A pin it should read random high low values, does it?
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago - 6 years 7 months ago #160459 by alex.statie
Yes, watching the parameters with halmeter.
Yes, counter mode set to 1: setp hm2_5i25.0.encoder.03.counter-mode 1
Yes, it is encoder 3. Bottom one on second row. (0, 1, 2 are linked to axis)
Yes, the other 3 work as quadrature.
Encoder3 input A is True (bit value) and stays true no matter what i do to the input voltage.
Last edit: 6 years 7 months ago by alex.statie.
Time to create page: 3.165 seconds
