- Thank you received: 297
All good! I can now park the gantry anywhere I want after homing and both Y1 & Y2 move in tandem.ok -- i've reverted the suspicious commit
if you built from git, you must rebuild
if you used buildbot deb, it usually takes a few hours
Thank you!
Sure. That is my current *.ini fileWould you mind submitting the portion of the ini file again re: the homing?
