machine parameter conversion from mach3 to emc2
- BigJohnT
- Thank you received: 1176
05 Mar 2015 20:05 #56500
by BigJohnT
Replied by BigJohnT on topic machine parameter conversion from mach3 to emc2
Can you compress the file into a zip format? I have limited download.
JT
JT
The topic has been locked.
- madguernseyboy
06 Mar 2015 07:13 #56508
by madguernseyboy
Replied by madguernseyboy on topic machine parameter conversion from mach3 to emc2
Im sorry
is this better?
thanks
Brendan
is this better?
thanks
Brendan
- BigJohnT
06 Mar 2015 19:52 #56511
by BigJohnT
Yea, even with two copies of the xml it was 1/4 the size of the original xml.
JT
JT
The following user(s) said Thank You: madguernseyboy
- BigJohnT
06 Mar 2015 20:04 #56513
by BigJohnT
Please use the sticky post in this section to add Mach files to.
JT
JT
The following user(s) said Thank You: pari
Time to create page: 0.093 seconds
