What input should I use for a probe fault.
6 years 3 months ago #174145 by oldtech
The 7i76 has 8 analog inputs and I'm successfully using 3 for limit/home switches.
6 years 3 months ago #174148 by tommylight
oldtech wrote: The 7i76 has 8 analog inputs and I'm successfully using 3 for limit/home switches.
7i76 should have 4 analogue inputs when set to mode 2, not 8, but in any case double check that.
The following user(s) said Thank You: oldtech
6 years 3 months ago #174149 by tommylight
That reminds me, you should have mentioned you have an 7i76 in the first post, wasted 10 minutes looking where did i put those LM331 chips as i have 3 of them in a box waiting for some quality time ..... :)
6 years 3 months ago #174150 by rodw
Yes, you need to change modes to use as analog inputs. If you don't they are normal digital inputs. I use them for home/limits too.
6 years 3 months ago #174151 by oldtech
Sorry, I will include a background in new questions. In any case, it looks like I will need an analog to digital chip for connecting to E-STOP from the probe.
6 years 3 months ago #174152 by rodw
oldtech wrote: Sorry, I will include a background in new questions. In any case, it looks like I will need an analog to digital chip for connecting to E-STOP from the probe.
Yes, you probably don't need to use a THCAD as you do not need isolation from the noise of the plasma environment. Tommy's chip should work nice. But you still need an encoder input.. There is not really any other way to do it.
Time to create page: 0.056 seconds
