machine parameter conversion from mach3 to emc2
- terabyte
14 Oct 2013 05:28 #39815
by terabyte
Replied by terabyte on topic machine parameter conversion from mach3 to emc2
Hey BigJohnT. I like others have a kit from CNC Router Parts and I have no interest in using Mach3, I have the upgraded version with the PMDX-126 and Nema 34 motors. This is a 3 axis machine with 4 motors total.
Do you think you could please convert the attached xml file?
In Linux CNC should I just create a new file with the stepconf wizard and then over right the file with the one you convert?
Sorry for the noob questions, this is my first CNC machine.
The topic has been locked.
- BigJohnT
- Thank you received: 1176
14 Oct 2013 18:50 - 14 Oct 2013 18:50 #39830
by BigJohnT
Replied by BigJohnT on topic machine parameter conversion from mach3 to emc2
If you know all your parameters you can just use the stepconf wizard. If not then start with the converted file.
JT
JT
Last edit: 14 Oct 2013 18:50 by BigJohnT.
The following user(s) said Thank You: terabyte
- terabyte
14 Oct 2013 23:26 #39833
by terabyte
Thanks a bunch JT.
- mikewasouski
05 Nov 2013 13:34 - 06 Nov 2013 02:26 #40544
by mikewasouski
Replied by mikewasouski on topic machine parameter conversion from mach3 to emc2
Hello BighJohn, as the others I want to beg your help to convert my mach3mill.xml to emc configuration file (for the CNC 3040) .
drive.google.com/file/d/0B8yW5_FoT2SjU0F...WFE/edit?usp=sharing
I hope you can help me.
Thanks in advance.
Mike.
Thanks in advance.
Mike.
Last edit: 06 Nov 2013 02:26 by mikewasouski.
- BigJohnT
05 Nov 2013 19:19 #40551
by BigJohnT
Sure can just attach your config to a message and I'll convert it.
JT
JT
- mikewasouski
06 Nov 2013 02:24 - 06 Nov 2013 02:34 #40559
by mikewasouski
Ok here is it, I was uploaded before, but system doesn't accept 7z files and I didn't realized of that.
Thanks.
Mike
Thanks.
Mike
Last edit: 06 Nov 2013 02:34 by mikewasouski.
- BigJohnT
07 Nov 2013 00:34 #40594
by BigJohnT
Here you go...
JT
JT
- palmfans
12 Nov 2013 13:11 #40763
by palmfans
Replied by palmfans on topic machine parameter conversion from mach3 to emc2
Hello BighJohn,
Could you help to convert my 3-axis machine.xml to emc configuration (for Desktop Mini Muscle CNC Machine).
Thanks a lot in advance.
palmfans
palmfans
- BigJohnT
12 Nov 2013 19:13 #40766
by BigJohnT
Here you go...
JT
JT
The following user(s) said Thank You: palmfans
- Pysiek
21 Dec 2013 05:16 - 21 Dec 2013 05:17 #41887
by Pysiek
Replied by Pysiek on topic machine parameter conversion from mach3 to emc2
Hi
Could you convert my Mach3 settings to LinuxCNC also?
Last edit: 21 Dec 2013 05:17 by Pysiek.
Time to create page: 0.143 seconds
