trying to install linuxcnc 2.6
- johnl2
20 Mar 2015 06:56 #57028
by johnl2
Replied by johnl2 on topic trying to install linuxcnc 2.6
Is anybody running Meshcam on Debian Wheezy? I have been trying ALL day to get it working under wine and it just will not open. I keep getting the error message: There is no Windows program configured to open this type of file.
- johnl2
21 Mar 2015 08:06 #57053
by johnl2
Andy, I reverted back to ubuntu with linuxcnc2.5 to see if I could get meshcam to work on it. Well I got it to work under wine, but guess what? No USB! If I do lsusb in the terminal, it lists all devices, but they do not work. My mouse and keyboard don't work and the usb drive does not work. Any idea why, or how to fix it?
Thanks,
Thanks,
21 Mar 2015 09:11 #57057
Replied by andypugh on topic trying to install linuxcnc 2.6
Sorry, no ideas. But you don't have to run LinuxCNC to run under Ubuntu, you can actually update right up to at least 2.7 on Ubuntu 10.04.
MeshCAM is pretty good, but CamBam isn't that far behind and runs natively in Linux:
www.cambam.info/ref/ref.linux
- johnl2
21 Mar 2015 11:15 #57060
by johnl2
That looks pretty good. Is it free too?
I wish I could just use ubuntu, but my usb does not work on it, only in debian.
Can the OS itself cause latency issues, like ubuntu vs debian?
- pws
22 Mar 2015 00:19 - 22 Mar 2015 00:21 #57072
by pws
Replied by pws on topic trying to install linuxcnc 2.6
Just my 2 cents! I updated an older system with an "newer - over spec'd" ASUS MB with an AMD A105800K. I installed the latest LinuxCNC/Debian and my latency went through the roof! I then went back to a copy of what was running on the system before the MB update (Ubuntu 10.04) updated to the latest LinuxCNC version (2.6.x) and latency went back down - lower than I expected!
I have no trouble at all with USB with the new MB. Recently added a XHC HB04 (USB) and it works great.
I suggest you dig deeper on the USB issue - it should work. Check your BIOS settings for USB, etc.
Last edit: 22 Mar 2015 00:21 by pws.
- johnl2
22 Mar 2015 06:01 #57078
by johnl2
Thanks for your post. I worked on it all day today and tried reinstalling 10.04 via usb. It did not work, I kept getting an error saying it could not find a working file system. I messed with some settings in bios, did it thousands of times before but this time I changed some other things. Well, usb worked all of a sudden and everything is fine. So I'm not going to use Debian since I cannot use meshcam on it. Everything is fine now with ubuntu and I'm just going to keep it this way.
Thanks,
Thanks,
- eFalegname
- Thank you received: 30
21 Oct 2015 15:17 #64033
by eFalegname
Replied by eFalegname on topic trying to install linuxcnc 2.6
I'm agree with pws and John. I'm also ready to do the downgrade to Ubuntu 10.04 which offers IMHO better performance and lower latency results than Debian.
Is there someone who can confirm this hypothesis from a real theoretical point of view?
Time to create page: 0.096 seconds
