Z axis cuts in the air - not plunging
  • Jeff65
  • Jeff65's Avatar Topic Author
  • Junior Member
  • Junior Member
05 Sep 2020 10:58 #180800 by Jeff65
Hi - I am new to this forum so a big Hello to everyone.
I have a very small cnc - a Proxxon mf70 with a Gecko G540 controller.
one switch on each axis - positioned at the motor end of each way. After many frustrating hours of trying to get everything to work - I have finally managed to Home all axis and the axis all jog correctly.
On my 1st try at cutting something - the Z axis does not plunge but goes upward and starts to cut in mid air - so something is reversed somewhere and I can't quite work it out.
Any help greatly appreciated.
05 Sep 2020 11:08 #180802 by Mike_Eitel
Replied by Mike_Eitel on topic Z axis cuts in the air - not plunging
Normal z axis is zero when high=max and goes to - values=min.
Check how your g-code generator sees his "world". What is the value for top and what for low of the part?
Mike
  • Jeff65
  • Junior Member
  • Junior Member
05 Sep 2020 16:43 #180810 by Jeff65
Replied by Jeff65 on topic Z axis cuts in the air - not plunging
Hi Mike
Thanks for responding - yes I thought that max was zero and is -65mm at the min.
The black screen in Linuxcnc, however, (sorry if I don't quite know the terminology) has x y and z at the top and Z is showing -65mm at the top and - 0.001 at the bottom.
I guess this is not quite right.
Regards
05 Sep 2020 17:00 #180811 by Clive S
Replied by Clive S on topic Z axis cuts in the air - not plunging
Hi Mike
Regards
Where are you touching off in Z ie on the top or bottom off the part or top off stock etc
What software are you suing to generated the code
It would help for you to post your config files ie. you_machine .ini and .hal
And also the gcode you are using.
  • Jeff65
  • Junior Member
  • Junior Member
05 Sep 2020 17:24 #180814 by Jeff65
Hi Mike
Touching off was done to the bottom of the Z axis to the top of a 5mm piece of wood - I zeroed it there.
INI file - Hal and gcode below
# Generated by stepconf 1.1 at Sun Aug 30 18:04:07 2020
# overwritten when you run stepconf again
[EMC]
MACHINE = my-mill
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 5.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 20.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/jeff65/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 37851
SERVO_PERIOD = 1000000
[HAL]
HALFILE = my-mill.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.00
MAX_VELOCITY = 20.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 5
MAX_VELOCITY = 12.5492060976
MAX_ACCELERATION = 13.0
STEPGEN_MAXACCEL = 16.25
SCALE = -2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0
MAX_LIMIT = 168
HOME_USE_INDEX = NO
HOME_OFFSET = 3
HOME_SEARCH_VEL = 1.000000
HOME_LATCH_VEL = 0.050000
HOME_FINAL_VEL = 2
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = 5
SCALE = -2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0
MAX_LIMIT = 79
HOME_USE_INDEX = NO
HOME_OFFSET = 3
HOME_FINAL_VEL = 2
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = 0
SCALE = 2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -75
MAX_LIMIT = 0.001
HOME_OFFSET = -64
OME_FINAL_VEL = 2
HOME_SEQUENCE = 0
HAL
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 1500
loadrt stepgen step_type=0,0,0
loadrt charge_pump
net estop-out charge-pump.enable iocontrol.0.user-enable-out
net charge-pump <= charge-pump.out
addf charge-pump base-thread
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net spindle-cw <= motion.spindle-forward
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net astep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net adir => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net charge-pump => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
net all-home <= parport.0.pin-10-in
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 29551
setp stepgen.0.dirsetup 29551
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net all-home => axis.0.home-sw-in
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 29551
setp stepgen.1.dirsetup 29551
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
net all-home => axis.1.home-sw-in
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 29551
setp stepgen.2.dirsetup 29551
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net all-home => axis.2.home-sw-in
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
GCODE
G21 ; Set units to mm
G90 ; Absolute positioning
G1 Z1.9999999999999998 F750 ; Move to clearance level
; Operation: 0
; Name:
; Type: Pocket
; Paths: 7
; Direction: Conventional
; Cut Depth: 1.25
; Pass Depth: 1.25
; Plunge rate: 50
; Cut rate: 300
; Path 0
; Rapid to initial position
G1 X20.1486 Y4.7544 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X20.1666 Y4.7234 F300
G1 X20.1262 Y4.6487
G1 X20.1033 Y4.6942
G1 X20.0858 Y4.7241
G1 X20.0866 Y4.7252
G1 X20.1262 Y4.7988
G1 X20.1486 Y4.7544
G1 X20.3218 Y4.8544
G1 X20.3482 Y4.8087
G1 X20.3919 Y4.7407
G1 X20.4043 Y4.7231
G1 X20.3672 Y4.6693
G1 X20.3424 Y4.6279
G1 X20.3045 Y4.5583
G1 X20.2829 Y4.5136
G1 X20.2499 Y4.4348
G1 X20.2344 Y4.3914
G1 X20.2113 Y4.3170
G1 X20.1986 Y4.2667
G1 X20.1816 Y4.1819
G1 X20.1742 Y4.1275
G1 X20.1658 Y4.0231
G1 X20.1648 Y3.9723
G1 X20.1648 Y0.9926
G1 X20.0884 Y0.9926
G1 X20.0873 Y4.0150
G1 X20.0823 Y4.0980
G1 X20.0767 Y4.1448
G1 X20.0632 Y4.2276
G1 X20.0523 Y4.2751
G1 X20.0320 Y4.3513
G1 X20.0165 Y4.3983
G1 X19.9850 Y4.4808
G1 X19.9672 Y4.5197
G1 X19.9301 Y4.5941
G1 X19.9037 Y4.6398
G1 X19.8600 Y4.7079
G1 X19.8481 Y4.7244
G1 X19.8859 Y4.7793
G1 X19.9108 Y4.8207
G1 X19.9487 Y4.8903
G1 X19.9702 Y4.9350
G1 X20.0033 Y5.0137
G1 X20.0188 Y5.0571
G1 X20.0419 Y5.1316
G1 X20.0546 Y5.1819
G1 X20.0716 Y5.2667
G1 X20.0790 Y5.3210
G1 X20.0873 Y5.4254
G1 X20.0884 Y5.4762
G1 X20.0881 Y6.6162
G1 X20.0891 Y6.6901
G1 X20.0894 Y6.6972
G1 X20.0924 Y6.7841
G1 X20.0995 Y6.8897
G1 X20.1056 Y6.9472
G1 X20.1165 Y7.0190
G1 X20.1270 Y7.0709
G1 X20.1437 Y7.1333
G1 X20.1564 Y7.1704
G1 X20.1795 Y7.2271
G1 X20.2001 Y7.2680
G1 X20.2245 Y7.3091
G1 X20.2593 Y7.3589
G1 X20.2669 Y7.3680
G1 X20.2334 Y7.2372
G1 X20.2161 Y7.1506
G1 X20.1902 Y6.9830
G1 X20.1828 Y6.9144
G1 X20.1686 Y6.7213
G1 X20.1643 Y6.5656
G1 X20.1635 Y6.4483
G1 X20.1646 Y5.4336
G1 X20.1696 Y5.3505
G1 X20.1752 Y5.3038
G1 X20.1887 Y5.2210
G1 X20.1996 Y5.1735
G1 X20.2199 Y5.0973
G1 X20.2354 Y5.0503
G1 X20.2669 Y4.9677
G1 X20.2847 Y4.9289
G1 X20.3218 Y4.8544
G1 X20.4958 Y4.9533
G1 X20.5169 Y4.9162
G1 X20.5547 Y4.8567
G1 X20.5760 Y4.8268
G1 X20.6218 Y4.7681
G1 X20.6469 Y4.7396
G1 X20.6619 Y4.7239
G1 X20.6494 Y4.7107
G1 X20.6024 Y4.6553
G1 X20.5796 Y4.6251
G1 X20.5384 Y4.5659
G1 X20.5176 Y4.5314
G1 X20.4843 Y4.4709
G1 X20.4671 Y4.4353
G1 X20.4381 Y4.3673
G1 X20.4252 Y4.3312
G1 X20.4048 Y4.2669
G1 X20.3944 Y4.2266
G1 X20.3797 Y4.1544
G1 X20.3736 Y4.1105
G1 X20.3657 Y4.0188
G1 X20.3647 Y3.9723
G1 X20.3647 Y0.7927
G1 X19.8885 Y0.7927
G1 X19.8877 Y4.0035
G1 X19.8836 Y4.0747
G1 X19.8791 Y4.1135
G1 X19.8679 Y4.1841
G1 X19.8590 Y4.2240
G1 X19.8417 Y4.2896
G1 X19.8293 Y4.3279
G1 X19.8029 Y4.3983
G1 X19.7881 Y4.4308
G1 X19.7561 Y4.4953
G1 X19.7350 Y4.5324
G1 X19.6972 Y4.5918
G1 X19.6759 Y4.6218
G1 X19.6301 Y4.6805
G1 X19.6050 Y4.7089
G1 X19.5908 Y4.7239
G1 X19.6037 Y4.7379
G1 X19.6507 Y4.7932
G1 X19.6736 Y4.8235
G1 X19.7147 Y4.8826
G1 X19.7355 Y4.9172
G1 X19.7688 Y4.9776
G1 X19.7861 Y5.0132
G1 X19.8150 Y5.0813
G1 X19.8280 Y5.1173
G1 X19.8483 Y5.1816
G1 X19.8587 Y5.2220
G1 X19.8735 Y5.2941
G1 X19.8796 Y5.3381
G1 X19.8874 Y5.4298
G1 X19.8885 Y5.4762
G1 X19.8882 Y6.6187
G1 X19.8892 Y6.6972
G1 X19.8895 Y6.7043
G1 X19.8928 Y6.7975
G1 X19.8999 Y6.9032
G1 X19.9078 Y6.9771
G1 X19.9192 Y7.0526
G1 X19.9321 Y7.1166
G1 X19.9517 Y7.1897
G1 X19.9700 Y7.2433
G1 X19.9967 Y7.3083
G1 X20.0243 Y7.3640
G1 X20.0571 Y7.4188
G1 X20.0988 Y7.4785
G1 X20.1478 Y7.5385
G1 X20.2093 Y7.6035
G1 X20.2824 Y7.6705
G1 X20.3799 Y7.7480
G1 X20.4366 Y7.7884
G1 X20.5008 Y7.8298
G1 X20.5837 Y7.8778
G1 X20.6489 Y7.9124
G1 X20.7338 Y7.9520
G1 X20.7576 Y7.9619
G1 X20.7188 Y7.9022
G1 X20.6278 Y7.7490
G1 X20.5864 Y7.6675
G1 X20.5679 Y7.6243
G1 X20.5014 Y7.4554
G1 X20.4716 Y7.3612
G1 X20.4295 Y7.1973
G1 X20.4137 Y7.1201
G1 X20.3891 Y6.9609
G1 X20.3822 Y6.8994
G1 X20.3685 Y6.7158
G1 X20.3642 Y6.5644
G1 X20.3634 Y6.4486
G1 X20.3642 Y5.4450
G1 X20.3683 Y5.3739
G1 X20.3728 Y5.3350
G1 X20.3840 Y5.2644
G1 X20.3929 Y5.2245
G1 X20.4102 Y5.1590
G1 X20.4226 Y5.1206
G1 X20.4490 Y5.0503
G1 X20.4638 Y5.0178
G1 X20.4958 Y4.9533
G1 X20.6700 Y5.0513
G1 X20.6860 Y5.0228
G1 X20.7180 Y4.9720
G1 X20.7345 Y4.9487
G1 X20.7719 Y4.9002
G1 X20.7922 Y4.8771
G1 X20.8331 Y4.8339
G1 X20.8552 Y4.8130
G1 X20.9017 Y4.7732
G1 X20.9253 Y4.7551
G1 X20.9702 Y4.7236
G1 X20.9603 Y4.7175
G1 X20.9370 Y4.7010
G1 X20.8885 Y4.6637
G1 X20.8653 Y4.6434
G1 X20.8222 Y4.6025
G1 X20.8013 Y4.5804
G1 X20.7615 Y4.5339
G1 X20.7434 Y4.5103
G1 X20.7089 Y4.4610
G1 X20.6926 Y4.4346
G1 X20.6637 Y4.3823
G1 X20.6507 Y4.3561
G1 X20.6261 Y4.2989
G1 X20.6157 Y4.2702
G1 X20.5981 Y4.2154
G1 X20.5903 Y4.1859
G1 X20.5776 Y4.1247
G1 X20.5727 Y4.0924
G1 X20.5656 Y4.0140
G1 X20.5646 Y3.9723
G1 X20.5646 Y0.5928
G1 X19.6886 Y0.5928
G1 X19.6880 Y3.9926
G1 X19.6847 Y4.0528
G1 X19.6814 Y4.0830
G1 X19.6723 Y4.1422
G1 X19.6657 Y4.1730
G1 X19.6507 Y4.2299
G1 X19.6418 Y4.2583
G1 X19.6202 Y4.3165
G1 X19.6083 Y4.3431
G1 X19.5819 Y4.3972
G1 X19.5659 Y4.4257
G1 X19.5339 Y4.4765
G1 X19.5174 Y4.4999
G1 X19.4800 Y4.5484
G1 X19.4597 Y4.5715
G1 X19.4188 Y4.6147
G1 X19.3967 Y4.6355
G1 X19.3502 Y4.6754
G1 X19.3266 Y4.6934
G1 X19.2824 Y4.7244
G1 X19.2928 Y4.7310
G1 X19.3162 Y4.7475
G1 X19.3647 Y4.7849
G1 X19.3878 Y4.8052
G1 X19.4310 Y4.8461
G1 X19.4518 Y4.8682
G1 X19.4917 Y4.9146
G1 X19.5097 Y4.9383
G1 X19.5443 Y4.9875
G1 X19.5605 Y5.0140
G1 X19.5895 Y5.0663
G1 X19.6025 Y5.0924
G1 X19.6271 Y5.1496
G1 X19.6375 Y5.1783
G1 X19.6550 Y5.2332
G1 X19.6629 Y5.2626
G1 X19.6756 Y5.3238
G1 X19.6804 Y5.3561
G1 X19.6875 Y5.4346
G1 X19.6886 Y5.4762
G1 X19.6886 Y6.6172
G1 X19.6883 Y6.6213
G1 X19.6893 Y6.7038
G1 X19.6896 Y6.7114
G1 X19.6931 Y6.8110
G1 X19.7002 Y6.9167
G1 X19.7099 Y7.0071
G1 X19.7213 Y7.0825
G1 X19.7388 Y7.1684
G1 X19.7597 Y7.2461
G1 X19.7825 Y7.3137
G1 X19.8138 Y7.3899
G1 X19.8478 Y7.4582
G1 X19.8905 Y7.5298
G1 X19.9370 Y7.5964
G1 X19.9984 Y7.6718
G1 X20.0685 Y7.7457
G1 X20.1544 Y7.8242
G1 X20.2585 Y7.9073
G1 X20.3233 Y7.9532
G1 X20.3967 Y8.0005
G1 X20.4869 Y8.0528
G1 X20.5623 Y8.0927
G1 X20.6538 Y8.1354
G1 X20.7480 Y8.1747
G1 X20.8514 Y8.2126
G1 X20.9535 Y8.2453
G1 X21.0607 Y8.2748
G1 X21.1907 Y8.3053
G1 X21.3154 Y8.3297
G1 X21.4391 Y8.3487
G1 X21.5212 Y8.3586
G1 X21.4434 Y8.3182
G1 X21.3848 Y8.2837
G1 X21.3045 Y8.2311
G1 X21.2413 Y8.1846
G1 X21.1767 Y8.1316
G1 X21.1168 Y8.0759
G1 X21.0894 Y8.0467
G1 X20.9771 Y7.9202
G1 X20.9400 Y7.8735
G1 X20.9248 Y7.8519
G1 X20.8905 Y7.7998
G1 X20.8059 Y7.6578
G1 X20.7701 Y7.5880
G1 X20.7538 Y7.5504
G1 X20.6919 Y7.3944
G1 X20.6652 Y7.3111
G1 X20.6253 Y7.1570
G1 X20.6113 Y7.0891
G1 X20.5877 Y6.9383
G1 X20.5816 Y6.8844
G1 X20.5684 Y6.7099
G1 X20.5641 Y6.5631
G1 X20.5633 Y6.4486
G1 X20.5638 Y5.4559
G1 X20.5671 Y5.3957
G1 X20.5704 Y5.3655
G1 X20.5796 Y5.3063
G1 X20.5862 Y5.2756
G1 X20.6012 Y5.2187
G1 X20.6101 Y5.1902
G1 X20.6317 Y5.1321
G1 X20.6436 Y5.1054
G1 X20.6700 Y5.0513
G1 X20.8455 Y5.1473
G1 X20.8557 Y5.1288
G1 X20.8824 Y5.0861
G1 X20.8933 Y5.0703
G1 X20.9240 Y5.0302
G1 X20.9375 Y5.0145
G1 X20.9720 Y4.9779
G1 X20.9862 Y4.9642
G1 X21.0243 Y4.9312
G1 X21.0403 Y4.9187
G1 X21.0815 Y4.8898
G1 X21.0988 Y4.8788
G1 X21.1427 Y4.8542
G1 X21.1600 Y4.8456
G1 X21.2062 Y4.8252
G1 X21.2260 Y4.8179
G1 X21.2738 Y4.8026
G1 X21.2921 Y4.7976
G1 X21.3413 Y4.7869
G1 X21.3627 Y4.7836
G1 X21.4272 Y4.7772
G1 X21.4633 Y4.7762
G1 X22.8811 Y4.7762
G1 X22.8811 Y4.6723
G1 X21.4544 Y4.6721
G1 X21.4041 Y4.6695
G1 X21.3840 Y4.6675
G1 X21.3342 Y4.6599
G1 X21.3142 Y4.6558
G1 X21.2654 Y4.6431
G1 X21.2471 Y4.6375
G1 X21.1999 Y4.6203
G1 X21.1811 Y4.6121
G1 X21.1356 Y4.5900
G1 X21.1171 Y4.5799
G1 X21.0744 Y4.5532
G1 X21.0586 Y4.5423
G1 X21.0185 Y4.5115
G1 X21.0028 Y4.4981
G1 X20.9662 Y4.4635
G1 X20.9525 Y4.4493
G1 X20.9194 Y4.4112
G1 X20.9070 Y4.3952
G1 X20.8780 Y4.3541
G1 X20.8671 Y4.3368
G1 X20.8425 Y4.2929
G1 X20.8338 Y4.2756
G1 X20.8135 Y4.2294
G1 X20.8062 Y4.2095
G1 X20.7909 Y4.1618
G1 X20.7858 Y4.1435
G1 X20.7752 Y4.0942
G1 X20.7719 Y4.0729
G1 X20.7655 Y4.0084
G1 X20.7645 Y3.9723
G1 X20.7645 Y0.3929
G1 X19.4887 Y0.3929
G1 X19.4884 Y3.9825
G1 X19.4859 Y4.0328
G1 X19.4838 Y4.0528
G1 X19.4762 Y4.1026
G1 X19.4721 Y4.1227
G1 X19.4594 Y4.1714
G1 X19.4539 Y4.1897
G1 X19.4366 Y4.2370
G1 X19.4285 Y4.2558
G1 X19.4064 Y4.3012
G1 X19.3962 Y4.3198
G1 X19.3695 Y4.3624
G1 X19.3586 Y4.3782
G1 X19.3279 Y4.4183
G1 X19.3144 Y4.4341
G1 X19.2799 Y4.4707
G1 X19.2656 Y4.4844
G1 X19.2275 Y4.5174
G1 X19.2115 Y4.5298
G1 X19.1704 Y4.5588
G1 X19.1531 Y4.5697
G1 X19.1092 Y4.5944
G1 X19.0919 Y4.6030
G1 X19.0457 Y4.6233
G1 X19.0259 Y4.6307
G1 X18.9781 Y4.6459
G1 X18.9598 Y4.6510
G1 X18.9106 Y4.6617
G1 X18.8892 Y4.6650
G1 X18.8247 Y4.6713
G1 X18.7886 Y4.6723
G1 X18.5227 Y4.6723
G1 X18.5227 Y4.7762
G1 X18.7988 Y4.7765
G1 X18.8491 Y4.7790
G1 X18.8692 Y4.7810
G1 X18.9189 Y4.7887
G1 X18.9390 Y4.7927
G1 X18.9878 Y4.8054
G1 X19.0061 Y4.8110
G1 X19.0533 Y4.8283
G1 X19.0721 Y4.8364
G1 X19.1176 Y4.8585
G1 X19.1361 Y4.8687
G1 X19.1788 Y4.8953
G1 X19.1945 Y4.9063
G1 X19.2347 Y4.9370
G1 X19.2504 Y4.9505
G1 X19.2870 Y4.9850
G1 X19.3007 Y4.9992
G1 X19.3337 Y5.0373
G1 X19.3462 Y5.0533
G1 X19.3751 Y5.0945
G1 X19.3860 Y5.1117
G1 X19.4107 Y5.1557
G1 X19.4193 Y5.1730
G1 X19.4396 Y5.2192
G1 X19.4470 Y5.2390
G1 X19.4622 Y5.2868
G1 X19.4673 Y5.3050
G1 X19.4780 Y5.3543
G1 X19.4813 Y5.3757
G1 X19.4876 Y5.4402
G1 X19.4887 Y5.4762
G1 X19.4887 Y6.6172
G1 X19.4884 Y6.6197
G1 X19.4894 Y6.7130
G1 X19.4897 Y6.7186
G1 X19.4935 Y6.8245
G1 X19.5006 Y6.9301
G1 X19.5113 Y7.0310
G1 X19.5252 Y7.1224
G1 X19.5435 Y7.2123
G1 X19.5679 Y7.3033
G1 X19.5946 Y7.3828
G1 X19.6309 Y7.4714
G1 X19.6726 Y7.5550
G1 X19.7211 Y7.6365
G1 X19.7775 Y7.7175
G1 X19.8478 Y7.8036
G1 X19.9278 Y7.8880
G1 X20.0261 Y7.9779
G1 X20.1351 Y8.0648
G1 X20.2128 Y8.1199
G1 X20.2961 Y8.1735
G1 X20.3896 Y8.2278
G1 X20.4716 Y8.2710
G1 X20.5743 Y8.3190
G1 X20.6743 Y8.3607
G1 X20.7863 Y8.4018
G1 X20.8951 Y8.4366
G1 X21.0149 Y8.4696
G1 X21.1460 Y8.5004
G1 X21.2806 Y8.5265
G1 X21.4130 Y8.5471
G1 X21.5646 Y8.5651
G1 X21.7195 Y8.5778
G1 X21.8735 Y8.5855
G1 X22.0396 Y8.5880
G1 X22.2336 Y8.5849
G1 X22.4125 Y8.5758
G1 X22.5974 Y8.5606
G1 X22.7681 Y8.5402
G1 X22.8636 Y8.5255
G1 X22.8636 Y8.3614
G1 X22.7269 Y8.3739
G1 X22.6929 Y8.3759
G1 X22.5582 Y8.3802
G1 X22.5135 Y8.3802
G1 X22.3586 Y8.3739
G1 X22.3111 Y8.3698
G1 X22.1706 Y8.3525
G1 X22.1204 Y8.3442
G1 X21.9936 Y8.3175
G1 X21.9443 Y8.3048
G1 X21.8316 Y8.2710
G1 X21.7790 Y8.2527
G1 X21.6799 Y8.2126
G1 X21.6306 Y8.1900
G1 X21.5445 Y8.1455
G1 X21.4937 Y8.1158
G1 X21.4221 Y8.0693
G1 X21.3680 Y8.0300
G1 X21.3116 Y7.9837
G1 X21.2626 Y7.9390
G1 X21.2387 Y7.9136
G1 X21.1333 Y7.7953
G1 X21.1018 Y7.7559
G1 X21.0917 Y7.7419
G1 X21.0622 Y7.6972
G1 X20.9834 Y7.5656
G1 X20.9535 Y7.5080
G1 X20.9395 Y7.4760
G1 X20.8821 Y7.3327
G1 X20.8587 Y7.2608
G1 X20.8211 Y7.1158
G1 X20.8090 Y7.0579
G1 X20.7863 Y6.9154
G1 X20.7810 Y6.8692
G1 X20.7683 Y6.7038
G1 X20.7640 Y6.5618
G1 X20.7632 Y6.4486
G1 X20.7635 Y5.4661
G1 X20.7660 Y5.4158
G1 X20.7681 Y5.3957
G1 X20.7757 Y5.3459
G1 X20.7797 Y5.3259
G1 X20.7924 Y5.2771
G1 X20.7980 Y5.2588
G1 X20.8153 Y5.2116
G1 X20.8234 Y5.1928
G1 X20.8455 Y5.1473
G1 X21.0254 Y5.2347
G1 X21.0520 Y5.1920
G1 X21.0828 Y5.1519
G1 X21.1173 Y5.1153
G1 X21.1554 Y5.0823
G1 X21.1966 Y5.0533
G1 X21.2405 Y5.0287
G1 X21.2867 Y5.0084
G1 X21.3345 Y4.9931
G1 X21.3838 Y4.9825
G1 X21.4340 Y4.9771
G1 X21.4633 Y4.9761
G1 X23.0810 Y4.9761
G1 X23.0810 Y4.4724
G1 X21.4645 Y4.4724
G1 X21.4142 Y4.4699
G1 X21.3644 Y4.4623
G1 X21.3157 Y4.4496
G1 X21.2684 Y4.4323
G1 X21.2230 Y4.4102
G1 X21.1803 Y4.3835
G1 X21.1402 Y4.3528
G1 X21.1036 Y4.3183
G1 X21.0706 Y4.2802
G1 X21.0416 Y4.2390
G1 X21.0170 Y4.1951
G1 X20.9967 Y4.1488
G1 X20.9814 Y4.1011
G1 X20.9707 Y4.0518
G1 X20.9654 Y4.0015
G1 X20.9644 Y3.9723
G1 X20.9644 Y0.1930
G1 X19.2888 Y0.1930
G1 X19.2888 Y3.9723
G1 X19.2862 Y4.0226
G1 X19.2786 Y4.0724
G1 X19.2659 Y4.1211
G1 X19.2486 Y4.1684
G1 X19.2265 Y4.2139
G1 X19.1999 Y4.2565
G1 X19.1691 Y4.2967
G1 X19.1346 Y4.3332
G1 X19.0965 Y4.3663
G1 X19.0553 Y4.3952
G1 X19.0114 Y4.4199
G1 X18.9652 Y4.4402
G1 X18.9174 Y4.4554
G1 X18.8681 Y4.4661
G1 X18.8178 Y4.4714
G1 X18.7886 Y4.4724
G1 X18.3228 Y4.4724
G1 X18.3228 Y4.9761
G1 X18.7886 Y4.9761
G1 X18.8389 Y4.9787
G1 X18.8887 Y4.9863
G1 X18.9375 Y4.9990
G1 X18.9847 Y5.0162
G1 X19.0302 Y5.0383
G1 X19.0729 Y5.0650
G1 X19.1130 Y5.0957
G1 X19.1496 Y5.1303
G1 X19.1826 Y5.1684
G1 X19.2115 Y5.2095
G1 X19.2362 Y5.2535
G1 X19.2565 Y5.2997
G1 X19.2717 Y5.3475
G1 X19.2824 Y5.3967
G1 X19.2877 Y5.4470
G1 X19.2888 Y5.4762
G1 X19.2888 Y6.6172
G1 X19.2885 Y6.6172
G1 X19.2895 Y6.7213
G1 X19.2898 Y6.7257
G1 X19.2938 Y6.8379
G1 X19.3010 Y6.9436
G1 X19.3126 Y7.0551
G1 X19.3284 Y7.1585
G1 X19.3492 Y7.2598
G1 X19.3756 Y7.3589
G1 X19.4081 Y7.4557
G1 X19.4480 Y7.5529
G1 X19.4965 Y7.6502
G1 X19.5527 Y7.7447
G1 X19.6182 Y7.8387
G1 X19.6972 Y7.9355
G1 X19.7889 Y8.0320
G1 X19.8943 Y8.1285
G1 X20.0162 Y8.2255
G1 X20.1021 Y8.2865
G1 X20.1915 Y8.3442
G1 X20.2903 Y8.4016
G1 X20.3832 Y8.4503
G1 X20.4927 Y8.5016
G1 X20.6009 Y8.5466
G1 X20.7234 Y8.5915
G1 X20.8366 Y8.6279
G1 X20.9692 Y8.6644
G1 X21.1016 Y8.6954
G1 X21.2458 Y8.7234
G1 X21.3876 Y8.7455
G1 X21.5443 Y8.7643
G1 X21.7033 Y8.7772
G1 X21.8679 Y8.7854
G1 X22.0396 Y8.7879
G1 X22.2397 Y8.7848
G1 X22.4290 Y8.7752
G1 X22.6162 Y8.7597
G1 X22.7927 Y8.7386
G1 X22.9613 Y8.7127
G1 X23.0635 Y8.6939
G1 X23.0635 Y8.1285
G1 X23.0063 Y8.1397
G1 X22.8732 Y8.1592
G1 X22.8458 Y8.1623
G1 X22.7145 Y8.1742
G1 X22.6860 Y8.1760
G1 X22.5582 Y8.1803
G1 X22.5214 Y8.1803
G1 X22.3751 Y8.1745
G1 X22.3352 Y8.1712
G1 X22.2029 Y8.1552
G1 X22.1610 Y8.1483
G1 X22.0426 Y8.1237
G1 X22.0015 Y8.1133
G1 X21.8968 Y8.0820
G1 X21.8534 Y8.0670
G1 X21.7630 Y8.0307
G1 X21.7218 Y8.0119
G1 X21.6449 Y7.9726
G1 X21.6019 Y7.9477
G1 X21.5392 Y7.9073
G1 X21.4942 Y7.8748
G1 X21.4452 Y7.8349
G1 X21.4076 Y7.8011
G1 X21.3878 Y7.7803
G1 X21.2895 Y7.6703
G1 X21.2580 Y7.6309
G1 X21.2336 Y7.5943
G1 X21.1600 Y7.4717
G1 X21.1364 Y7.4272
G1 X21.1249 Y7.4013
G1 X21.0721 Y7.2702
G1 X21.0523 Y7.2100
G1 X21.0167 Y7.0744
G1 X21.0066 Y7.0264
G1 X20.9850 Y6.8910
G1 X20.9804 Y6.8537
G1 X20.9682 Y6.6975
G1 X20.9639 Y6.5606
G1 X20.9631 Y6.4486
G1 X20.9631 Y5.4762
G1 X20.9657 Y5.4259
G1 X20.9733 Y5.3762
G1 X20.9860 Y5.3274
G1 X21.0033 Y5.2802
G1 X21.0254 Y5.2347
; Retract
G1 Z2.0000 F750
; Path 1
G1 X24.9552 Y4.9761 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X25.4213 Y4.9761 F300
G1 X25.4716 Y4.9787
G1 X25.5214 Y4.9863
G1 X25.5702 Y4.9990
G1 X25.6174 Y5.0162
G1 X25.6629 Y5.0383
G1 X25.7056 Y5.0650
G1 X25.7457 Y5.0957
G1 X25.7823 Y5.1303
G1 X25.8153 Y5.1684
G1 X25.8442 Y5.2095
G1 X25.8689 Y5.2535
G1 X25.8892 Y5.2997
G1 X25.9044 Y5.3475
G1 X25.9151 Y5.3967
G1 X25.9204 Y5.4470
G1 X25.9215 Y5.4762
G1 X25.9215 Y6.6172
G1 X25.9212 Y6.6172
G1 X25.9225 Y6.7277
G1 X25.9263 Y6.8374
G1 X25.9334 Y6.9466
G1 X25.9451 Y7.0546
G1 X25.9606 Y7.1567
G1 X25.9809 Y7.2560
G1 X26.0091 Y7.3614
G1 X26.0411 Y7.4569
G1 X26.0805 Y7.5527
G1 X26.1290 Y7.6502
G1 X26.1851 Y7.7447
G1 X26.2512 Y7.8392
G1 X26.3307 Y7.9365
G1 X26.4201 Y8.0307
G1 X26.5267 Y8.1285
G1 X26.6487 Y8.2255
G1 X26.7345 Y8.2865
G1 X26.8239 Y8.3442
G1 X26.9227 Y8.4016
G1 X27.0154 Y8.4501
G1 X27.1267 Y8.5021
G1 X27.2326 Y8.5463
G1 X27.3558 Y8.5915
G1 X27.4691 Y8.6279
G1 X27.6017 Y8.6644
G1 X27.7340 Y8.6954
G1 X27.8785 Y8.7234
G1 X28.0200 Y8.7455
G1 X28.1767 Y8.7640
G1 X28.3360 Y8.7772
G1 X28.5006 Y8.7854
G1 X28.6720 Y8.7879
G1 X28.8722 Y8.7848
G1 X29.0617 Y8.7752
G1 X29.2486 Y8.7597
G1 X29.4251 Y8.7386
G1 X29.5928 Y8.7130
G1 X29.6959 Y8.6937
G1 X29.6959 Y8.1285
G1 X29.6388 Y8.1397
G1 X29.5057 Y8.1592
G1 X29.4782 Y8.1623
G1 X29.3469 Y8.1742
G1 X29.3185 Y8.1760
G1 X29.1907 Y8.1803
G1 X29.1539 Y8.1803
G1 X29.0076 Y8.1745
G1 X28.9677 Y8.1712
G1 X28.8354 Y8.1552
G1 X28.7934 Y8.1483
G1 X28.6751 Y8.1237
G1 X28.6337 Y8.1133
G1 X28.5293 Y8.0820
G1 X28.4866 Y8.0670
G1 X28.3959 Y8.0307
G1 X28.3535 Y8.0114
G1 X28.2768 Y7.9720
G1 X28.2354 Y7.9482
G1 X28.1724 Y7.9078
G1 X28.1267 Y7.8748
G1 X28.0777 Y7.8349
G1 X28.0401 Y7.8011
G1 X28.0200 Y7.7798
G1 X27.9220 Y7.6698
G1 X27.8902 Y7.6304
G1 X27.8668 Y7.5951
G1 X27.7929 Y7.4724
G1 X27.7691 Y7.4280
G1 X27.7574 Y7.4013
G1 X27.7045 Y7.2702
G1 X27.6847 Y7.2100
G1 X27.6492 Y7.0744
G1 X27.6388 Y7.0254
G1 X27.6174 Y6.8900
G1 X27.6134 Y6.8547
G1 X27.6022 Y6.7234
G1 X27.6007 Y6.6975
G1 X27.5963 Y6.5606
G1 X27.5956 Y6.4486
G1 X27.5956 Y5.4762
G1 X27.5981 Y5.4259
G1 X27.6057 Y5.3762
G1 X27.6184 Y5.3274
G1 X27.6357 Y5.2802
G1 X27.6578 Y5.2347
G1 X27.6845 Y5.1920
G1 X27.7152 Y5.1519
G1 X27.7498 Y5.1153
G1 X27.7879 Y5.0823
G1 X27.8290 Y5.0533
G1 X27.8729 Y5.0287
G1 X27.9192 Y5.0084
G1 X27.9669 Y4.9931
G1 X28.0162 Y4.9825
G1 X28.0665 Y4.9771
G1 X28.0957 Y4.9761
G1 X29.7134 Y4.9761
G1 X29.7134 Y4.4724
G1 X28.0970 Y4.4724
G1 X28.0467 Y4.4699
G1 X27.9969 Y4.4623
G1 X27.9481 Y4.4496
G1 X27.9009 Y4.4323
G1 X27.8554 Y4.4102
G1 X27.8127 Y4.3835
G1 X27.7726 Y4.3528
G1 X27.7360 Y4.3183
G1 X27.7030 Y4.2802
G1 X27.6741 Y4.2390
G1 X27.6494 Y4.1951
G1 X27.6291 Y4.1488
G1 X27.6139 Y4.1011
G1 X27.6032 Y4.0518
G1 X27.5979 Y4.0015
G1 X27.5968 Y3.9723
G1 X27.5968 Y0.1930
G1 X25.9215 Y0.1930
G1 X25.9215 Y3.9723
G1 X25.9189 Y4.0226
G1 X25.9113 Y4.0724
G1 X25.8986 Y4.1211
G1 X25.8813 Y4.1684
G1 X25.8592 Y4.2139
G1 X25.8326 Y4.2565
G1 X25.8018 Y4.2967
G1 X25.7673 Y4.3332
G1 X25.7292 Y4.3663
G1 X25.6880 Y4.3952
G1 X25.6441 Y4.4199
G1 X25.5979 Y4.4402
G1 X25.5501 Y4.4554
G1 X25.5008 Y4.4661
G1 X25.4505 Y4.4714
G1 X25.4213 Y4.4724
G1 X24.9552 Y4.4724
G1 X24.9552 Y4.9761
G1 X25.1551 Y4.7762
G1 X25.4315 Y4.7765
G1 X25.4818 Y4.7790
G1 X25.5019 Y4.7810
G1 X25.5516 Y4.7887
G1 X25.5717 Y4.7927
G1 X25.6205 Y4.8054
G1 X25.6388 Y4.8110
G1 X25.6860 Y4.8283
G1 X25.7048 Y4.8364
G1 X25.7503 Y4.8585
G1 X25.7688 Y4.8687
G1 X25.8115 Y4.8953
G1 X25.8272 Y4.9063
G1 X25.8674 Y4.9370
G1 X25.8831 Y4.9505
G1 X25.9197 Y4.9850
G1 X25.9334 Y4.9992
G1 X25.9664 Y5.0373
G1 X25.9789 Y5.0533
G1 X26.0078 Y5.0945
G1 X26.0187 Y5.1117
G1 X26.0434 Y5.1557
G1 X26.0520 Y5.1730
G1 X26.0723 Y5.2192
G1 X26.0797 Y5.2390
G1 X26.0949 Y5.2868
G1 X26.1000 Y5.3050
G1 X26.1107 Y5.3543
G1 X26.1140 Y5.3757
G1 X26.1203 Y5.4402
G1 X26.1214 Y5.4762
G1 X26.1214 Y6.6172
G1 X26.1211 Y6.6197
G1 X26.1224 Y6.7208
G1 X26.1259 Y6.8245
G1 X26.1328 Y6.9301
G1 X26.1440 Y7.0330
G1 X26.1574 Y7.1211
G1 X26.1752 Y7.2083
G1 X26.2006 Y7.3033
G1 X26.2296 Y7.3896
G1 X26.2618 Y7.4684
G1 X26.3050 Y7.5550
G1 X26.3538 Y7.6373
G1 X26.4099 Y7.7173
G1 X26.4813 Y7.8047
G1 X26.5610 Y7.8887
G1 X26.6565 Y7.9761
G1 X26.7675 Y8.0648
G1 X26.8453 Y8.1199
G1 X26.9286 Y8.1735
G1 X27.0200 Y8.2266
G1 X27.1059 Y8.2715
G1 X27.2062 Y8.3185
G1 X27.3091 Y8.3614
G1 X27.4188 Y8.4018
G1 X27.5275 Y8.4366
G1 X27.6474 Y8.4696
G1 X27.7797 Y8.5006
G1 X27.9110 Y8.5260
G1 X28.0472 Y8.5474
G1 X28.1955 Y8.5649
G1 X28.3525 Y8.5778
G1 X28.5062 Y8.5855
G1 X28.6720 Y8.5880
G1 X28.8661 Y8.5849
G1 X29.0452 Y8.5758
G1 X29.2298 Y8.5606
G1 X29.4015 Y8.5400
G1 X29.4960 Y8.5255
G1 X29.4960 Y8.3614
G1 X29.3594 Y8.3739
G1 X29.3253 Y8.3759
G1 X29.1907 Y8.3802
G1 X29.1460 Y8.3802
G1 X28.9911 Y8.3739
G1 X28.9436 Y8.3698
G1 X28.8031 Y8.3525
G1 X28.7528 Y8.3442
G1 X28.6263 Y8.3177
G1 X28.5763 Y8.3048
G1 X28.4630 Y8.2707
G1 X28.4122 Y8.2527
G1 X28.3131 Y8.2128
G1 X28.2621 Y8.1895
G1 X28.1770 Y8.1453
G1 X28.1275 Y8.1166
G1 X28.0553 Y8.0698
G1 X28.0005 Y8.0300
G1 X27.9441 Y7.9837
G1 X27.9065 Y7.9499
G1 X27.8943 Y7.9380
G1 X27.8707 Y7.9129
G1 X27.7663 Y7.7953
G1 X27.7345 Y7.7559
G1 X27.7233 Y7.7409
G1 X27.6957 Y7.6982
G1 X27.6167 Y7.5672
G1 X27.5928 Y7.5227
G1 X27.5859 Y7.5082
G1 X27.5720 Y7.4760
G1 X27.5145 Y7.3327
G1 X27.4912 Y7.2608
G1 X27.4536 Y7.1161
G1 X27.4411 Y7.0566
G1 X27.4188 Y6.9129
G1 X27.4140 Y6.8717
G1 X27.4025 Y6.7351
G1 X27.4008 Y6.7038
G1 X27.3964 Y6.5618
G1 X27.3957 Y6.4486
G1 X27.3959 Y5.4661
G1 X27.3985 Y5.4158
G1 X27.4005 Y5.3957
G1 X27.4081 Y5.3459
G1 X27.4122 Y5.3259
G1 X27.4249 Y5.2771
G1 X27.4305 Y5.2588
G1 X27.4477 Y5.2116
G1 X27.4559 Y5.1928
G1 X27.4780 Y5.1473
G1 X27.4881 Y5.1288
G1 X27.5148 Y5.0861
G1 X27.5257 Y5.0703
G1 X27.5565 Y5.0302
G1 X27.5699 Y5.0145
G1 X27.6045 Y4.9779
G1 X27.6187 Y4.9642
G1 X27.6568 Y4.9312
G1 X27.6728 Y4.9187
G1 X27.7139 Y4.8898
G1 X27.7312 Y4.8788
G1 X27.7752 Y4.8542
G1 X27.7924 Y4.8456
G1 X27.8387 Y4.8252
G1 X27.8585 Y4.8179
G1 X27.9062 Y4.8026
G1 X27.9245 Y4.7976
G1 X27.9738 Y4.7869
G1 X27.9951 Y4.7836
G1 X28.0596 Y4.7772
G1 X28.0957 Y4.7762
G1 X29.5135 Y4.7762
G1 X29.5135 Y4.6723
G1 X28.0868 Y4.6721
G1 X28.0365 Y4.6695
G1 X28.0165 Y4.6675
G1 X27.9667 Y4.6599
G1 X27.9466 Y4.6558
G1 X27.8978 Y4.6431
G1 X27.8795 Y4.6375
G1 X27.8323 Y4.6203
G1 X27.8135 Y4.6121
G1 X27.7680 Y4.5900
G1 X27.7495 Y4.5799
G1 X27.7068 Y4.5532
G1 X27.6911 Y4.5423
G1 X27.6509 Y4.5115
G1 X27.6352 Y4.4981
G1 X27.5986 Y4.4635
G1 X27.5849 Y4.4493
G1 X27.5519 Y4.4112
G1 X27.5394 Y4.3952
G1 X27.5105 Y4.3541
G1 X27.4996 Y4.3368
G1 X27.4749 Y4.2929
G1 X27.4663 Y4.2756
G1 X27.4460 Y4.2294
G1 X27.4386 Y4.2095
G1 X27.4234 Y4.1618
G1 X27.4183 Y4.1435
G1 X27.4076 Y4.0942
G1 X27.4043 Y4.0729
G1 X27.3980 Y4.0084
G1 X27.3969 Y3.9723
G1 X27.3969 Y0.3929
G1 X26.1214 Y0.3929
G1 X26.1211 Y3.9825
G1 X26.1186 Y4.0328
G1 X26.1165 Y4.0528
G1 X26.1089 Y4.1026
G1 X26.1048 Y4.1227
G1 X26.0922 Y4.1714
G1 X26.0866 Y4.1897
G1 X26.0693 Y4.2370
G1 X26.0612 Y4.2558
G1 X26.0391 Y4.3012
G1 X26.0289 Y4.3198
G1 X26.0022 Y4.3624
G1 X25.9913 Y4.3782
G1 X25.9606 Y4.4183
G1 X25.9471 Y4.4341
G1 X25.9126 Y4.4707
G1 X25.8983 Y4.4844
G1 X25.8602 Y4.5174
G1 X25.8442 Y4.5298
G1 X25.8031 Y4.5588
G1 X25.7858 Y4.5697
G1 X25.7419 Y4.5944
G1 X25.7246 Y4.6030
G1 X25.6784 Y4.6233
G1 X25.6586 Y4.6307
G1 X25.6108 Y4.6459
G1 X25.5925 Y4.6510
G1 X25.5433 Y4.6617
G1 X25.5219 Y4.6650
G1 X25.4574 Y4.6713
G1 X25.4213 Y4.6723
G1 X25.1551 Y4.6723
G1 X25.1551 Y4.7762
G1 X25.9151 Y4.7244
G1 X25.9255 Y4.7310
G1 X25.9489 Y4.7475
G1 X25.9974 Y4.7849
G1 X26.0205 Y4.8052
G1 X26.0637 Y4.8461
G1 X26.0845 Y4.8682
G1 X26.1244 Y4.9146
G1 X26.1424 Y4.9383
G1 X26.1770 Y4.9875
G1 X26.1932 Y5.0140
G1 X26.2222 Y5.0663
G1 X26.2352 Y5.0924
G1 X26.2598 Y5.1496
G1 X26.2702 Y5.1783
G1 X26.2877 Y5.2332
G1 X26.2956 Y5.2626
G1 X26.3083 Y5.3238
G1 X26.3131 Y5.3561
G1 X26.3202 Y5.4346
G1 X26.3213 Y5.4762
G1 X26.3213 Y6.6172
G1 X26.3210 Y6.6213
G1 X26.3223 Y6.7140
G1 X26.3256 Y6.8115
G1 X26.3324 Y6.9167
G1 X26.3428 Y7.0114
G1 X26.3548 Y7.0891
G1 X26.3695 Y7.1605
G1 X26.3921 Y7.2451
G1 X26.4170 Y7.3193
G1 X26.4447 Y7.3868
G1 X26.4818 Y7.4615
G1 X26.5204 Y7.5265
G1 X26.5697 Y7.5969
G1 X26.6319 Y7.6728
G1 X26.7000 Y7.7447
G1 X26.7889 Y7.8260
G1 X26.8882 Y7.9052
G1 X26.9558 Y7.9532
G1 X27.0327 Y8.0028
G1 X27.1155 Y8.0508
G1 X27.1963 Y8.0929
G1 X27.2857 Y8.1349
G1 X27.3842 Y8.1760
G1 X27.4838 Y8.2126
G1 X27.5859 Y8.2453
G1 X27.6931 Y8.2748
G1 X27.8242 Y8.3055
G1 X27.9448 Y8.3289
G1 X28.0751 Y8.3492
G1 X28.1536 Y8.3586
G1 X28.0767 Y8.3182
G1 X28.0187 Y8.2845
G1 X27.9377 Y8.2316
G1 X27.8737 Y8.1846
G1 X27.8105 Y8.1326
G1 X27.7665 Y8.0929
G1 X27.7485 Y8.0749
G1 X27.7211 Y8.0457
G1 X27.6106 Y7.9207
G1 X27.5742 Y7.8755
G1 X27.5554 Y7.8499
G1 X27.5245 Y7.8014
G1 X27.4404 Y7.6619
G1 X27.4119 Y7.6083
G1 X27.4023 Y7.5877
G1 X27.3863 Y7.5504
G1 X27.3243 Y7.3944
G1 X27.2976 Y7.3111
G1 X27.2578 Y7.1570
G1 X27.2435 Y7.0874
G1 X27.2202 Y6.9362
G1 X27.2146 Y6.8885
G1 X27.2029 Y6.7465
G1 X27.2009 Y6.7099
G1 X27.1965 Y6.5631
G1 X27.1958 Y6.4486
G1 X27.1963 Y5.4559
G1 X27.1996 Y5.3957
G1 X27.2029 Y5.3655
G1 X27.2120 Y5.3063
G1 X27.2186 Y5.2756
G1 X27.2336 Y5.2187
G1 X27.2425 Y5.1902
G1 X27.2641 Y5.1321
G1 X27.2760 Y5.1054
G1 X27.3025 Y5.0513
G1 X27.3185 Y5.0228
G1 X27.3505 Y4.9720
G1 X27.3670 Y4.9487
G1 X27.4043 Y4.9002
G1 X27.4246 Y4.8771
G1 X27.4655 Y4.8339
G1 X27.4876 Y4.8130
G1 X27.5341 Y4.7732
G1 X27.5577 Y4.7551
G1 X27.6027 Y4.7236
G1 X27.5928 Y4.7175
G1 X27.5694 Y4.7010
G1 X27.5209 Y4.6637
G1 X27.4978 Y4.6434
G1 X27.4546 Y4.6025
G1 X27.4338 Y4.5804
G1 X27.3939 Y4.5339
G1 X27.3759 Y4.5103
G1 X27.3413 Y4.4610
G1 X27.3251 Y4.4346
G1 X27.2961 Y4.3823
G1 X27.2832 Y4.3561
G1 X27.2585 Y4.2989
G1 X27.2481 Y4.2702
G1 X27.2306 Y4.2154
G1 X27.2227 Y4.1859
G1 X27.2100 Y4.1247
G1 X27.2052 Y4.0924
G1 X27.1981 Y4.0140
G1 X27.1971 Y3.9723
G1 X27.1971 Y0.5928
G1 X26.3213 Y0.5928
G1 X26.3208 Y3.9926
G1 X26.3174 Y4.0528
G1 X26.3141 Y4.0830
G1 X26.3050 Y4.1422
G1 X26.2984 Y4.1730
G1 X26.2834 Y4.2299
G1 X26.2745 Y4.2583
G1 X26.2529 Y4.3165
G1 X26.2410 Y4.3431
G1 X26.2146 Y4.3972
G1 X26.1986 Y4.4257
G1 X26.1666 Y4.4765
G1 X26.1501 Y4.4999
G1 X26.1127 Y4.5484
G1 X26.0924 Y4.5715
G1 X26.0515 Y4.6147
G1 X26.0294 Y4.6355
G1 X25.9829 Y4.6754
G1 X25.9593 Y4.6934
G1 X25.9151 Y4.7244
G1 X26.2235 Y4.7239
G1 X26.2364 Y4.7379
G1 X26.2834 Y4.7932
G1 X26.3063 Y4.8235
G1 X26.3474 Y4.8826
G1 X26.3682 Y4.9172
G1 X26.4015 Y4.9776
G1 X26.4188 Y5.0132
G1 X26.4477 Y5.0813
G1 X26.4607 Y5.1173
G1 X26.4810 Y5.1816
G1 X26.4914 Y5.2220
G1 X26.5062 Y5.2941
G1 X26.5123 Y5.3381
G1 X26.5201 Y5.4298
G1 X26.5212 Y5.4762
G1 X26.5209 Y6.6185
G1 X26.5222 Y6.7071
G1 X26.5252 Y6.7986
G1 X26.5318 Y6.8994
G1 X26.5417 Y6.9896
G1 X26.5516 Y7.0536
G1 X26.5638 Y7.1128
G1 X26.5844 Y7.1895
G1 X26.6035 Y7.2464
G1 X26.6283 Y7.3071
G1 X26.6570 Y7.3650
G1 X26.6880 Y7.4173
G1 X26.7297 Y7.4767
G1 X26.7820 Y7.5405
G1 X26.8407 Y7.6025
G1 X26.9192 Y7.6744
G1 X27.0076 Y7.7447
G1 X27.0690 Y7.7884
G1 X27.1374 Y7.8323
G1 X27.2128 Y7.8760
G1 X27.2842 Y7.9134
G1 X27.3652 Y7.9512
G1 X27.3896 Y7.9614
G1 X27.3868 Y7.9576
G1 X27.3533 Y7.9047
G1 X27.2639 Y7.7556
G1 X27.2308 Y7.6932
G1 X27.2184 Y7.6665
G1 X27.2004 Y7.6243
G1 X27.1338 Y7.4554
G1 X27.1041 Y7.3612
G1 X27.0619 Y7.1971
G1 X27.0459 Y7.1178
G1 X27.0215 Y6.9596
G1 X27.0152 Y6.9050
G1 X27.0032 Y6.7577
G1 X27.0010 Y6.7158
G1 X26.9966 Y6.5644
G1 X26.9959 Y6.4486
G1 X26.9966 Y5.4450
G1 X27.0007 Y5.3739
G1 X27.0053 Y5.3350
G1 X27.0165 Y5.2644
G1 X27.0253 Y5.2245
G1 X27.0426 Y5.1590
G1 X27.0551 Y5.1206
G1 X27.0815 Y5.0503
G1 X27.0962 Y5.0178
G1 X27.1282 Y4.9533
G1 X27.1493 Y4.9162
G1 X27.1871 Y4.8567
G1 X27.2085 Y4.8268
G1 X27.2542 Y4.7681
G1 X27.2793 Y4.7396
G1 X27.2943 Y4.7239
G1 X27.2819 Y4.7107
G1 X27.2349 Y4.6553
G1 X27.2120 Y4.6251
G1 X27.1709 Y4.5659
G1 X27.1501 Y4.5314
G1 X27.1168 Y4.4709
G1 X27.0995 Y4.4353
G1 X27.0706 Y4.3673
G1 X27.0576 Y4.3312
G1 X27.0373 Y4.2669
G1 X27.0269 Y4.2266
G1 X27.0121 Y4.1544
G1 X27.0060 Y4.1105
G1 X26.9982 Y4.0188
G1 X26.9972 Y3.9723
G1 X26.9972 Y0.7927
G1 X26.5212 Y0.7927
G1 X26.5204 Y4.0035
G1 X26.5163 Y4.0747
G1 X26.5118 Y4.1135
G1 X26.5006 Y4.1841
G1 X26.4917 Y4.2240
G1 X26.4744 Y4.2896
G1 X26.4620 Y4.3279
G1 X26.4356 Y4.3983
G1 X26.4208 Y4.4308
G1 X26.3888 Y4.4953
G1 X26.3677 Y4.5324
G1 X26.3299 Y4.5918
G1 X26.3086 Y4.6218
G1 X26.2628 Y4.6805
G1 X26.2377 Y4.7089
G1 X26.2235 Y4.7239
G1 X26.4808 Y4.7244
G1 X26.5186 Y4.7793
G1 X26.5435 Y4.8207
G1 X26.5814 Y4.8903
G1 X26.6029 Y4.9350
G1 X26.6360 Y5.0137
G1 X26.6515 Y5.0571
G1 X26.6746 Y5.1316
G1 X26.6873 Y5.1819
G1 X26.7043 Y5.2667
G1 X26.7117 Y5.3210
G1 X26.7200 Y5.4254
G1 X26.7211 Y5.4762
G1 X26.7208 Y6.6157
G1 X26.7221 Y6.7005
G1 X26.7249 Y6.7856
G1 X26.7312 Y6.8821
G1 X26.7406 Y6.9677
G1 X26.7485 Y7.0180
G1 X26.7581 Y7.0650
G1 X26.7762 Y7.1323
G1 X26.7909 Y7.1758
G1 X26.8107 Y7.2243
G1 X26.8336 Y7.2702
G1 X26.8564 Y7.3091
G1 X26.8884 Y7.3548
G1 X26.8994 Y7.3680
G1 X26.8658 Y7.2367
G1 X26.8483 Y7.1483
G1 X26.8229 Y6.9827
G1 X26.8158 Y6.9212
G1 X26.8036 Y6.7686
G1 X26.8011 Y6.7213
G1 X26.7967 Y6.5656
G1 X26.7960 Y6.4483
G1 X26.7970 Y5.4336
G1 X26.8021 Y5.3505
G1 X26.8077 Y5.3038
G1 X26.8211 Y5.2210
G1 X26.8321 Y5.1735
G1 X26.8524 Y5.0973
G1 X26.8679 Y5.0503
G1 X26.8994 Y4.9677
G1 X26.9171 Y4.9289
G1 X26.9542 Y4.8544
G1 X26.9806 Y4.8087
G1 X27.0243 Y4.7407
G1 X27.0368 Y4.7231
G1 X26.9997 Y4.6693
G1 X26.9748 Y4.6279
G1 X26.9370 Y4.5583
G1 X26.9154 Y4.5136
G1 X26.8823 Y4.4348
G1 X26.8668 Y4.3914
G1 X26.8437 Y4.3170
G1 X26.8310 Y4.2667
G1 X26.8140 Y4.1819
G1 X26.8067 Y4.1275
G1 X26.7983 Y4.0231
G1 X26.7973 Y3.9723
G1 X26.7973 Y0.9926
G1 X26.7211 Y0.9926
G1 X26.7200 Y4.0150
G1 X26.7150 Y4.0980
G1 X26.7094 Y4.1448
G1 X26.6959 Y4.2276
G1 X26.6850 Y4.2751
G1 X26.6647 Y4.3513
G1 X26.6492 Y4.3983
G1 X26.6177 Y4.4808
G1 X26.5999 Y4.5197
G1 X26.5628 Y4.5941
G1 X26.5364 Y4.6398
G1 X26.4927 Y4.7079
G1 X26.4808 Y4.7244
G1 X26.7185 Y4.7241
G1 X26.7193 Y4.7252
G1 X26.7589 Y4.7986
G1 X26.7810 Y4.7544
G1 X26.7990 Y4.7234
G1 X26.7589 Y4.6487
G1 X26.7360 Y4.6942
G1 X26.7185 Y4.7241
; Retract
G1 Z2.0000 F750
; Path 2
G1 X16.3586 Y2.9385 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X16.3759 Y2.8179 F300
G1 X16.3812 Y2.7615
G1 X10.7069 Y2.7615
G1 X10.6566 Y2.7589
G1 X10.6068 Y2.7513
G1 X10.5580 Y2.7386
G1 X10.5108 Y2.7214
G1 X10.4653 Y2.6993
G1 X10.4226 Y2.6726
G1 X10.3825 Y2.6419
G1 X10.3459 Y2.6073
G1 X10.3129 Y2.5692
G1 X10.2840 Y2.5281
G1 X10.2593 Y2.4841
G1 X10.2390 Y2.4379
G1 X10.2238 Y2.3901
G1 X10.2131 Y2.3409
G1 X10.2078 Y2.2906
G1 X10.2080 Y2.2288
G1 X10.2159 Y2.1079
G1 X10.2230 Y2.0495
G1 X10.2466 Y1.9218
G1 X10.2591 Y1.8702
G1 X10.2982 Y1.7386
G1 X10.3160 Y1.6891
G1 X10.3708 Y1.5573
G1 X10.3927 Y1.5110
G1 X10.4630 Y1.3813
G1 X10.4925 Y1.3338
G1 X10.5788 Y1.2098
G1 X10.6139 Y1.1648
G1 X10.7158 Y1.0493
G1 X10.7602 Y1.0048
G1 X10.8781 Y0.9009
G1 X10.9339 Y0.8583
G1 X11.0935 Y0.7534
G1 X11.1491 Y0.7219
G1 X11.3193 Y0.6388
G1 X11.3690 Y0.6177
G1 X11.5461 Y0.5540
G1 X11.5908 Y0.5403
G1 X11.7714 Y0.4938
G1 X11.8090 Y0.4856
G1 X11.9896 Y0.4536
G1 X12.0203 Y0.4491
G1 X12.1973 Y0.4290
G1 X12.2240 Y0.4267
G1 X12.4150 Y0.4158
G1 X12.5921 Y0.4130
G1 X12.7549 Y0.4161
G1 X12.9207 Y0.4247
G1 X13.0851 Y0.4394
G1 X13.2484 Y0.4608
G1 X13.3848 Y0.4841
G1 X13.4102 Y0.4892
G1 X13.5400 Y0.5184
G1 X13.5684 Y0.5255
G1 X13.6893 Y0.5603
G1 X13.7239 Y0.5718
G1 X13.8542 Y0.6200
G1 X13.8803 Y0.6309
G1 X13.9095 Y0.6444
G1 X13.9578 Y0.6683
G1 X13.9822 Y0.6812
G1 X14.0477 Y0.7183
G1 X14.0752 Y0.7348
G1 X14.1536 Y0.7861
G1 X14.1801 Y0.8047
G1 X14.2674 Y0.8702
G1 X14.2984 Y0.8956
G1 X14.3901 Y0.9766
G1 X14.4221 Y1.0074
G1 X14.4569 Y1.0442
G1 X15.8438 Y0.9446
G1 X15.7836 Y0.8885
G1 X15.6982 Y0.8166
G1 X15.6020 Y0.7427
G1 X15.5100 Y0.6782
G1 X15.4163 Y0.6177
G1 X15.3218 Y0.5613
G1 X15.2278 Y0.5098
G1 X15.1384 Y0.4641
G1 X15.0556 Y0.4247
G1 X14.9715 Y0.3873
G1 X14.8412 Y0.3350
G1 X14.7061 Y0.2868
G1 X14.5628 Y0.2413
G1 X14.4257 Y0.2024
G1 X14.2799 Y0.1661
G1 X14.1346 Y0.1344
G1 X13.9832 Y0.1062
G1 X13.8361 Y0.0825
G1 X13.6761 Y0.0610
G1 X13.5283 Y0.0442
G1 X13.3675 Y0.0300
G1 X13.2039 Y0.0183
G1 X13.0406 Y0.0099
G1 X12.8844 Y0.0046
G1 X12.7117 Y0.0010
G1 X12.5491 Y-0.0000
G1 X12.3302 Y0.0018
G1 X12.1028 Y0.0079
G1 X11.8915 Y0.0180
G1 X11.6914 Y0.0325
G1 X11.4788 Y0.0538
G1 X11.2834 Y0.0792
G1 X11.0901 Y0.1115
G1 X10.8971 Y0.1509
G1 X10.7160 Y0.1951
G1 X10.5341 Y0.2479
G1 X10.3584 Y0.3081
G1 X10.1884 Y0.3752
G1 X10.0155 Y0.4536
G1 X9.8534 Y0.5375
G1 X9.6853 Y0.6360
G1 X9.5273 Y0.7402
G1 X9.4150 Y0.8227
G1 X9.3015 Y0.9147
G1 X9.2022 Y1.0033
G1 X9.1044 Y1.1006
G1 X9.0112 Y1.2040
G1 X8.9258 Y1.3091
G1 X8.8481 Y1.4176
G1 X8.7787 Y1.5276
G1 X8.7142 Y1.6452
G1 X8.6584 Y1.7645
G1 X8.6114 Y1.8847
G1 X8.5707 Y2.0135
G1 X8.5392 Y2.1417
G1 X8.5159 Y2.2784
G1 X8.5016 Y2.4173
G1 X8.4966 Y2.5611
G1 X8.5004 Y2.6802
G1 X8.5131 Y2.8100
G1 X8.5326 Y2.9334
G1 X8.5606 Y3.0574
G1 X8.5982 Y3.1864
G1 X8.6413 Y3.3071
G1 X8.6929 Y3.4275
G1 X8.7549 Y3.5514
G1 X8.8250 Y3.6726
G1 X8.9017 Y3.7887
G1 X8.9901 Y3.9073
G1 X9.0838 Y4.0188
G1 X9.1844 Y4.1252
G1 X9.2997 Y4.2344
G1 X9.4214 Y4.3373
G1 X9.5479 Y4.4328
G1 X9.7122 Y4.5400
G1 X9.8826 Y4.6378
G1 X10.0566 Y4.7247
G1 X10.2372 Y4.8036
G1 X10.4247 Y4.8743
G1 X10.6083 Y4.9342
G1 X10.7907 Y4.9853
G1 X10.9804 Y5.0300
G1 X11.1768 Y5.0693
G1 X11.3594 Y5.0988
G1 X11.5524 Y5.1239
G1 X11.7310 Y5.1422
G1 X11.9172 Y5.1562
G1 X12.0929 Y5.1651
G1 X12.2735 Y5.1702
G1 X12.4384 Y5.1719
G1 X12.6030 Y5.1704
G1 X12.7902 Y5.1653
G1 X12.9631 Y5.1572
G1 X13.1643 Y5.1430
G1 X13.3497 Y5.1250
G1 X13.5458 Y5.1003
G1 X13.7396 Y5.0696
G1 X13.9484 Y5.0292
G1 X14.1409 Y4.9842
G1 X14.3365 Y4.9299
G1 X14.5301 Y4.8666
G1 X14.7190 Y4.7945
G1 X14.9098 Y4.7099
G1 X15.0868 Y4.6190
G1 X15.2611 Y4.5154
G1 X15.4282 Y4.4008
G1 X15.5806 Y4.2809
G1 X15.7104 Y4.1636
G1 X15.8280 Y4.0427
G1 X15.9316 Y3.9197
G1 X16.0205 Y3.7981
G1 X16.0965 Y3.6777
G1 X16.1620 Y3.5557
G1 X16.2197 Y3.4293
G1 X16.2657 Y3.3086
G1 X16.3035 Y3.1872
G1 X16.3347 Y3.0620
G1 X16.3586 Y2.9385
G1 X16.1506 Y2.9614
G1 X14.9865 Y2.9614
G1 X15.0099 Y2.9944
G1 X15.0208 Y3.0117
G1 X15.0454 Y3.0556
G1 X15.0541 Y3.0729
G1 X15.0744 Y3.1191
G1 X15.0818 Y3.1389
G1 X15.0970 Y3.1867
G1 X15.1021 Y3.2050
G1 X15.1127 Y3.2542
G1 X15.1160 Y3.2756
G1 X15.1214 Y3.3259
G1 X15.1224 Y3.3449
G1 X15.1229 Y3.3952
G1 X15.1221 Y3.4166
G1 X15.1173 Y3.4666
G1 X15.1145 Y3.4856
G1 X15.1049 Y3.5352
G1 X15.0998 Y3.5555
G1 X15.0785 Y3.6236
G1 X15.0546 Y3.6845
G1 X15.0279 Y3.7470
G1 X15.0122 Y3.7810
G1 X14.9695 Y3.8654
G1 X14.9504 Y3.8997
G1 X14.8925 Y3.9975
G1 X14.8653 Y4.0396
G1 X14.7876 Y4.1491
G1 X14.7536 Y4.1923
G1 X14.6555 Y4.3063
G1 X14.6119 Y4.3518
G1 X14.4920 Y4.4648
G1 X14.4402 Y4.5085
G1 X14.2964 Y4.6164
G1 X14.2410 Y4.6530
G1 X14.1161 Y4.7267
G1 X14.0729 Y4.7495
G1 X13.9370 Y4.8156
G1 X13.8928 Y4.8349
G1 X13.8859 Y4.8377
G1 X13.9055 Y4.8339
G1 X14.0904 Y4.7907
G1 X14.2829 Y4.7371
G1 X14.4597 Y4.6792
G1 X14.6441 Y4.6088
G1 X14.8250 Y4.5288
G1 X14.9873 Y4.4453
G1 X15.1564 Y4.3447
G1 X15.3076 Y4.2413
G1 X15.4523 Y4.1272
G1 X15.5722 Y4.0190
G1 X15.6799 Y3.9083
G1 X15.7724 Y3.7983
G1 X15.8557 Y3.6845
G1 X15.9225 Y3.5784
G1 X15.9840 Y3.4643
G1 X16.0338 Y3.3553
G1 X16.0764 Y3.2436
G1 X16.1110 Y3.1328
G1 X16.1392 Y3.0201
G1 X16.1506 Y2.9614
G1 X15.8925 Y3.1613
G1 X15.2974 Y3.1613
G1 X15.2977 Y3.1626
G1 X15.3104 Y3.2238
G1 X15.3149 Y3.2545
G1 X15.3210 Y3.3152
G1 X15.3223 Y3.3429
G1 X15.3228 Y3.4023
G1 X15.3213 Y3.4359
G1 X15.3152 Y3.4955
G1 X15.3109 Y3.5240
G1 X15.2989 Y3.5837
G1 X15.2905 Y3.6154
G1 X15.2646 Y3.6965
G1 X15.2385 Y3.7630
G1 X15.2095 Y3.8311
G1 X15.1907 Y3.8715
G1 X15.1442 Y3.9624
G1 X15.1227 Y4.0015
G1 X15.0607 Y4.1059
G1 X15.0284 Y4.1554
G1 X14.9878 Y4.2123
G1 X15.0475 Y4.1768
G1 X15.1895 Y4.0797
G1 X15.3220 Y3.9754
G1 X15.4361 Y3.8722
G1 X15.5298 Y3.7760
G1 X15.6167 Y3.6726
G1 X15.6906 Y3.5715
G1 X15.7485 Y3.4795
G1 X15.8054 Y3.3741
G1 X15.8481 Y3.2804
G1 X15.8877 Y3.1770
G1 X15.8925 Y3.1613
G1 X15.5852 Y3.3612
G1 X15.5224 Y3.3612
G1 X15.5227 Y3.4115
G1 X15.5202 Y3.4562
G1 X15.5189 Y3.4671
G1 X15.5260 Y3.4574
G1 X15.5755 Y3.3790
G1 X15.5852 Y3.3612
G1 X14.9225 Y3.3470
G1 X14.9230 Y3.3972
G1 X14.9182 Y3.4473
G1 X14.9085 Y3.4968
G1 X14.8918 Y3.5514
G1 X14.8707 Y3.6060
G1 X14.8460 Y3.6637
G1 X14.8333 Y3.6914
G1 X14.7947 Y3.7683
G1 X14.7782 Y3.7981
G1 X14.7241 Y3.8898
G1 X14.7020 Y3.9243
G1 X14.6304 Y4.0256
G1 X14.6017 Y4.0622
G1 X14.5108 Y4.1684
G1 X14.4744 Y4.2065
G1 X14.3624 Y4.3124
G1 X14.3198 Y4.3487
G1 X14.1851 Y4.4501
G1 X14.1392 Y4.4808
G1 X14.0216 Y4.5504
G1 X13.9855 Y4.5697
G1 X13.8560 Y4.6327
G1 X13.8199 Y4.6487
G1 X13.6787 Y4.7041
G1 X13.6428 Y4.7165
G1 X13.4899 Y4.7635
G1 X13.4554 Y4.7727
G1 X13.2913 Y4.8105
G1 X13.2578 Y4.8171
G1 X13.0825 Y4.8450
G1 X13.0500 Y4.8491
G1 X12.8638 Y4.8664
G1 X12.8331 Y4.8684
G1 X12.6362 Y4.8745
G1 X12.6027 Y4.8743
G1 X12.3576 Y4.8654
G1 X12.3205 Y4.8628
G1 X12.1003 Y4.8384
G1 X12.0604 Y4.8323
G1 X11.8633 Y4.7942
G1 X11.8247 Y4.7851
G1 X11.6489 Y4.7363
G1 X11.6096 Y4.7236
G1 X11.4539 Y4.6662
G1 X11.4168 Y4.6507
G1 X11.2796 Y4.5872
G1 X11.2461 Y4.5702
G1 X11.1260 Y4.5032
G1 X11.0968 Y4.4854
G1 X10.9918 Y4.4171
G1 X10.9403 Y4.3787
G1 X10.7922 Y4.2525
G1 X10.7465 Y4.2080
G1 X10.6139 Y4.0620
G1 X10.5819 Y4.0231
G1 X10.5659 Y4.0000
G1 X10.4577 Y3.8349
G1 X10.4320 Y3.7915
G1 X10.4130 Y3.7498
G1 X10.3375 Y3.5651
G1 X10.3208 Y3.5176
G1 X10.3091 Y3.4686
G1 X10.3022 Y3.4188
G1 X10.3005 Y3.3685
G1 X10.3038 Y3.3183
G1 X10.3121 Y3.2685
G1 X10.3254 Y3.2200
G1 X10.3434 Y3.1730
G1 X10.3662 Y3.1280
G1 X10.3934 Y3.0856
G1 X10.4247 Y3.0460
G1 X10.4600 Y3.0099
G1 X10.4986 Y2.9776
G1 X10.5402 Y2.9492
G1 X10.5844 Y2.9251
G1 X10.6309 Y2.9058
G1 X10.6792 Y2.8910
G1 X10.7285 Y2.8814
G1 X10.8003 Y2.8760
G1 X14.4234 Y2.8760
G1 X14.4737 Y2.8786
G1 X14.5235 Y2.8862
G1 X14.5722 Y2.8989
G1 X14.6195 Y2.9162
G1 X14.6649 Y2.9383
G1 X14.7076 Y2.9649
G1 X14.7477 Y2.9957
G1 X14.7843 Y3.0302
G1 X14.8173 Y3.0683
G1 X14.8463 Y3.1095
G1 X14.8709 Y3.1534
G1 X14.8913 Y3.1996
G1 X14.9065 Y3.2474
G1 X14.9172 Y3.2967
G1 X14.9225 Y3.3470
; Retract
G1 Z2.0000 F750
; Path 3
G1 X14.5346 Y0.8382 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X15.3030 Y0.7831 F300
G1 X15.2207 Y0.7341
G1 X15.1333 Y0.6861
G1 X15.0525 Y0.6447
G1 X14.9743 Y0.6076
G1 X14.8913 Y0.5707
G1 X14.7726 Y0.5230
G1 X14.6416 Y0.4762
G1 X14.5059 Y0.4333
G1 X14.3711 Y0.3950
G1 X14.2331 Y0.3607
G1 X14.0960 Y0.3307
G1 X13.9461 Y0.3028
G1 X13.8074 Y0.2804
G1 X13.6517 Y0.2593
G1 X13.5080 Y0.2431
G1 X13.3510 Y0.2291
G1 X13.1920 Y0.2179
G1 X13.0338 Y0.2098
G1 X12.8775 Y0.2045
G1 X12.7076 Y0.2009
G1 X12.5494 Y0.1999
G1 X12.3355 Y0.2017
G1 X12.1082 Y0.2078
G1 X11.9050 Y0.2174
G1 X11.7076 Y0.2316
G1 X11.5047 Y0.2522
G1 X11.3139 Y0.2771
G1 X11.1267 Y0.3084
G1 X10.9390 Y0.3465
G1 X10.7668 Y0.3886
G1 X10.5948 Y0.4384
G1 X10.4252 Y0.4966
G1 X10.2677 Y0.5588
G1 X10.1026 Y0.6337
G1 X9.9494 Y0.7130
G1 X9.7902 Y0.8062
G1 X9.6416 Y0.9042
G1 X9.5410 Y0.9782
G1 X9.4275 Y1.0701
G1 X9.3398 Y1.1483
G1 X9.2504 Y1.2372
G1 X9.1618 Y1.3355
G1 X9.0863 Y1.4285
G1 X9.0137 Y1.5301
G1 X8.9510 Y1.6297
G1 X8.8928 Y1.7353
G1 X8.8420 Y1.8440
G1 X8.8003 Y1.9502
G1 X8.7638 Y2.0665
G1 X8.7348 Y2.1841
G1 X8.7140 Y2.3063
G1 X8.7013 Y2.4295
G1 X8.6967 Y2.5618
G1 X8.7000 Y2.6657
G1 X8.7119 Y2.7871
G1 X8.7295 Y2.8974
G1 X8.7541 Y3.0069
G1 X8.7894 Y3.1278
G1 X8.8265 Y3.2316
G1 X8.8758 Y3.3462
G1 X8.9299 Y3.4547
G1 X8.9974 Y3.5710
G1 X9.0670 Y3.6759
G1 X9.1432 Y3.7785
G1 X9.2347 Y3.8872
G1 X9.3259 Y3.9837
G1 X9.4343 Y4.0866
G1 X9.5466 Y4.1816
G1 X9.6601 Y4.2672
G1 X9.8176 Y4.3698
G1 X9.9786 Y4.4623
G1 X10.1410 Y4.5433
G1 X10.3104 Y4.6175
G1 X10.4907 Y4.6853
G1 X10.6703 Y4.7440
G1 X10.8405 Y4.7917
G1 X11.0208 Y4.8341
G1 X11.2151 Y4.8730
G1 X11.3853 Y4.9004
G1 X11.5783 Y4.9256
G1 X11.5875 Y4.9266
G1 X11.5405 Y4.9113
G1 X11.3767 Y4.8509
G1 X11.3327 Y4.8323
G1 X11.1892 Y4.7655
G1 X11.1486 Y4.7450
G1 X11.0221 Y4.6741
G1 X10.9875 Y4.6530
G1 X10.8725 Y4.5776
G1 X10.8105 Y4.5309
G1 X10.6528 Y4.3960
G1 X10.5984 Y4.3424
G1 X10.4595 Y4.1892
G1 X10.4275 Y4.1504
G1 X10.4176 Y4.1369
G1 X10.3985 Y4.1097
G1 X10.2855 Y3.9365
G1 X10.2598 Y3.8931
G1 X10.2502 Y3.8745
G1 X10.2278 Y3.8255
G1 X10.1488 Y3.6317
G1 X10.1321 Y3.5842
G1 X10.1262 Y3.5641
G1 X10.1145 Y3.5151
G1 X10.1110 Y3.4958
G1 X10.1041 Y3.4460
G1 X10.1023 Y3.4260
G1 X10.1006 Y3.3757
G1 X10.1008 Y3.3553
G1 X10.1041 Y3.3050
G1 X10.1067 Y3.2850
G1 X10.1150 Y3.2352
G1 X10.1191 Y3.2159
G1 X10.1323 Y3.1674
G1 X10.1387 Y3.1483
G1 X10.1567 Y3.1013
G1 X10.1651 Y3.0823
G1 X10.1879 Y3.0373
G1 X10.1978 Y3.0201
G1 X10.2250 Y2.9776
G1 X10.2365 Y2.9616
G1 X10.2677 Y2.9220
G1 X10.2817 Y2.9060
G1 X10.3170 Y2.8699
G1 X10.3317 Y2.8565
G1 X10.3350 Y2.8537
G1 X10.3167 Y2.8423
G1 X10.3010 Y2.8313
G1 X10.2608 Y2.8006
G1 X10.2451 Y2.7871
G1 X10.2085 Y2.7526
G1 X10.1948 Y2.7384
G1 X10.1618 Y2.7003
G1 X10.1493 Y2.6843
G1 X10.1204 Y2.6431
G1 X10.1095 Y2.6259
G1 X10.0848 Y2.5819
G1 X10.0762 Y2.5646
G1 X10.0559 Y2.5184
G1 X10.0485 Y2.4986
G1 X10.0333 Y2.4508
G1 X10.0282 Y2.4326
G1 X10.0175 Y2.3833
G1 X10.0142 Y2.3619
G1 X10.0089 Y2.3117
G1 X10.0079 Y2.2898
G1 X10.0084 Y2.2159
G1 X10.0173 Y2.0838
G1 X10.0264 Y2.0132
G1 X10.0523 Y1.8748
G1 X10.0673 Y1.8133
G1 X10.1100 Y1.6711
G1 X10.1313 Y1.6121
G1 X10.1900 Y1.4719
G1 X10.2169 Y1.4158
G1 X10.2931 Y1.2758
G1 X10.3284 Y1.2195
G1 X10.4211 Y1.0869
G1 X10.4638 Y1.0325
G1 X10.5743 Y0.9078
G1 X10.6279 Y0.8547
G1 X10.7566 Y0.7419
G1 X10.8240 Y0.6911
G1 X10.9949 Y0.5794
G1 X11.0614 Y0.5420
G1 X11.2413 Y0.4547
G1 X11.3012 Y0.4295
G1 X11.4874 Y0.3627
G1 X11.5410 Y0.3465
G1 X11.7292 Y0.2982
G1 X11.7742 Y0.2888
G1 X11.9601 Y0.2558
G1 X11.9977 Y0.2504
G1 X12.1803 Y0.2296
G1 X12.2126 Y0.2271
G1 X12.4120 Y0.2159
G1 X12.5959 Y0.2131
G1 X12.7653 Y0.2164
G1 X12.9385 Y0.2256
G1 X13.1110 Y0.2410
G1 X13.2822 Y0.2637
G1 X13.4239 Y0.2880
G1 X13.4541 Y0.2941
G1 X13.5885 Y0.3244
G1 X13.6238 Y0.3332
G1 X13.7521 Y0.3703
G1 X13.7932 Y0.3843
G1 X13.9311 Y0.4354
G1 X13.9642 Y0.4493
G1 X13.9982 Y0.4651
G1 X14.0515 Y0.4917
G1 X14.0807 Y0.5072
G1 X14.1508 Y0.5469
G1 X14.1846 Y0.5674
G1 X14.2685 Y0.6226
G1 X14.2999 Y0.6447
G1 X14.3942 Y0.7155
G1 X14.4308 Y0.7457
G1 X14.5285 Y0.8324
G1 X14.5346 Y0.8382
; Retract
G1 Z2.0000 F750
; Path 4
G1 X10.5352 Y0.6703 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X10.4920 Y0.6850 F300
G1 X10.3469 Y0.7424
G1 X10.1897 Y0.8138
G1 X10.0493 Y0.8865
G1 X9.8938 Y0.9774
G1 X9.7569 Y1.0678
G1 X9.6637 Y1.1361
G1 X9.5534 Y1.2255
G1 X9.4775 Y1.2934
G1 X9.3965 Y1.3739
G1 X9.3124 Y1.4671
G1 X9.2476 Y1.5471
G1 X9.1788 Y1.6434
G1 X9.1239 Y1.7302
G1 X9.0698 Y1.8288
G1 X9.0269 Y1.9207
G1 X8.9886 Y2.0180
G1 X8.9571 Y2.1184
G1 X8.9304 Y2.2271
G1 X8.9121 Y2.3332
G1 X8.9009 Y2.4422
G1 X8.8969 Y2.5624
G1 X8.8997 Y2.6513
G1 X8.9106 Y2.7615
G1 X8.9266 Y2.8618
G1 X8.9474 Y2.9553
G1 X8.9794 Y3.0650
G1 X9.0147 Y3.1633
G1 X9.0564 Y3.2601
G1 X9.1067 Y3.3607
G1 X9.1676 Y3.4658
G1 X9.2311 Y3.5613
G1 X9.2982 Y3.6518
G1 X9.3856 Y3.7556
G1 X9.4676 Y3.8425
G1 X9.5669 Y3.9367
G1 X9.6716 Y4.0251
G1 X9.7747 Y4.1031
G1 X9.9230 Y4.1996
G1 X10.0747 Y4.2868
G1 X10.2253 Y4.3619
G1 X10.3850 Y4.4320
G1 X10.4224 Y4.4460
G1 X10.3050 Y4.3165
G1 X10.2664 Y4.2690
G1 X10.2537 Y4.2517
G1 X10.2311 Y4.2189
G1 X10.1133 Y4.0381
G1 X10.0825 Y3.9855
G1 X10.0683 Y3.9576
G1 X10.0427 Y3.9009
G1 X9.9601 Y3.6982
G1 X9.9400 Y3.6401
G1 X9.9317 Y3.6106
G1 X9.9179 Y3.5514
G1 X9.9129 Y3.5230
G1 X9.9050 Y3.4635
G1 X9.9024 Y3.4331
G1 X9.9007 Y3.3731
G1 X9.9012 Y3.3421
G1 X9.9057 Y3.2799
G1 X9.9096 Y3.2517
G1 X9.9192 Y3.1940
G1 X9.9261 Y3.1633
G1 X9.9426 Y3.1041
G1 X9.9520 Y3.0767
G1 X9.9736 Y3.0208
G1 X9.9868 Y2.9916
G1 X10.0145 Y2.9378
G1 X10.0294 Y2.9121
G1 X10.0515 Y2.8778
G1 X10.0437 Y2.8694
G1 X10.0038 Y2.8230
G1 X9.9858 Y2.7993
G1 X9.9512 Y2.7501
G1 X9.9350 Y2.7236
G1 X9.9060 Y2.6713
G1 X9.8930 Y2.6452
G1 X9.8684 Y2.5880
G1 X9.8580 Y2.5593
G1 X9.8405 Y2.5044
G1 X9.8326 Y2.4750
G1 X9.8199 Y2.4138
G1 X9.8153 Y2.3830
G1 X9.8090 Y2.3211
G1 X9.8080 Y2.2885
G1 X9.8087 Y2.2024
G1 X9.8189 Y2.0582
G1 X9.8298 Y1.9764
G1 X9.8580 Y1.8273
G1 X9.8758 Y1.7559
G1 X9.9220 Y1.6030
G1 X9.9469 Y1.5349
G1 X10.0096 Y1.3853
G1 X10.0411 Y1.3200
G1 X10.1237 Y1.1697
G1 X10.1646 Y1.1049
G1 X10.2639 Y0.9634
G1 X10.3142 Y0.8999
G1 X10.4336 Y0.7658
G1 X10.4960 Y0.7043
G1 X10.5352 Y0.6703
G1 X9.8567 Y1.2426
G1 X9.7874 Y1.2934
G1 X9.6794 Y1.3810
G1 X9.6177 Y1.4361
G1 X9.5402 Y1.5131
G1 X9.4638 Y1.5979
G1 X9.4087 Y1.6660
G1 X9.3439 Y1.7567
G1 X9.2959 Y1.8324
G1 X9.2474 Y1.9207
G1 X9.2123 Y1.9959
G1 X9.1763 Y2.0876
G1 X9.1504 Y2.1702
G1 X9.1262 Y2.2690
G1 X9.1102 Y2.3619
G1 X9.1006 Y2.4544
G1 X9.0970 Y2.5629
G1 X9.0993 Y2.6365
G1 X9.1092 Y2.7361
G1 X9.1232 Y2.8245
G1 X9.1417 Y2.9070
G1 X9.1702 Y3.0046
G1 X9.2011 Y3.0909
G1 X9.2377 Y3.1755
G1 X9.2824 Y3.2652
G1 X9.3368 Y3.3586
G1 X9.3977 Y3.4506
G1 X9.4534 Y3.5255
G1 X9.5364 Y3.6241
G1 X9.6093 Y3.7013
G1 X9.6990 Y3.7864
G1 X9.7975 Y3.8697
G1 X9.8217 Y3.8877
G1 X9.7711 Y3.7635
G1 X9.7478 Y3.6947
G1 X9.7368 Y3.6558
G1 X9.7211 Y3.5865
G1 X9.7145 Y3.5491
G1 X9.7056 Y3.4801
G1 X9.7025 Y3.4389
G1 X9.7008 Y3.3698
G1 X9.7018 Y3.3274
G1 X9.7076 Y3.2532
G1 X9.7122 Y3.2187
G1 X9.7239 Y3.1506
G1 X9.7335 Y3.1095
G1 X9.7533 Y3.0394
G1 X9.7655 Y3.0046
G1 X9.7914 Y2.9385
G1 X9.8090 Y2.9002
G1 X9.8102 Y2.8974
G1 X9.7808 Y2.8550
G1 X9.7600 Y2.8204
G1 X9.7267 Y2.7600
G1 X9.7094 Y2.7244
G1 X9.6804 Y2.6563
G1 X9.6675 Y2.6203
G1 X9.6472 Y2.5560
G1 X9.6368 Y2.5156
G1 X9.6220 Y2.4432
G1 X9.6164 Y2.4033
G1 X9.6091 Y2.3274
G1 X9.6081 Y2.2868
G1 X9.6093 Y2.1885
G1 X9.6208 Y2.0317
G1 X9.6332 Y1.9393
G1 X9.6639 Y1.7790
G1 X9.6843 Y1.6980
G1 X9.7340 Y1.5344
G1 X9.7625 Y1.4575
G1 X9.8295 Y1.2984
G1 X9.8567 Y1.2426
G1 X9.4214 Y2.0211
G1 X9.3957 Y2.0759
G1 X9.3645 Y2.1554
G1 X9.3434 Y2.2228
G1 X9.3221 Y2.3099
G1 X9.3083 Y2.3901
G1 X9.3002 Y2.4676
G1 X9.2972 Y2.5634
G1 X9.2989 Y2.6215
G1 X9.3078 Y2.7114
G1 X9.3200 Y2.7887
G1 X9.3353 Y2.8567
G1 X9.3604 Y2.9431
G1 X9.3866 Y3.0152
G1 X9.4198 Y3.0924
G1 X9.4582 Y3.1694
G1 X9.5072 Y3.2535
G1 X9.5093 Y3.2271
G1 X9.5151 Y3.1849
G1 X9.5291 Y3.1049
G1 X9.5410 Y3.0551
G1 X9.5646 Y2.9733
G1 X9.5794 Y2.9314
G1 X9.5849 Y2.9174
G1 X9.5847 Y2.9169
G1 X9.5468 Y2.8473
G1 X9.5253 Y2.8026
G1 X9.4922 Y2.7239
G1 X9.4767 Y2.6805
G1 X9.4536 Y2.6060
G1 X9.4407 Y2.5555
G1 X9.4239 Y2.4709
G1 X9.4173 Y2.4227
G1 X9.4092 Y2.3325
G1 X9.4082 Y2.2842
G1 X9.4099 Y2.1740
G1 X9.4214 Y2.0211
; Retract
G1 Z2.0000 F750
; Path 5
G1 X5.5027 Y2.2146 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X5.4968 Y2.1069 F300
G1 X5.4849 Y1.9743
G1 X5.4686 Y1.8529
G1 X5.4465 Y1.7323
G1 X5.4158 Y1.6065
G1 X5.3782 Y1.4846
G1 X5.3332 Y1.3688
G1 X5.2748 Y1.2456
G1 X5.2078 Y1.1290
G1 X5.1293 Y1.0152
G1 X5.0330 Y0.8974
G1 X4.9253 Y0.7861
G1 X4.7945 Y0.6716
G1 X4.6429 Y0.5591
G1 X4.5138 Y0.4747
G1 X4.3782 Y0.3978
G1 X4.2431 Y0.3312
G1 X4.1021 Y0.2710
G1 X3.9596 Y0.2189
G1 X3.8143 Y0.1735
G1 X3.6652 Y0.1341
G1 X3.5103 Y0.0998
G1 X3.3614 Y0.0729
G1 X3.2116 Y0.0511
G1 X3.0498 Y0.0325
G1 X2.9050 Y0.0198
G1 X2.7516 Y0.0104
G1 X2.5989 Y0.0041
G1 X2.4503 Y0.0010
G1 X2.3076 Y-0.0000
G1 X2.1900 Y0.0005
G1 X2.0721 Y0.0020
G1 X1.9510 Y0.0053
G1 X1.8311 Y0.0102
G1 X1.7247 Y0.0160
G1 X1.6012 Y0.0254
G1 X1.4978 Y0.0353
G1 X1.3881 Y0.0488
G1 X1.2670 Y0.0665
G1 X1.1643 Y0.0843
G1 X1.0660 Y0.1049
G1 X0.9472 Y0.1333
G1 X0.8458 Y0.1613
G1 X0.7440 Y0.1930
G1 X0.6360 Y0.2314
G1 X0.5344 Y0.2715
G1 X0.4074 Y0.3299
G1 X0.2723 Y0.3983
G1 X0.1262 Y0.4790
G1 X0.0000 Y0.5542
G1 X0.8837 Y1.2482
G1 X0.9241 Y1.2065
G1 X0.9627 Y1.1709
G1 X1.0790 Y1.0742
G1 X1.1194 Y1.0439
G1 X1.1496 Y1.0251
G1 X1.3068 Y0.9347
G1 X1.3515 Y0.9116
G1 X1.3871 Y0.8974
G1 X1.5547 Y0.8372
G1 X1.6030 Y0.8227
G1 X1.6330 Y0.8161
G1 X1.8148 Y0.7826
G1 X1.8793 Y0.7750
G1 X2.0785 Y0.7645
G1 X2.1283 Y0.7645
G1 X2.3061 Y0.7729
G1 X2.3660 Y0.7793
G1 X2.5367 Y0.8082
G1 X2.5860 Y0.8191
G1 X2.6147 Y0.8280
G1 X2.7783 Y0.8839
G1 X2.8252 Y0.9027
G1 X2.8623 Y0.9215
G1 X3.0190 Y1.0099
G1 X3.0617 Y1.0368
G1 X3.0978 Y1.0650
G1 X3.2151 Y1.1651
G1 X3.2520 Y1.1996
G1 X3.2824 Y1.2349
G1 X3.3721 Y1.3480
G1 X3.4013 Y1.3889
G1 X3.4219 Y1.4239
G1 X3.4877 Y1.5476
G1 X3.5090 Y1.5931
G1 X3.5192 Y1.6200
G1 X3.5644 Y1.7518
G1 X3.5809 Y1.8118
G1 X3.6096 Y1.9489
G1 X3.6170 Y1.9944
G1 X3.6330 Y2.1344
G1 X3.6355 Y2.1669
G1 X3.6429 Y2.3271
G1 X3.6444 Y2.4699
G1 X3.6444 Y7.8425
G1 X5.5067 Y7.8425
G1 X5.5067 Y2.4559
G1 X5.5070 Y2.4559
G1 X5.5060 Y2.3434
G1 X5.5027 Y2.2146
G1 X5.3030 Y2.2255
G1 X5.2977 Y2.1250
G1 X5.2860 Y1.9949
G1 X5.2718 Y1.8890
G1 X5.2504 Y1.7724
G1 X5.2222 Y1.6576
G1 X5.1897 Y1.5517
G1 X5.1486 Y1.4460
G1 X5.0993 Y1.3419
G1 X5.0376 Y1.2344
G1 X4.9698 Y1.1361
G1 X4.8842 Y1.0312
G1 X4.7861 Y0.9301
G1 X4.6683 Y0.8268
G1 X4.5303 Y0.7244
G1 X4.4107 Y0.6462
G1 X4.2822 Y0.5733
G1 X4.1600 Y0.5131
G1 X4.0307 Y0.4580
G1 X3.8913 Y0.4069
G1 X3.7600 Y0.3660
G1 X3.6210 Y0.3292
G1 X3.4707 Y0.2959
G1 X3.3274 Y0.2700
G1 X3.1847 Y0.2492
G1 X3.0284 Y0.2314
G1 X2.8928 Y0.2195
G1 X2.7432 Y0.2103
G1 X2.5905 Y0.2040
G1 X2.4463 Y0.2009
G1 X2.3068 Y0.1999
G1 X2.1925 Y0.2004
G1 X2.0775 Y0.2019
G1 X1.9591 Y0.2052
G1 X1.8392 Y0.2101
G1 X1.7391 Y0.2154
G1 X1.6203 Y0.2245
G1 X1.5222 Y0.2339
G1 X1.4125 Y0.2474
G1 X1.3005 Y0.2637
G1 X1.2029 Y0.2807
G1 X1.1092 Y0.3002
G1 X0.9949 Y0.3277
G1 X0.9045 Y0.3526
G1 X0.8072 Y0.3828
G1 X0.7031 Y0.4199
G1 X0.6134 Y0.4552
G1 X0.4973 Y0.5085
G1 X0.3645 Y0.5758
G1 X0.3566 Y0.5801
G1 X0.8730 Y0.9855
G1 X0.9591 Y0.9141
G1 X0.9995 Y0.8839
G1 X1.0137 Y0.8740
G1 X1.0498 Y0.8517
G1 X1.2149 Y0.7572
G1 X1.2596 Y0.7341
G1 X1.2774 Y0.7259
G1 X1.3195 Y0.7092
G1 X1.4973 Y0.6457
G1 X1.5601 Y0.6274
G1 X1.5966 Y0.6195
G1 X1.7915 Y0.5839
G1 X1.8689 Y0.5753
G1 X2.0785 Y0.5646
G1 X2.1377 Y0.5646
G1 X2.3271 Y0.5740
G1 X2.3995 Y0.5822
G1 X2.5799 Y0.6129
G1 X2.6292 Y0.6238
G1 X2.6452 Y0.6281
G1 X2.6794 Y0.6388
G1 X2.8524 Y0.6982
G1 X2.8994 Y0.7170
G1 X2.9157 Y0.7244
G1 X2.9606 Y0.7473
G1 X3.1257 Y0.8407
G1 X3.1684 Y0.8677
G1 X3.1849 Y0.8793
G1 X3.2276 Y0.9129
G1 X3.3520 Y1.0193
G1 X3.3889 Y1.0538
G1 X3.4033 Y1.0688
G1 X3.4392 Y1.1107
G1 X3.5349 Y1.2316
G1 X3.5641 Y1.2725
G1 X3.5738 Y1.2875
G1 X3.5984 Y1.3299
G1 X3.6688 Y1.4625
G1 X3.6962 Y1.5225
G1 X3.7084 Y1.5552
G1 X3.7572 Y1.6988
G1 X3.7767 Y1.7709
G1 X3.8070 Y1.9169
G1 X3.8156 Y1.9718
G1 X3.8324 Y2.1189
G1 X3.8354 Y2.1577
G1 X3.8428 Y2.3251
G1 X3.8443 Y2.4699
G1 X3.8443 Y7.6426
G1 X5.3068 Y7.6426
G1 X5.3068 Y2.4559
G1 X5.3071 Y2.4531
G1 X5.3061 Y2.3485
G1 X5.3030 Y2.2255
G1 X5.1034 Y2.2362
G1 X5.0983 Y2.1392
G1 X5.0871 Y2.0168
G1 X5.0749 Y1.9251
G1 X5.0546 Y1.8138
G1 X5.0292 Y1.7104
G1 X5.0008 Y1.6177
G1 X4.9647 Y1.5250
G1 X4.9215 Y1.4341
G1 X4.8687 Y1.3419
G1 X4.8103 Y1.2570
G1 X4.7341 Y1.1636
G1 X4.6487 Y1.0754
G1 X4.5418 Y0.9820
G1 X4.4188 Y0.8905
G1 X4.3061 Y0.8166
G1 X4.1880 Y0.7498
G1 X4.0770 Y0.6949
G1 X3.9568 Y0.6439
G1 X3.8293 Y0.5972
G1 X3.7033 Y0.5578
G1 X3.5751 Y0.5240
G1 X3.4310 Y0.4920
G1 X3.2934 Y0.4671
G1 X3.1570 Y0.4473
G1 X3.0081 Y0.4303
G1 X2.8806 Y0.4191
G1 X2.7348 Y0.4102
G1 X2.5822 Y0.4039
G1 X2.5367 Y0.4028
G1 X2.6231 Y0.4176
G1 X2.6812 Y0.4308
G1 X2.7046 Y0.4371
G1 X2.7445 Y0.4496
G1 X2.9266 Y0.5126
G1 X2.9820 Y0.5349
G1 X3.0063 Y0.5461
G1 X3.0592 Y0.5733
G1 X3.2324 Y0.6716
G1 X3.2840 Y0.7043
G1 X3.3084 Y0.7221
G1 X3.3576 Y0.7610
G1 X3.4889 Y0.8735
G1 X3.5326 Y0.9149
G1 X3.5555 Y0.9388
G1 X3.5959 Y0.9865
G1 X3.6977 Y1.1153
G1 X3.7323 Y1.1643
G1 X3.7468 Y1.1872
G1 X3.7752 Y1.2362
G1 X3.8506 Y1.3792
G1 X3.8837 Y1.4526
G1 X3.8979 Y1.4910
G1 X3.9502 Y1.6464
G1 X3.9726 Y1.7302
G1 X4.0046 Y1.8859
G1 X4.0142 Y1.9492
G1 X4.0317 Y2.1031
G1 X4.0353 Y2.1488
G1 X4.0427 Y2.3231
G1 X4.0442 Y2.4699
G1 X4.0442 Y7.4427
G1 X5.1069 Y7.4427
G1 X5.1069 Y2.4559
G1 X5.1072 Y2.4508
G1 X5.1062 Y2.3536
G1 X5.1034 Y2.2362
G1 X4.9037 Y2.2466
G1 X4.8992 Y2.1575
G1 X4.8887 Y2.0432
G1 X4.8771 Y1.9553
G1 X4.8588 Y1.8560
G1 X4.8362 Y1.7633
G1 X4.8113 Y1.6825
G1 X4.7808 Y1.6038
G1 X4.7437 Y1.5260
G1 X4.7010 Y1.4511
G1 X4.6490 Y1.3757
G1 X4.5852 Y1.2974
G1 X4.5098 Y1.2197
G1 X4.4166 Y1.1382
G1 X4.3056 Y1.0556
G1 X4.1994 Y0.9860
G1 X4.0955 Y0.9274
G1 X3.9942 Y0.8771
G1 X3.8806 Y0.8288
G1 X3.7686 Y0.7879
G1 X3.6505 Y0.7508
G1 X3.6772 Y0.7765
G1 X3.7081 Y0.8098
G1 X3.7529 Y0.8626
G1 X3.8613 Y1.0000
G1 X3.9012 Y1.0574
G1 X3.9197 Y1.0869
G1 X3.9520 Y1.1430
G1 X4.0330 Y1.2972
G1 X4.0711 Y1.3830
G1 X4.0874 Y1.4272
G1 X4.1435 Y1.5949
G1 X4.1684 Y1.6899
G1 X4.2022 Y1.8557
G1 X4.2128 Y1.9266
G1 X4.2311 Y2.0876
G1 X4.2352 Y2.1405
G1 X4.2426 Y2.3211
G1 X4.2441 Y2.4699
G1 X4.2441 Y7.2428
G1 X4.9070 Y7.2428
G1 X4.9073 Y2.4529
G1 X4.9063 Y2.3584
G1 X4.9037 Y2.2466
G1 X4.7041 Y2.2568
G1 X4.7000 Y2.1755
G1 X4.6904 Y2.0696
G1 X4.6787 Y1.9827
G1 X4.6639 Y1.9017
G1 X4.6426 Y1.8141
G1 X4.6223 Y1.7483
G1 X4.5979 Y1.6850
G1 X4.5659 Y1.6177
G1 X4.5314 Y1.5573
G1 X4.4882 Y1.4948
G1 X4.4364 Y1.4310
G1 X4.3726 Y1.3655
G1 X4.2913 Y1.2944
G1 X4.2304 Y1.2489
G1 X4.2588 Y1.3139
G1 X4.2771 Y1.3637
G1 X4.3371 Y1.5441
G1 X4.3645 Y1.6500
G1 X4.4000 Y1.8260
G1 X4.4115 Y1.9040
G1 X4.4305 Y2.0724
G1 X4.4351 Y2.1323
G1 X4.4425 Y2.3190
G1 X4.4440 Y2.4699
G1 X4.4440 Y7.0429
G1 X4.7071 Y7.0429
G1 X4.7074 Y2.4549
G1 X4.7064 Y2.3630
G1 X4.7041 Y2.2568
; Retract
G1 Z2.0000 F750
; Path 6
G1 X1.4917 Y0.4394 F750
G1 Z0.0000
; plunge
G1 Z-1.2500 F50
; cut
G1 X1.4369 Y0.4460 F300
G1 X1.4369 Y0.4458
G1 X1.3348 Y0.4608
G1 X1.2403 Y0.4773
G1 X1.1544 Y0.4953
G1 X1.0417 Y0.5222
G1 X0.9632 Y0.5438
G1 X0.8705 Y0.5725
G1 X0.7732 Y0.6073
G1 X0.7343 Y0.6226
G1 X0.8715 Y0.7302
G1 X0.8852 Y0.7198
G1 X0.9083 Y0.7041
G1 X0.9505 Y0.6782
G1 X1.1229 Y0.5796
G1 X1.1765 Y0.5522
G1 X1.2035 Y0.5400
G1 X1.2522 Y0.5207
G1 X1.4415 Y0.4536
G1 X1.4917 Y0.4394
; Retract
G1 Z2.0000 F750
; Return to 0,0
G0 X0 Y0 F750
M2
05 Sep 2020 17:37 - 05 Sep 2020 17:40 #180816 by Mud
Replied by Mud on topic Z axis cuts in the air - not plunging
Hi Mike
Regards
Yes, the tool moving toward the work should make z more negative (it's a right-handed coordinate system). Assuming you have 4 wire stepper motors, swap two of the wires (on a single coil) and it will go the other way. You will need to reverse the conventions in your INI for that axis.
Edit: there's a typo here:
OME_FINAL_VEL = 2
HOME_SEQUENCE = 0
Last edit: 05 Sep 2020 17:40 by Mud.
05 Sep 2020 17:40 - 05 Sep 2020 17:43 #180817 by Clive S
Re this
HOME = 0
HOME_OFFSET = -64 I would set this as -1
OME_FINAL_VEL = 2 This has a missing H
HOME_SEQUENCE = 0
SCALE = 2000.0 you might have to reverse the motor it can be done by putting a - before the 2000 ie. SCALE = -2000.0
Last edit: 05 Sep 2020 17:43 by Clive S.
  • Jeff65
  • Junior Member
  • Junior Member
05 Sep 2020 17:42 #180818 by Jeff65
Only 3 steppers for the axis - at the moment the spindle is a separate systemI will have a go at your suggestion and see what happens.
I have found that if I change something on one axis it can affect the other 2 axis - how can I stop that happening?
05 Sep 2020 17:46 - 05 Sep 2020 17:47 #180819 by Clive S
Are you editing the file manually or using stepconf . You should not be using stepconf as it will overwrite what you have changed
when you jog down with the page down key the it should go -ve
Last edit: 05 Sep 2020 17:47 by Clive S.
  • Jeff65
  • Junior Member
  • Junior Member
05 Sep 2020 17:47 #180820 by Jeff65
Sorry misunderstood there - you mean there is 4 wires for each motor - yes that's right. How do I know which 2 wires to swop?
Time to create page: 0.153 seconds
