Skew correction/perpendicularity correction (millkins or millkins_xyz)
1 year 10 months ago #317025 by abdulasis12
Hi
I have question.I would like to know if I can use skewkins together with xyzac-trt-kins. If it is possible to use them together, what steps do I need to take? Please provide me with some guidance.
Thank you,
Asis
1 year 10 months ago #317031 by Aciera
You would need to add the 'skew-y' pin and the corrective terms to the forward and inverse kinematic models of the xyzac-trt kins.
1 year 10 months ago #317035 by abdulasis12
This I understand.
This is hard for me , not understand.
Now I open .hal of xyzbc and i add
loadrt skewkins
before line
loadrt xyzbc-trt-kins sparm=identityfirst
try to run linuxcnc and error  :
<commandline>:0: Pin 'motion.switchkins-type' does not exist
INI file HAL command net :kinstype-select <= motion.analog-out-03 => motion.switchkins-type failed.
Could you please guide me? I am ready to learn it
Thank you,
Asis
1 year 10 months ago - 1 year 10 months ago #317038 by Aciera
you have to build the skew function into the xyzbc-trt kinematics file and recompile it.
github.com/LinuxCNC/linuxcnc/blob/master...inematics/trtfuncs.c
Last edit: 1 year 10 months ago by Aciera.
The following user(s) said Thank You: abdulasis12
1 year 10 months ago #317040 by abdulasis12
Hi MR.Aciera
Thank you, for fast reply .
maybe I will use a lot time for learn it to combine code  it's new for me (java right ?) but I will try first. image missing /media/kunena/emoticons/smile.png
Thank you,
Asis
1 year 10 months ago - 1 year 10 months ago #317041 by Aciera
