- Thank you received: 486
HOME_SEQUENCE = -2 ( this is fine for both Y joints)
That does not agree with the docs which state:
The initial HOME_SEQUENCE number may be 0, 1 (or -1). The absolute value of sequence numbers must increment by one — skipping sequence numbers is not supported. If a sequence number is omitted, HOME ALL homing will stop upon completion of the last valid sequence number.
Ref: linuxcnc.org/docs/devel/html/config/ini-...tml#_homing_sequence
I am not sure that it does. It seems that the final moves to home happen separately.That looks perfectly normal.
