7i96 configuration Tool and Gantry XYZ Machines
03 Jan 2022 04:34 #230621 by SSIRon
RNJFAB could i have your ini and hal files. i would like to review them.
I am using the 7i96 and 7i85 is that what you are using
03 Jan 2022 09:48 #230637 by RNJFAB
Hey,
I uploaded my most recent ini/hal files here the other day.
forum.linuxcnc.org/show-your-stuff/42411...cnc?start=170#230517
I used the config when I set mine up. x, y, tandem y, z.
I'm running a MESA 7i96. and using a THCAD10 for the THC with a Unimig Razor Cut45 Plasma.
04 Jan 2022 05:39 #230721 by SSIRon
RNJFAB - thanks so much.  i appreciate this.  thank you tommylight
04 Jan 2022 07:20 #230726 by RNJFAB
No worries, did you get it all working ?
04 Jan 2022 17:43 #230782 by SSIRon
Maybe later today.  I have to find a block of time where i got one thing to focus on.  My own worst enemy
05 Jan 2022 09:41 - 05 Jan 2022 09:42 #230848 by RNJFAB
Cool, I'll be back down in the shed soon, so I'll keep an eye on this while I'm working.
Take some screen shots while you do the config as this may help out if there is something a miss.
Cheers
Last edit: 05 Jan 2022 09:42 by RNJFAB.
05 Jan 2022 23:34 #230910 by BigJohnT
Just to be clear you have a gantry machine with dual X motors and a U axis?
I can look into it in the morning but can not test as I'm out of 7i96 cards.
JT
06 Jan 2022 20:15 #230984 by SSIRon
BigJohnT
I have dual Motors on the x which is a gantry.  i thought the 2nd x was to be done with the u or a axis but i am understanding now that i can have a second x axis.  So it is a xxyz machine.  I may add a rotary axis down the road but that is later.   I am going to try some more  today.  However i may get shut down as we had a major snow fall and powder maybe a little flaky today.
06 Jan 2022 21:35 #230990 by tommylight
Replied by tommylight on topic 7i96 configuration Tool and Gantry XYZ Machines
Gantry machines can not use UVW axis as a tandem axis (well they and it can, but not preferred).
Why am i getting a "deja vue" on this subject? Maybe not enough sleep...
Setting up a tandem machine is easy using the provided wizards, ...
I'll stop here as i am not sure what topic with a similar topic was answered already.
06 Jan 2022 23:49 - 06 Jan 2022 23:50 #231000 by BigJohnT
Yes, a gantry uses two joints with the same axis so just define the two joints with x and you should be good to go.
Tommy go take a nap!
JT
Last edit: 06 Jan 2022 23:50 by BigJohnT.
Time to create page: 0.320 seconds
