machine parameter conversion from mach3 to emc2
- djb204
09 Mar 2013 23:57 #31139
by djb204
Replied by djb204 on topic machine parameter conversion from mach3 to emc2
Hi
I try tonight or tommorow, I leave a message after test.
Thank you John for it, it's very nice !
See you later ....
Joseph
See you later ....
Joseph
The topic has been locked.
- bjames28
27 Mar 2013 21:23 #31970
by bjames28
Replied by bjames28 on topic machine parameter conversion from mach3 to emc2
Hi John,
Would you be so kind to translate my xml to StepConf ?
my xml
Thank you for your assistance in advance.
Best regards:
James
my xml
Best regards:
James
- BigJohnT
- Thank you received: 1176
27 Mar 2013 22:44 #31973
by BigJohnT
It is best to name your xml file the same as your configuration and compress your xml file and attach with the Add File button.
Here you go.
Replied by BigJohnT on topic machine parameter conversion from mach3 to emc2
Hi John,
my xml
Best regards:
James
Here you go.
The following user(s) said Thank You: bjames28
- bjames28
29 Mar 2013 12:16 #32021
by bjames28
Hi John,
Thank you for the config. Sorry for the inconvenience caused by the naming and upload method.
Would it be possible to get the tool you use for conversion from Mach XML to StepConf? I suppose it could not be polished or perfect yet, but would be good to learn how different parameters are matched and converted. Purely for personal "educational" purposes.
Best regards:
James
Best regards:
James
- BigJohnT
29 Mar 2013 18:08 - 30 Mar 2013 17:35 #32033
by BigJohnT
It's just a python script that reads in the xml file and creates the stepconf xml file from the entries it finds.
Last edit: 30 Mar 2013 17:35 by BigJohnT.
- bjames28
30 Mar 2013 00:23 #32054
by bjames28
Hi John,
I get an "Internal Server Error" when I want to download the attached zip and of course nothing is downloaded.
Maybe just renaming it to "mark.zip" would work ...
Regards:
James
Regards:
James
- BigJohnT
30 Mar 2013 17:36 #32090
by BigJohnT
Odd but changing the name an uploading again worked. I sure am glad the LinuxCNC software isn't as buggy as the forum software!
- Cer_Matt
08 Aug 2013 23:42 #37502
by Cer_Matt
Replied by Cer_Matt on topic machine parameter conversion from mach3 to emc2
Hi John,
I bought a simple 3 axis cnc mill machine with mach3 software, now I would like to use it with linuxcnc.
Would you be so kind to translate my xml to StepConf?
Thank you for your help in advance!
Matt
p.s. Since there are three xml files in Mach3 folder, I hope this one is correct.
Matt
- BigJohnT
09 Aug 2013 00:01 #37503
by BigJohnT
Looks like Mach3Mill.xml is a standard name so I renamed yours Mach3MillCM.
JT
JT
The following user(s) said Thank You: Cer_Matt
- Cer_Matt
09 Aug 2013 00:48 #37504
by Cer_Matt
Thank you for your quick reply!
Matt
Matt
Time to create page: 0.075 seconds
