Stepper motors and linear scale closed loop setup?
8 years 3 months ago #115327 by Hakan
Tuned and tested in the video.
Now the Y axis.
The following user(s) said Thank You: Clive S, tivoi
8 years 2 months ago - 8 years 2 months ago #115736 by Hakan
Finishing off the X axis. Aligning the reading head, mounting the cover.
Another of these un-polished videos that show every detail.
Last edit: 8 years 2 months ago by Hakan.
8 years 2 months ago - 8 years 2 months ago #115811 by RayJr
Hi Peter.
Re: PID command-deriv pins on all stepgens
Could you elaborate a bit more on this?
Does it apply to open loop PID setups, or both open & closed?
I am on LCNC V. 2.7.14
Thank you!
Ray
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Last edit: 8 years 2 months ago by RayJr.
8 years 2 months ago #116106 by Hakan
The Y axis is now done. The Y axis is in poor mechanical shape with a backlash of 0.2-0.3 mm.
Nevertheless I test to see if the encoder can improve things.
I think the result was interesting, although not perfect. The Y axis will be rebuilt later on.
The following user(s) said Thank You: gantarone
8 years 2 months ago #116889 by Hakan
I test the stepper motors' resolution and try to see if that has an influence on the following error.
The locking screw from from the video is finally added.
8 years 1 month ago #117066 by Hakan
Prepare a BK15 bearing block with angular contact bearings for use on the Y-axis.
This will, when mounted, improve backlash and stiffness in the Y-axis.
Time to create page: 0.220 seconds
