Skew correction/perpendicularity correction (millkins or millkins_xyz)
1 year 10 months ago #317373 by Aciera
There is a problem with linebreaks in the code above from pasting. I'll post the file tomorrow. Or you can fix it in a text editor in the mean time.
1 year 10 months ago #317382 by abdulasis12
Hi Aciera,
Thank you for reply.
Update......
Now I delete  " ; "    and try  again.
result is  no error about   " ; "
but error   "syntax error in VERSION script"
Thank you,
Asis
1 year 10 months ago #317391 by Aciera
That's what I expected. As a workaround you can build linuxcnc on your computer:
linuxcnc.org/docs/master/html/code/building-linuxcnc.html
The following user(s) said Thank You: abdulasis12
1 year 10 months ago #317410 by abdulasis12
Hi Aciera
I use this
$ git clone github.com/LinuxCNC/linuxcnc.git linuxcnc-source-dir
$ cd linuxcnc-source-dir/src
and I replace file trtfuncs.c  (inside skew func) on this step (correct right ?)
Then, cmd :
$ ./autogen.sh
$ ./configure --with-realtime=uspace
it's look good  and I use  cmd : $ make
it's loading and show in picture attach file  , this not complete compile right ?
Error :
/bin/bash: line 1: a2x: command not found
make: * [../docs/src/Submakefile:1001: ../docs/man/man1/5axisgui.1] Error 127
How to solve this problem ?
I think it's near succes with your help ^^"
Thank you,
Asis
1 year 10 months ago #317412 by Aciera
you need to install the build dependencies. See 4.2.2 in the linked documentation above.
1 year 10 months ago #317417 by abdulasis12
I think now it's success compile.
then I cmd : sudo make setuid
I try open sim xyzbc-trt-kins
I'm open hallshow and click to check inside pin--> xyzbc-trt-kins   but not have show pin skew-y
have any step ?
Thank you,
Asis
Time to create page: 0.412 seconds
