how to get Mesa THC values
6 years 7 months ago - 6 years 7 months ago #160460 by PCW
Replied by PCW on topic how to get Mesa THC values
1, you should use watch rather than show as show is just a snapshot of values
2. if encoder input A is stuck high that suggests a wiring error
Can you measure the voltage across A and /A at the 7I77?
Also you may need to turn off the encoder filter on encoder 3
if you are using the 1/1 THCAD mode
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago #160462 by tommylight
Replied by tommylight on topic how to get Mesa THC values
PCW wrote:
tommylight wrote:
alex.statie wrote: setp hm2_5i25.0.encoder.03.counter-mode 1
setp hm2_5i25.0.encoder.01.scale -1
Should the encoder jumper be set for single ended or differential?
encoder 01 or 03 ???????
Jumpers should be set to single ended.
I would tend to disagree here,
Now that i read it again, i would also disagree ! :)
Edited the post above, blaming myself, i did install them so i should know.
6 years 7 months ago #160577 by alex.statie
Replied by alex.statie on topic how to get Mesa THC values
Thank you for the help!
It was due to the THC multiplier. It was set to 1:1.
1:128 produces rather stable readings.
Time to create page: 1.433 seconds
