Linuxcnc always wants to update my INI file
7 years 3 months ago #140481 by bevins
oops, I meant Tommy
7 years 3 months ago #140486 by JetForMe
tommylight wrote: Version should be 1.1
According to the docs : "It’s a good idea to change this number each time you revise your file."
I only bumped it because I was getting the warning before. After bumping it, it went away. Then it came back so I bumped it again.
7 years 3 months ago #140490 by tommylight
I have not yet done much testing on 2.9, but 2.8 requires that to be 1.1
Anything else and it will try to run the wizard to change the version.
The following user(s) said Thank You: JetForMe
7 years 3 months ago #140492 by JetForMe
So, it sounds like the documentation is incorrect, then.
7 years 3 months ago #140512 by Clive S
JetForMe wrote: So, it sounds like the documentation is incorrect, then.
The docs were probably written before the configuration tools were made
7 years 3 months ago #140525 by Todd Zuercher
Yes, the docs are incorrect, and should be updated.
Time to create page: 0.133 seconds
