how to get Mesa THC values
10 years 5 days ago #82115 by echesortux
Replied by echesortux on topic how to get Mesa THC values
setp thc.scale-offset 119000 = frequency 0V ?
setp thc.vel-scale 0.00037866834 = 300v/(916100Hz - 119100Hz) = 0.000376411 aprox.
setp thc.correction-vel 0.0001 =???
10 years 5 days ago #82116 by jtc
Replied by jtc on topic how to get Mesa THC values
echesortux wrote: setp thc.scale-offset 119000 = frequency 0V ?
1- yes, is the measured freq at 0v
2- slope of the line, I prefer to make some measurements and calc a trend line on excel to get the slope value.
3- I use a modified THC comp, so I cant help you on this one.
The following user(s) said Thank You: echesortux
10 years 5 days ago #82123 by tommylight
Replied by tommylight on topic how to get Mesa THC values
This is by how much the value will change while correcting the height, to high and the torch will bounce like a bunny, to little and it will be to slow at going up or down, so you have to test some values there to get smooth movement. That is dependant on your setup, speed of Z axis, delay on the motor drives, etc.
9 years 11 months ago #82553 by BigJohnT
Replied by BigJohnT on topic how to get Mesa THC values
echesortux wrote: Hi John, how do you get this values? I am trying to understand your plasma.hal to using with my machine.
# this might need to be increased
thanks
The THCAD manual tells you where to get the scale offset number, it's different for each card a bit I think.
JT
9 years 11 months ago #82555 by echesortux
Thanks John.
9 years 11 months ago #82564 by rodw
Replied by rodw on topic how to get Mesa THC values
JT
The manual will tell you to look for a sticker on the back of the THCAD card. I forgot to write it down before mounting the card too so when I pull the card up I am going to make my own sticker and attach it beside the THCAD in the enclosure.
Time to create page: 1.847 seconds
