machine parameter conversion from mach3 to emc2
- alromh87
04 Dec 2012 09:14 - 04 Dec 2012 09:25 #27167
by alromh87
Replied by alromh87 on topic machine parameter conversion from mach3 to emc2
Great, thanks.
It only has 3 axis and yes the file is huge.
Thanks again
Thanks again
Last edit: 04 Dec 2012 09:25 by alromh87.
The topic has been locked.
- revo
09 Jan 2013 09:08 - 09 Jan 2013 09:48 #28506
by revo
Replied by revo on topic Re:machine parameter conversion from mach3 to emc2
Big John,
i also need help converting a file..
would that be alright?
its a 4 axis router.
xyza
cheers
xyza
cheers
Last edit: 09 Jan 2013 09:48 by revo.
- revo
09 Jan 2013 09:26 #28509
by revo
- BigJohnT
- Thank you received: 1176
09 Jan 2013 19:20 #28514
by BigJohnT
Replied by BigJohnT on topic Re:machine parameter conversion from mach3 to emc2
Here you go, the zip file contains the instructions in the README file.
Enjoy
Enjoy
- revo
10 Jan 2013 04:44 #28528
by revo
thanks so much, that will help me.
Louis
Louis
- firephoto
30 Jan 2013 06:43 #29285
by firephoto
Replied by firephoto on topic Re:machine parameter conversion from mach3 to emc2
Finally getting around to the software side of my cnc router parts machine so I thought I'd see if the mach3 xml file for it could be converted to use with stepconf. Was having trouble with the xml but finally discovered the name value was in a strange encoding so I edited that and got it to display the values but figured maybe this would save me some time if it could be converted.
This machine has the NEMA 34 PRO drives they call them so the gearing is different slightly than the normal n34 drives. Has PMDX-126 board and gecko 201x's. In case anyone else runs across this.
This is the file directly from their website with the change to the name field in case someone else comes across this. I also see what you mean by all the extra stuff in these mach3 files. I'll be going through the wizard too just to see if I can manually pick out all the values but I figured I'd give this a shot.
I'm all new to the cnc thing so my mechanical and linux experience only goes so far. thanks.
- revo
11 Feb 2013 13:46 #29892
by revo
i have a new board pmdx126 with same motors from cncrp.
idlove to get that file too.
cheers!
revo
cheers!
revo
- BigJohnT
11 Feb 2013 22:16 - 11 Feb 2013 22:18 #29906
by BigJohnT
Lets see if this works.
Nope upload is still broken for me.
Well crap, I'll just use filebin.ca
filebin.ca/WfNUvnb02eD/PMDX-1262012-10-19N34PRO.zip
Last edit: 11 Feb 2013 22:18 by BigJohnT.
- djb204
09 Mar 2013 07:04 #31112
by djb204
Replied by djb204 on topic machine parameter conversion from mach3 to emc2
Hello everybody
I have a problem for configure my CNC with linuxcnc, can you help me (work fine with MACH3) ?
I send my xml configuration of mach3.
Thank you in avance for your help.
Have a nice day.
Joseph
Have a nice day.
Joseph
- BigJohnT
09 Mar 2013 19:30 #31129
by BigJohnT
Replied by BigJohnT on topic machine parameter conversion from mach3 to emc2
Here is your converted file.
Time to create page: 0.138 seconds
