Stepper motors and linear scale closed loop setup?
5 years 11 months ago #189683 by Muzzer
Hmm. So I have a 5i25 and 7i76. I just bought a 7i85 - am I missing a critical component?
From tommylight's response, I thought this was a compatible board. Seems not - what to do?
5 years 11 months ago #189688 by PCW
You would need a cable to connect from the 5I25 to the 7I85
5 years 11 months ago #189690 by Muzzer
I was guessing so - but as I only have one 5i25 and would appear to need it for the 7i76 to drive my servos, I'm wondering where that leaves me. The motherboard only has one PCI slot as it is.
So do I "put the 7i76 and 7i85 aside" (possibly the 5i25 too) and spend more beer tokens on a 7i96 or similar? I would presumably be best off to go for an ethernet connection these days.
5 years 11 months ago #189691 by PCW
The 5I25 has 2 I/O connectors, one is used for the 7I76 (P3) and the other (P2) would be used by the 7I85
5 years 11 months ago #189699 by tommylight
Muzzer wrote: Hmm. So I have a 5i25 and 7i76. I just bought a 7i85 - am I missing a critical component?
PCW explained already, but just in case:
5i25 will work with 7i76 AND 7i85, you do need a 26 pin header to DB25 cable and another DB25 to DB25 or parallel port cable.
This is the header, might find it in some PC it was widely used in some of them :
eusurplus.com/index.php?route=product/category&path=59_63
First and third OR second and third, depending on the PCI slot size.
5 years 11 months ago - 5 years 11 months ago #189732 by chris@cnc
Hi , i have the 7i76E + 7i85s + 7i85 + 7i84
Bit file is in standard an works pretty well :)
Last edit: 5 years 11 months ago by chris@cnc.
Time to create page: 0.133 seconds
