Linux Mint with RTAI
10 years 10 months ago - 10 years 10 months ago #67658 by BigJohnT
Replied by BigJohnT on topic Linux Mint with RTAI
I've just uploaded my latest notes including the menu fix as well as others to my website here . There is something wrong with your install procedure if you have to launch LinuxCNC with sudo... I think I've installed about 10 times with the latest instructions just to test and I think I've got everything covered, if not let me know.
JT
Last edit: 10 years 10 months ago by BigJohnT.
10 years 10 months ago #67659 by cncnoob1979
Replied by cncnoob1979 on topic Linux Mint with RTAI
Thanks JT,
I was under the impression your install was a different procedure. I'll use your method to see if I get a different outcome. Man this is fun but frustrating, you don't know what you don't know! lol
Thanks for the help.
10 years 10 months ago #67660 by BigJohnT
Mine varied I think in what desktop you ended up with and perhaps how you got from blank to running LinuxCNC as well as all the other little fixes I ran across along the way. And you are very correct the more you know the more you realize you don't know about...
JT
10 years 10 months ago - 10 years 10 months ago #67661 by cncnoob1979
JT,
Just finished the installation and went very smooth. However while installing the deb I did get a error.
Installing new version of config file /etc/linuxcnc/rtapi.conf ... dpkg: error processing package linuxcnc (--install): subprocess installed post-installation script returned error exit status 1
Did you get the same on your install? Otherwise everything worked and the menu fix was spot on. Thanks for the help brother! I hope things go this smooth when I install on my mini atx motherboard.
Last edit: 10 years 10 months ago by cncnoob1979.
10 years 9 months ago #67666 by BigJohnT
I don't remember an error like that but if your up and running ignore it! Now if I can figure out why my image is not showing up...
JT
10 years 9 months ago #67821 by andypugh
Replied by andypugh on topic Linux Mint with RTAI
For some reason you seem to have "LinuxCNC Configuration Picker" rather than "LinuxCNC" but I am fairly sure that they do the same thing.
Time to create page: 0.075 seconds
