Below code works on my machine. Slightly different approach from code posted earlier, as I worked out a bit more about how the turret works mechanically and under the old controller.
LinuxCNC HAL component to implement ATC toolchanging on Hercus PC200 Lathe
Based on "EMC2 HAL component to implement ATC toolchanging in Denford ORAC CNC lathes" (c) ArcEye 01122011 schooner30@tiscali.co.uk
Modified by pippin88 - 07/10/2017
All values are metric
Version 0c - The PC200 toolchanger has an 8 position unidirectional turret. There is an index sensor (PC200changer.index),
and a position sensor (PC200changer.pocket) that pulses once per tool position.
When the motor moves forwards, the turret rotates forward.
The position sensor does not line up exactly with the actual tool position, but is past the tool position a bit
- the turret reverses until the spring-loaded pins line up and jump into the locking holes.
When the locking pins are fully deployed, they close a circuit (PC200changer.lock)
The turret uses a simple DC motor. This is driven by an H-bridge (L298N) which takes two input signals to determine direction.
motor A and motor B. A HIGH, B HIGH = motor off; A HIGH, B LOW = motor forward; A LOW, B HIGH = motor reverse; A LOW, B LOW = motor off;
I use A HIGH, B HIGH for off, as this is less susceptible to noise than a resting LOW state.
Compile the component with 'sudo comp --install PC200changer.comp'
Below .hal file extracts give a specimen .hal connection guide. Place them as appropriate in .hal file
# loading the toolchange component in .hal file
loadrt PC200changer
addf PC200changer servo-thread
net tool-change iocontrol.0.tool-change => PC200changer.toolchange
net tool-changed iocontrol.0.tool-changed <= PC200changer.toolchanged
net tool-number iocontrol.0.tool-prep-number => PC200changer.reqtoolnumber
net tool-oldnumber iocontrol.0.tool-number => PC200changer.currenttoolnumber
net turret-lock PC200changer.lock <= hm2_7i43.0.7i76.0.0.input-25 #Turret Lock sensor (White)
net turret-index PC200changer.index <= hm2_7i43.0.7i76.0.0.input-26 #Turret Index (Green)
net turret-pocket PC200changer.pocket <= hm2_7i43.0.7i76.0.0.input-27 #Turret Pulse (Blue)
## GPIO33 = Turret motorA
setp hm2_7i43.0.gpio.033.is_output true
setp hm2_7i43.0.gpio.033.out true ### pull high at startup!!! Can change if needed
## GPIO34 = Turret motorB
setp hm2_7i43.0.gpio.034.is_output true
setp hm2_7i43.0.gpio.034.out true ### pull high at startup!!! Can change if needed
net turret-motorA PC200changer.motorA => hm2_7i43.0.gpio.033.out
net turret-motorB PC200changer.motorB => hm2_7i43.0.gpio.034.out
net xhomed joint.0.homed => PC200changer.ishomedX
net zhomed joint.1.homed => PC200changer.ishomedZ
#setp PC200changer.times 125 ### where nnn is the new value - sets a sleep timer
component PC200changer "This component controls the PC200 Lathe Auto Tool Changer. M6 calls this";
pin in bit toolchange "Receives signal from M6 that tool change required";
pin in s32 reqtoolnumber "Requested Tool Number - Tx data from M6. Only 1-8 allowed";
pin in s32 currenttoolnumber "Receives old tool number from hal / axis";
pin out bit toolchanged = false "Sends signal when tool change finished";
pin in bit index = 1 "State of turret index sensor";
pin in bit pocket = 1 "State of turret pocket sensor";
pin in bit lock = 1 "State of turret lock sensor";
pin out bit motorA = 1 "Motor signal A";
pin out bit motorB = 1 "Motor signal B";
pin in bit ishomedX = false "Status of X axis homing";
pin in bit ishomedZ = false "Status of Z axis homing";
pin out s32 turretposition = 0 "Turret Position - Initialised as a pin for debugging so we can check where it thinks it is";
pin out s32 turrethomed = 0 "Turret Homed signal - Initialised as a pin for debugging so we can check where it thinks it is";
param rw float times = 290 "Length of delay";
// Internal and debugging stuff
pin out s32 progresslevel = 0; // tracks the progress of the toolchange, just here so it can be read easily
//pin out s32 tnumber = 0; // Internal toolnumber to allow overrun of quadrant by 1 then reverse back onto it
variable bool bWarn = false; // first toolnumber reminder
variable float sleeptime = 0; // our own timer to set delay for locking - set to 0 for first run
pin out bit indexState = 1; // current state of the index signal - for rising edge
pin out bit lastindexState = 1; // previous state of the index signal - for rising edge
pin out bit unlockState = 1; // current state of the index signal - for rising edge
pin out bit lastunlockState = 1; // previous state of the index signal - for rising edge
pin out bit pocketState = 1; // current state of the pocket signal - for rising edge
pin out bit lastpocketState = 1; // previous state of the pocket signal - for rising edge
pin out bit lockState = 1; // current state of the pocket signal - lock is detected on falling edge
pin out bit lastlockState = 1; // previous state of the pocket signal
pin out bit turretislocked = 0;
option singleton yes; // makes no sense to have more than one of these components running - only one ATC
function _;
author "pippin88 pippin88@imagineant.com";
license "GPL";
FUNCTION(_)
switch (progresslevel) {
case 0: // idle waiting for toolchange request
//first make sure X and Z axes are homed. If turret is not homed, home it
if((toolchange==1)&&(turrethomed==0)&&(ishomedX)&&(ishomedZ)){
progresslevel = 1; //call case 1 - homing sequence
break;
if((toolchange==1)&&(toolchanged==0)&&(turrethomed==1)) { // if tool change requested and not done and turret already homed
if(currenttoolnumber && reqtoolnumber != currenttoolnumber && reqtoolnumber > 0 && reqtoolnumber < 9) { // if a valid number
// switch off motor if already on - both pins high = stop
motorA = 1; // "Motor input A";
motorB = 1; // "Motor input B";
//sleeptime = 0;
progresslevel = 2; //call case 2
break;
else // if tool requested is out of range set the toolchanged flag via case 5 and exit
// should only get this if tool table has more tools than ATC can have
// otherwise emc will error the M6 command
progresslevel = 5;
if(!toolchange) {
//Turn motor OFF
toolchanged = 0; // reset toolchange flag after reset by linuxcnc
//if(toolchange && currenttoolnumber==0) // if no tool is set in axis - set axis to tool requested so that can work next time
// motorA = 1; // "Motor input A";
// motorB = 1; // "Motor input B";
// progresslevel = 5;
break;
case 1: // HOMING SEQUENCE
// Turn motor forward
motorA = 0; // "Motor input A";
// use a state machine to detect the index pulse only once
indexState = index; // read the index sensor input pin
if (lastindexState != indexState) { // compare the indexState to its previous state
if (index == 0) { // if the current state is LOW then the index went from ON to OFF - FALLING EDGE
turretposition = 8; //Set Tool Pocket 1
turrethomed = 1; //Set turrent homed flag
if (reqtoolnumber == 8){
progresslevel = 4; //move to locking sequence
} else {
progresslevel = 2; //move to motor forward sequence
lastindexState = indexState; //store indexState for comparison next time around
break; // index not triggered - get out of case 1 and go round again
case 2: // UNLOCKING - use first pocket pulse to show that turret unlocked, and to prevent that first pulse counting as a position increment
// Run forward - need to clarify pins etc
//use a state machine to detect pocket sensor
unlockState = pocket; // read the pocket sensor input pin
if (lastunlockState != unlockState) { // compare the pocketState to its previous state
if (pocket == 1) { // if the current state is HIGH then the button went from OFF to ON - RISING EDGE
progresslevel = 3;
lastunlockState = unlockState; // save the current state as the last state, for next time through the loop
break; //get out of case 2 - - go round again
case 3: // FORWARD TOOL FIND SEQUENCE - Forward move until desired tool position
if(turretposition==0) { // if returning 0 something is wrong - should be homed and at pocket 1 at least
rtapi_print_msg(RTAPI_MSG_ERR, "Error - counter error");
progresslevel = 12; // doesn't exist so will go to default, output msg and then sit in level 10
break;
//use a state machine to detect pocket sensor once per position only
pocketState = pocket; // read the pocket sensor input pin
if (lastpocketState != pocketState) { // compare the pocketState to its previous state
if (pocket == 0) { // if the state has changed, increment the counter
// if the current state is LOW then the button went from ON to OFF - FALLING EDGE
turretposition++; //increment tool position counter
if(turretposition > 8)
turretposition = turretposition - 8; //we have gone round from 8 to 1
lastpocketState = pocketState; // save the current state as the last state, for next time through the loop
if (turretposition == reqtoolnumber) {
progresslevel = 4; //move to case 4
break; //get out of case 3 - go round again
case 4: // LOCKING SEQUENCE
// Reverse locking move
motorB = 0; // "Motor input B";
//use a state machine to detect lock sensor once only - detect falling edge
lockState = lock; // read the pocket sensor input pin
if (lastlockState != lockState) { // compare the pocketState to its previous state
if (lock == 0) { // if the state has changed, increment the counter
// if the current state is LOW then the lock circuit has grounded
//Turn motor OFF
turretislocked = 1;
progresslevel = 5;
lastlockState = lockState; // save the current state as the last state, for next time through the loop
break; //get out of case 4 - go round again
case 5: // clean up ready for next toolchange
//sleeptime = 0;
progresslevel = 6;
toolchanged = 1; // signal finished
break; //get out of case 5 - go round again
case 6:
//if(sleeptime < 1)
// sleeptime++;
// break;
progresslevel = 0;
break;
case 10: break; // should never get here but if we do then loop endlessly doing nothing
default:
progresslevel = 10;
rtapi_print_msg(RTAPI_MSG_ERR, "Error state in PC200changer - now disabled - unload PC200changer");
break;
