Linuxcnc always wants to update my INI file
6 years 9 months ago #154161 by Mike_Eitel
I think Version 1.1 must be adapted. A while agoo there was something about it here on the forum
The following user(s) said Thank You: DC67
6 years 9 months ago #154369 by andypugh
Is this fixed?
6 years 9 months ago #154413 by DC67
Hello
Not until now. I'm still looking for a solution.
6 years 9 months ago #154480 by andypugh
What happens if you allow LinuxCNC to update the INI file?
6 years 9 months ago - 6 years 9 months ago #154531 by DC67
if i try to update i get an error.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.8.0-pre1-5304-gc20f7ed38
Machine configuration directory is '/home/linuxcnc/linuxcnc/configs/Fenja'
Machine configuration file is 'Fenja.ini'
INIFILE=/home/linuxcnc/linuxcnc/configs/Fenja/Fenja.ini
VERSION=
halfiles =
halpaths =
update script failed in an unexpected way.
Debug file information:
Can not find -sec EMC -var VERSION -num 1
File "/usr/bin/update_ini", line 197, in <module>
all_sections.remove("EMC")
ValueError: list.remove(x): x not in list
Date: Fr 10. Jan 09:26:12 CET 2020
UTC Date: Fr 10. Jan 08:26:12 UTC 2020
this program: /usr/bin/linuxcnc_info
uptime: 09:26:12 up 2 min, 1 user, load average: 0,91, 0,66, 0,27
lsb_release -sa: Debian Debian GNU/Linux 9.11 (stretch) 9.11 stretch
which linuxcnc: /usr/bin/linuxcnc
uname items:
nodename -n: linuxcnc-fraese
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.189-3+deb9u2 (2019-11-11)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-11-rt-amd64 root=UUID=d181fc0c-5f1c-4a2e-a0e1-6cfc77e43d12 ro quiet isolcpus=1,2,3
model name: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
cores: 4
cpu MHz: 1999.200
parport:
serial:
Versions:
gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
python: Python 2.7.13
git: git version 2.11.0
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.20.0
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.0-pre1-5304-gc20f7ed38
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
Last edit: 6 years 9 months ago by DC67.
6 years 9 months ago #154543 by andypugh
Interesting. Does your INI file have an [EMC] section?
(I wrote the update_Ini script, and it looks like you have found a bug in it)
Can you attach the current INI and also the oldest one in the "old" directory of the same config directory?
Time to create page: 0.188 seconds
