Z axis cuts in the air - not plunging
  • Jeff65
  • Jeff65's Avatar Topic Author
  • Junior Member
  • Junior Member
06 Sep 2020 09:15 #180916 by Jeff65
Replied by Jeff65 on topic Z axis cuts in the air - not plunging
OK will do some stuff soon but I have lots of things happening here - family and kids etc
will get a breathing space soon
06 Sep 2020 09:18 - 06 Sep 2020 11:23 #180918 by Clive S
Replied by Clive S on topic Z axis cuts in the air - not plunging
I take it that you do reload the axis after you make changes to the ini file
Last edit: 06 Sep 2020 11:23 by Clive S.
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 09:29 #180920 by Jeff65
When you say reload - do you mean 'homing'
I haven't been able to home since everything went to pot
06 Sep 2020 09:34 #180922 by Clive S
No. when you edit any files you need to restart linuxcnc. Not the PC
Forget homing until you have the z axis searching in the correct direction to the switch
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 09:36 #180923 by Jeff65
OK - I did those 2 changes and homed the Z axis and it homed ok
pressing page up makes the spindle go down and page down goes up
But the screen motion is correct
I know how to re set the keys on the key board so thats not a problem to me
06 Sep 2020 09:44 #180925 by Clive S
That's strange where is your homing switch located should be at the top.
06 Sep 2020 09:44 #180926 by Mike_Eitel
Replied by Mike_Eitel on topic Z axis cuts in the air - not plunging
When it comes to the keys.
They are always "connected" to the workpeace, not to the machine. Means f.x. you press the left arrow, table moves to the right. = your tool will make his way into the peace direction left..... You will get used to that ;-)
06 Sep 2020 09:46 #180927 by Mike_Eitel
I have no home on z at all... I think you only need that it you can work with fixed tool lenght. I use only z-min as safety shut off.
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 09:47 #180928 by Jeff65
yeah switch is at the top
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 09:52 #180930 by Jeff65
I thought homing was necessary so the machine knows where it is in the real world - as it were
Time to create page: 0.169 seconds
