What input should I use for a probe fault.
6 years 3 months ago #174042 by oldtech
I'm building an experimental probe that will have the ability to fault if too much force is applied to it. So I need a way to halt motion when this occurs in order to limit damage to the probe. Any suggestions?
6 years 3 months ago #174065 by tommylight
What type of output will it have for overload ? Analogue or digital?
Digital is easy to do in hal, analogue would require some type of Mesa or analogue to digital converter.
6 years 3 months ago #174078 by rodw
If you connect your probe to motion.probe−input , it will halt motion when its triggered. If you want to measure force, thats a different kettle of fish!
RodW
6 years 3 months ago #174105 by oldtech
Thanks. I should have added more details. I'm using Linux Mint with a Mesa 5i25/7i76 and I'm still the process of building out my control box and adding new features. I should also add that I'm connecting to a cnc router (a Millrightcnc Power Route). I'm retired with a background in system and application software mostly on Windows.
The probe will only have analog inputs and outputs. Yes, I know that the probe will stop on contact but since there is always some overshoot I'm adding an internal limit signal. If successful, I'm planning on mounting the probe to a sub-z-axis so that it is always available and does not require a tool change.
So it sounds like I simply need to connect the internal limit signal to a custom analog input and then connect that pin to E-Stop.
I should emphasize that the probe is very much in a conceptual state with a goal to have an accuracy of 0.01mm.
6 years 3 months ago - 6 years 3 months ago #174141 by rodw
A couple of problems.
Linuxcnc does not really have a method to receive an analog input. If the the 7i76 is like the 7i76e there is a mode to enable some analog voltage inputs but its not particularly accurate.
With Plasma machines we use the encoder input with a bit file that converts the mesa encoder input into 3 x Encoder A inputs which then support 3 x THCAD voltage to frequency boards that is decoded from the encoder count back to a voltage. But you need the encoder for your spindle. You might be able to use the software encoder component.
Estop will need a bit output pin not a float. You might like to look at the sourcecode for the ohmic component in master branch for inspiration.
linuxcnc.org/docs/devel/html/man/man9/ohmic.9.html
It might work for you as is. Its purpose is to take a voltage from a THCAD and generate a probe output with hysteresis.
RodW
Last edit: 6 years 3 months ago by rodw.
The following user(s) said Thank You: oldtech
6 years 3 months ago #174142 by tommylight
Time to create page: 0.076 seconds
