Linuxcnc always wants to update my INI file
6 years 9 months ago - 6 years 9 months ago #154597 by DC67
Here are my ini files
File Name: current.ini
File Size:6 KB
this is may the same as current
File Name: old_2020-01-11-2.ini
File Size:6 KB
this is where i upgraded from.I had moved the old folder v2.7 so that it would not be overwritten or deleted.
File Name: 2.7.ini
File Size:3.73 KB
This EMC error started when adding probe/toolsensor to the INI .Before i could start linuxcnc without any message for update.
Last edit: 6 years 9 months ago by DC67.
6 years 9 months ago #154625 by andypugh
Backtracking a bit:
Machine configuration file is 'Fenja.ini' INIFILE=/home/linuxcnc/linuxcnc/configs/Fenja/Fenja.ini VERSION= halfiles = halpaths = update script failed in an unexpected way. Debug file information: Can not find -sec EMC -var VERSION -num 1
How are you starting LinuxCNC? This looks a bit like you are starting LinuxCNC in such a way that it is looking at an INI file called "Fenja.ini" and that is not containing any of the expected sections.
If you pick your "current.ini" from the LinuxCNC config picker, do things work better?
6 years 9 months ago #154637 by DC67
Hi
sorry for confusion.
I changed the ini name so that you can see which version is current and which is older. but all are called fenja.ini in the current system
6 years 9 months ago #154641 by andypugh
I guessed that the file names were changed. (That’s why I put the substitute file name in quotes).
But whatever file is being run, LinuxCNC is not finding a version or any Hal files.
So something odd seems to be going on.
Are you starting LinuxCNC from the config picker or some other way?
6 years 9 months ago #154643 by DC67
I start linuxcnc via a desktop shortcut that starts directly with fenja.ini
6 years 9 months ago #154648 by andypugh
Can you try it the other way?
Time to create page: 0.061 seconds
