Stepper motors and linear scale closed loop setup?
7 years 9 months ago #124229 by Hakan
That sounds like what i have in mind.
I mostly looked at the Single Line Resistance system. I am not dismissing the method as such but I think the oil points on my machine are not that similar or reliably made that the design rules can be applied everywhere. I might be wrong. Anyway I have made up my mind to make something myself. I like to tinker with such things.
7 years 9 months ago #124752 by Hakan
Slowly getting there. First use of the refurbished Y axis.
7 years 9 months ago - 7 years 9 months ago #124970 by Hakan
Replacing the plastic Y motor mount with one made of steel.
Testing how serviceable the Y ballscrew is by installing an oiler hose for the Y ballscrew nut.
Some remarks on the performance after the rebuild in the end.
Sorry and old version was uploaded. This is mended now.
Last edit: 7 years 9 months ago by Hakan.
7 years 9 months ago #124982 by tecno
You have been busy Håkan. Looking good so keep on with the good work.
7 years 9 months ago #125084 by Hakan
It took its time, but now it is up and running. I have some more things I want to do with it.
Any ideas on how to test performance with and without the linear encoders?
I would like to record several minutes of data but halscope has its limits.
7 years 9 months ago #125088 by PCW
You can use hal-sampler to record as much data as you want...
To check the difference between open and closed loop you could change the feedback path to the PID from encoder or stepgen leaving the encoder
feedback to motion (so the following error was always valid)
