Z axis cuts in the air - not plunging
06 Sep 2020 09:54 #180931 by Clive S
Replied by Clive S on topic Z axis cuts in the air - not plunging
yeah switch is at the top
Ok on a fresh start of linuxcnc I think what you are saying is that when jogging Z before homing page down z goes down, then when you home its start going up to the switch then backs off it. But then you are saying that Z goes down with page up is that correct.
  • Jeff65
  • Jeff65's Avatar Topic Author
  • Junior Member
  • Junior Member
06 Sep 2020 10:07 #180934 by Jeff65
Replied by Jeff65 on topic Z axis cuts in the air - not plunging
No -fresh start of Linuxcnc - before homing - page up makes it goes down
page down makes it go up.
After homing - same thing
06 Sep 2020 10:18 #180937 by Clive S
But you said
At the moment the Z axis is moving the way it should - page up it goes up and page down it goes down and on the screen the same is apparent.
Its just when i try to home it goes off in the wrong direction
please just post the z section of the ini file
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 10:24 #180940 by Jeff65
Z axis part of ini file
[AXIS_2]
TYPE = LINEAR
HOME = 0
MAX_VELOCITY = 12.5492060976
MAX_ACCELERATION = 13.0
STEPGEN_MAXACCEL = 16.25
SCALE = 2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -75
MAX_LIMIT = 0.001
HOME_OFFSET = -2
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = 0.050000
HOME_FINAL_VEL = 2
HOME_SEQUENCE = 0
06 Sep 2020 10:32 #180943 by Clive S
[AXIS_2]
TYPE = LINEAR
HOME = 0
SCALE = 2000.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -75
MAX_LIMIT = 0.001
HOME_OFFSET = -2
HOME_FINAL_VEL = 2
HOME_SEQUENCE = 0
Ok you have not changed what I suggested.
So start from scratch changed change the SCALE to -2000
save the file and restart linucnc then if the z goes up with page up that should be good.
If it does And when trying to home it moves in the wrong direction changed the sign here HOME_SEARCH_VEL = -1.000000
I know its frustrating but you will get there and have learnt what the things do in the ini file
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 10:47 - 06 Sep 2020 10:49 #180948 by Jeff65
Sorry - I can be a bit dim sometimes.
OK - I put a minus in front of the Scale setting - now if I press page up it goes up and if i press page down it goes down
However it is now reversed on the screen - goes down when you press page up - up when page down is pressed
Tried homing the axis and it goes in the wrong direction.
So I changed the sign in front of HOME_SEARCH_VEL
page up and down still worked fine but on screen was reversed.
It seemed to home ok - but cannot jog the axis down but it will go a little way up- screen problem still there
Last edit: 06 Sep 2020 10:49 by Jeff65. Reason: another error
06 Sep 2020 10:56 - 06 Sep 2020 11:24 #180952 by Clive S
Ok not sure what to do about the screen BUT if it is not a pain I would change the SCALE sign back and reverse the motor wires.
You can do that on the drive just swap over either A or B but not both.
And see if the screen is ok
Last edit: 06 Sep 2020 11:24 by Clive S.
06 Sep 2020 10:59 #180956 by rodw
Replied by rodw on topic Z axis cuts in the air - not plunging
Also, don't use a negative value for home sequence. That is reserved for joint axes. eg. a gantry machine with 2 motors on one axis. Don't give up homing your machine as you start up. Its a very good habit to get into.
  • Jeff65
  • Junior Member
  • Junior Member
06 Sep 2020 11:05 #180958 by Jeff65
I have played about with settings many times and never got sorted - so I thought I would join this forum and I'm very grateful for your help.
I have already swopped wires on this stepper motor - I can swop them back
Would be happy to talk on the phone if you have the time
I would think its critical to have the screen match up with the motion otherwise I'll be cutting only air again
06 Sep 2020 11:13 - 06 Sep 2020 11:15 #180961 by Clive S
I know you changed them before but we are starting again
Last edit: 06 Sep 2020 11:15 by Clive S.
Time to create page: 0.278 seconds
