machine parameter conversion from mach3 to emc2
- marcopiai
16 Sep 2012 10:20 #24300
by marcopiai
machine parameter conversion from mach3 to emc2 was created by marcopiai
Hi at All,
I'm new in this forum.
I have search for a lot, but I naven't find a really answer at my question.
i have a cnc machine with mach3 software, I would like to try to use it with emc2.
I have the xml file of the machine settings and I'm searching a converter to create an emc configuration file.
in the forum, at topic www.linuxcnc.org/index.php/english/compo...ew&catid=16&id=21534 I have read that: BigJohnT have made the conversion.
Can BigJohnT or anyone help me in the conversion?
Many thanks in advance.
Marco Piai
Marco Piai
The topic has been locked.
- BigJohnT
- Thank you received: 1176
16 Sep 2012 11:56 #24302
by BigJohnT
Replied by BigJohnT on topic Re:machine parameter conversion from mach3 to emc2
I can convert your xml file if it is a simple machine like a 3 axis mill. The conversion is done from your xml file to a stepconf wizard xml so it has to fit within the limits of the stepconf wizard.
How many axis do you have?
And attach your xml file and I'll convert it.
- marcopiai
16 Sep 2012 12:34 #24304
by marcopiai
Replied by marcopiai on topic Re:machine parameter conversion from mach3 to emc2
GREAT !!!
you are a king man
I'm a very simple cnc machine with only 3 axis and one motor
I attach the xml config file
I am indebted to you with a beer...
Marco Piai
you are a king man
Marco Piai
- BigJohnT
16 Sep 2012 14:16 - 16 Sep 2012 14:17 #24305
by BigJohnT
Here you go, just follow the instructions in the readme file... the conversion seemed to go well.
Last edit: 16 Sep 2012 14:17 by BigJohnT.
The following user(s) said Thank You: Alvaro
- marcopiai
16 Sep 2012 16:10 #24310
by marcopiai
Many many thanks
Now i will go to test and if my cnc work fine with emc2 i will abandon mach3in favor of emc2
Marco Piai
Marco Piai
- BigJohnT
16 Sep 2012 16:43 #24311
by BigJohnT
Don't forget to do a latency test on your PC.
- hill_capitol
28 Oct 2012 20:26 #25939
by hill_capitol
Replied by hill_capitol on topic Re:machine parameter conversion from mach3 to emc2
I'm attaching a Mach3 xml file that I would like to have converted.
Thank you.
Thank you.
- BigJohnT
28 Oct 2012 21:23 #25941
by BigJohnT
There you go...
- alromh87
03 Dec 2012 23:24 #27142
by alromh87
Replied by alromh87 on topic machine parameter conversion from mach3 to emc2
Could you help me translate this file?
Also, can the translating software be downloaded or is there any documentation about how to translate params.
I am unsure on how to get th times needed for hold, step, etc..
- BigJohnT
03 Dec 2012 23:47 - 04 Dec 2012 01:12 #27143
by BigJohnT
Replied by BigJohnT on topic machine parameter conversion from mach3 to emc2
How many axes does that have?
The conversion software I wrote is for the Stepconf Wizard which only does up to 4 axis mill configuration.
Edit: I attached the converted file. If your using a non standard parallel port address you might have to tweak that.
It's amazing how much bloat is in the Mach xml file... look at the difference in file size.
Last edit: 04 Dec 2012 01:12 by BigJohnT.
The following user(s) said Thank You: alromh87
