Linux Mint with RTAI
10 years 11 months ago #65633 by BigJohnT
Replied by BigJohnT on topic Linux Mint with RTAI
Ok I have the rtai kernel and LinuxCNC 2.7 installed and everyone is happy. I've attached my notes.
JT
10 years 11 months ago - 10 years 11 months ago #65672 by jtc
Replied by jtc on topic Linux Mint with RTAI
just installed a new RIP version ans compiled it.
looks like everything is running ok.
My next step is try to install a Preempt-RT kernel (if exists? ), compile again and see if works.
If everything is ok, I will install it in a real machine a use with mesa Ethernet cards. (and try to forget Debian wheezy :whistle: )
João
Last edit: 10 years 11 months ago by jtc.
10 years 11 months ago #65674 by tjmarch
Replied by tjmarch on topic Linux Mint with RTAI
JTC
If you use readme file and archive method in post:
forum.linuxcnc.org/forum/18-computer/299...mint-with-rtai#65402
Preempt-RT kernel can be installed for rip just follow directions
Tim :)
10 years 11 months ago #65679 by tommylight
Replied by tommylight on topic Linux Mint with RTAI
tjmarch wrote: tommylight
If you want it to work follow the directions in readme file download from here
Tim
just got to having a look at it, thank you very much, will report back.
Tom
10 years 11 months ago - 10 years 11 months ago #65691 by tjmarch
Big John T
Looked at your notes tried to make deb got to part of process
debuild -uc -us <this command must not valid option anymore "skips the signing steps" or is key needed
debuild <here were it failed after running for a long while
file stopped processing with this message
Finished running lintian.
Now signing changes and any dsc files...
signfile linuxcnc_2.8.0~pre1.dsc Sebastian Kuzminsky <seb@highlab.com>
gpg: skipped "Sebastian Kuzminsky <seb@highlab.com>": secret key not available
gpg: /tmp/debsign.opEtbNf4/linuxcnc_2.8.0~pre1.dsc: clearsign failed: secret key not available
debsign: gpg error occurred! Aborting....
debuild: fatal error at line 1283:
running debsign failed
tim@tim-linuxcnc ~/src/linuxcnc $
I do have several deb files in src directory
Tim
attached are my notes
Last edit: 10 years 11 months ago by tjmarch.
10 years 11 months ago - 10 years 11 months ago #65696 by BigJohnT
What I'm doing now to build the 2.7 deb is:
git clone git://git.linuxcnc.org/git/linuxcnc.git mint cd mint git checkout 2.7 debian/configure -r ; debuild -uc -us > configure.txt
And to install the deb:
sudo dpkg -i linuxcnc_2.7.2_i386.deb sudo dpkg -i linuxcnc-doc-en_2.7.2_all.deb
I have found that Xfce has issues with the menu and if you try and edit it with the menu editor it crashes the editor and you can't edit menus unless you replace the messed up file. So that makes me want to try LinuxMint with Cinnamon next.
JT
Last edit: 10 years 11 months ago by BigJohnT.
The following user(s) said Thank You: tjmarch
Time to create page: 0.452 seconds
