Spindle control not showing in Axis window...
1 year 6 months ago #325836 by tommylight
Start with the HAL part, that is what most people seem to be scared of, but it was and is the main reason why i liked LinuxCNC as you can do almost anything with it, within reason.
And then there is components, plenty of those included and the ability to write your own to fit your needs, so the possibilities are nearly endless.
As for 342 pages, nah, i'we read much longer not enjoyable, while this was very, very enjoyable/interesting.
It opens a whole new world of possibilities.
Does the Z have limit/home switches?
1 year 6 months ago - 1 year 6 months ago #325846 by rodw
Just a heads up. Tommy's link is to Linuxcnc v 2.6 and our release version is now 2.9 so it will be obsolete in places.
The PDF files are available from the Documention page but are just a copy of the content in the HTML version which I tend to use in preference,
But none the less I too was gobsmacked when starting off to find the documentation runs to 1347 pages!
2.9 version: linuxcnc.org/docs/stable/pdf/LinuxCNC_Documentation.pdf
Last edit: 1 year 6 months ago by rodw.
1 year 6 months ago #325847 by tommylight
Oh so those are now all in one file?
There were 3 back then, quick start, documentation and integrator's manual.
I recall thinking "how is this software under 5MB in size while documentation is nearly 30MB???"
Good times.
1 year 6 months ago #325873 by andypugh
Yet people still sometimes complain that there isn't enough documentation....
And it's true, I think. For example we really could so with a section on toolchangers.
1 year 6 months ago #325887 by rodw
And Ethercat now it can be installed without breaching licenses
And how to optimise later distributions
1 year 6 months ago #325957 by irwinger
Back to the 'knowledge well'... sigh.
What I CAN do:
I have my motion control working (I can job X, Y and Z in the correct directions - or at least in the directions I want them to move when pushing the +/- buttons).
     - I had to 'reverse' the homing direction of my X and Y axes in the INI file, changing the lines:
       HOME_SEARCH_VEL = -0.050000  ; changed 0.050000 to -0.050000
I have my spindle control working - I can turn the spindle on and off from the Axis UI
I have my home/limit switches working - I can 'home' my X & Y (I don't have Z-axis home/limit switches)
     - the 'home' symbol shows in the DRO section of the Axis UI
What I CANNOT do:
1) I cannot 'touch-off' any of my axes. I homed all axes, jog my router off of the Home position, click the 'Touch Off' button and leave the defaults as presented, click the 'OK' button and immediately get an error stating "Can't issue MDI command when not homed. This of course also translates to my MDI (F5) screen when I attempt to move the router around using the G0 command
     - I am somehow way out of 'scale' with motion - I was planning on using the MDI interface to specify G-Code moves and measure results. Of course I immediately got the "Can't issue MDI..." error so I returned to the 'Manual' tab to ensure I was homed... which I was.
     - At this point, 'eyeballing' alignment with marks on the wasteboard, a 5" move shows as ~1.25" on the DRO in the X dimension. I'm guessing Y will be the same - but Z will be different because it uses a different Acme threaded rod.
I did try to find a solution in the 1347 pages of the manual... but that document is just absolutely overwhelming. In fact - I tried going through it again, one more time before I pushed 'submit' on this post (I DID realize that at least part of my motion scaling issue is my INI configuration). I even read the 'history' this time and realized that LinuxCNC emerged from a NIST project that was based on Windows NT... if ONLY the guys that were first involved would have stayed there (insert joking face emoji here).
If you want me to repost this as a new thread with a new title - I am happy to do it.
Time to create page: 0.461 seconds
