Skew correction/perpendicularity correction (millkins or millkins_xyz)
2 years 3 weeks ago #311348 by Aciera
Looks like I already ported this kinematic so maybe try the one attached to this earlier post:
forum.linuxcnc.org/49-basic-configuratio...s-xyz?start=0#280714
The following user(s) said Thank You: abdulasis12
2 years 3 weeks ago #311353 by upplib
I did the whole thing again and millkins now works. Thanks Aciera.
Thanks itsbrian!!
added
KINS_NOT_SWITCHABLE
to the instructions provided by itsbrian. Version 2.9.3
I was able to see the skew in halconfiguration, able to make some tweaks to skew and it looks it is running square to x-axis.
The following user(s) said Thank You: itsbrian
1 year 11 months ago #315618 by abdulasis12
Hi
I want somebody help
I think now my CNC problem seem this topic.
My CNC XYZ  and Y correct  linear move
my X axis table on Y-axis base it's Skewed angle .
I D/L this file from MR.Aciera
I open terminal and compile file
asis@192:~/Downloads/skewkins$ sudo halcompile --install skewkins.comp
[sudo] password for asis:
Compiling realtime skewkins.c
Linking skewkins.so
cp skewkins.so /usr/lib/linuxcnc/modules/
I open hal
#loadrt [KINS]KINEMATICS
loadrt skewkins
setp skewkins.skew 0.01
I open ini
[KINS]
JOINTS = 4
KINEMATICS = skewkins
this problem when run linuxcnc
Debug file information:
Note: Using POSIX realtime
./217-4x.hal:7: parameter or pin 'skewkins.skew' not found
9192
Stopping realtime threads
Unloading hal components
what i'm wrong ?
Asis,
1 year 11 months ago #315627 by Aciera
that kinematic does not have a pin called 'skewkins.skew'. Try 'skewkins.skew-y':
1 year 10 months ago #315779 by abdulasis12
Hi Aciera
Thank you,  Now look its working  when jog   I will  caribrate my cnc new again.
this unit is angle ?
Thank you, image missing /media/kunena/emoticons/smile.png
Asis
1 year 10 months ago - 1 year 10 months ago #315783 by Aciera
It's a ratio. units of skew in Y  per unit of travel in X. If you set 'skew-y' to 0.1 then moving the y-axis in the positive direction will have the x-axis move 0.1 units in the negative direction for every unit of y-travel.
j [0] = pos->tran.x - pos->tran.y*(*(haldata->skew_y)) - pos->tran.z*(*(haldata->skew_xz)); j [1] = pos->tran.y - pos->tran.z*(*(haldata->skew_yz)); j [2] = pos->tran.z;
Last edit: 1 year 10 months ago by Aciera.
The following user(s) said Thank You: tommylight, abdulasis12
Time to create page: 0.367 seconds
