Followed a different install method, working now.
Having some problems with this.
Here's the output from the terminal.
blacksmith99@optiplex745 ~/lcnc $ sudo apt-get install imagemagick texlive-font-utils tcl8.6-dev tk8.6-dev libxaw7-dev libncurses-dev libreadline-gplv2-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libncurses5-dev' instead of 'libncurses-dev'
imagemagick is already the newest version.
libxaw7-dev is already the newest version.
libncurses5-dev is already the newest version.
libreadline-gplv2-dev is already the newest version.
tcl8.6-dev is already the newest version.
texlive-font-utils is already the newest version.
The following extra packages will be installed:
libfontconfig1-dev libfreetype6-dev libpng12-dev libxft-dev libxrender-dev
libxss-dev tk8.6 x11proto-render-dev x11proto-scrnsaver-dev
Suggested packages:
tk8.6-doc
The following NEW packages will be installed:
libxss-dev tk8.6 tk8.6-dev x11proto-render-dev x11proto-scrnsaver-dev
0 upgraded, 10 newly installed, 0 to remove and 71 not upgraded.
Need to get 20.1 kB/2,835 kB of archives.
After this operation, 9,288 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1
mirrors.liquidweb.com/debian/
jessie/main x11proto-render-dev all 2:0.11.1-2 [20.1 kB]
Fetched 20.8 kB in 0s (112 kB/s)
E: Failed to fetch
mirrors.liquidweb.com/debian/pool/main/x...dev_0.11.1-2_all.deb
Size mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
tk8.6-dev is the part that is causing the issue.
I have no idea what to do about the "size mismatch" error.
Any ideas?
Thanks!
Matt
