Hmm ... now i have to ask why?oldtech wrote: In any case, it looks like I will need an analog to digital chip for connecting to E-STOP from the probe.
Use the analogue input on the 7i76, set it in hal as you need and use an output or trigger the e-stop from hal.
No need for any electronics.
All field input pins are capable of reading the input voltage. These are not highly
accurate or high resolution but can be useful for things like potentiometer inputs. Input
resolution is 8 bits and input full scale value is 36.3V. Accuracy is +-5%. Software process
data modes 1 and 2 allow reading the analog voltage on inputs 0 through 3,
