Linux Mint with RTAI
10 years 9 months ago #67833 by cncnoob1979
Replied by cncnoob1979 on topic Linux Mint with RTAI
Sorry Andy I'm not following your statement. Linuxcnc configuration picker vs Linuxcnc?
Are you saying with my above configuration I have the configuration picker open?
I'm running the sim mode to verify the install procedure. How would I tell either way, or how could you tell?
10 years 9 months ago #67835 by andypugh
Replied by andypugh on topic Linux Mint with RTAI
In the second image of #67655 I see a menu item "LinuxCNC Configuration Selector" which I suspect has the same function as the "LinuxCNC" menu item that you said was missing.
Or I might be completely confused. It happens a lot.
10 years 9 months ago #67840 by cncnoob1979
Ahh ok, I got it.
The "start" menu is open and is overlaying on the linuxcnc program in that screen shot. (It appears almost the same color ect.)
I was attempting to show the cnc menu item was "messed up" because it placed linuxcnc under the "other" category with that install procedure.
And no worries. I'm still confused! :silly:
10 years 9 months ago #68039 by BigJohnT
Replied by BigJohnT on topic Linux Mint with RTAI
2.7.0 has this terrible menu that I made then I corrected it for 2.7.1.
JT
10 years 9 months ago - 10 years 9 months ago #68040 by cncnoob1979
Did you post your changes? I'm just now installing on my mill pc. I just re-downloaded your files.
I'm such a noob.
The .deb packages you built are intended to be installed with a package manager.
I've been following your guide JT and building my Linuxcnc from source. Haha! No big deal - see I'm learning already ;) wish my brain would have kicked in before I told it to build the .deb
Oh well a learning point for me!
Last edit: 10 years 9 months ago by cncnoob1979.
10 years 9 months ago #68167 by timewarp
Replied by timewarp on topic Linux Mint with RTAI
Hi, I am also having a few problems installing Mint with xfce. I used JT's script. My motherboard is a gigabyte j1900.
When Grub starts the new rtai kernal, I get a black and white illegible screen. if I boot into safe mode and then continue, all is good.
I think this is the same thing as jts was experiencing??
Here is My grub config file if that helps.
pastebin.com/ktU2kx9n
Linux experience is limited!
Paul
Time to create page: 0.075 seconds
